Installing hydraulic disc brakes
Hi,
I'm thinking about getting hydraulic disc brakes installed on my Salsa Warbird, which has internally routed cables. Can someone give me a ballpark estimate of how much the installation might be?
Dave
Dave
Quoted: 827 Post(s)
Liked 1,660 Times
I would recommend you talk to the LBS that you plan on having the work done at. I could tell you it would be $10 for installation, but they may disagree.
Likes For Bald Paul:
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
It could be anywhere from $30-$100. If they just go on smoothy and don't require a bleed, they might charge you something like $30. If they are problematic and they need to do a bleed, on both ends, expect close to $100.
Since you can't do your own work, it makes sense to ask your LBS. Internal routing is no big deal. Having old cables and housing in place makes it easy to reroute hoses.
Dave
Quoted: 1401 Post(s)
Liked 1,886 Times
if you go Shimano - their systems use mineral oil (instead of DOT fluid)
Likes For t2p:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
You're putting brakes on...what does that have to with the drivetrain? There are thousands of bikes out there with SRAM drivetrains and Shimano brakes. You're not committed to anything.
Dave
Quoted: 406 Post(s)
Liked 389 Times
Or are you just talking about using Shimano hydraulic brifters and brakes with SRAM cranks, cassettes and derailleurs (I did not thing you could mix rear derailleurs).
If your bike has mechanical disc brakes now, you'll need new brake/shift levers, with hoses and calipers. That's a major expense. I've built several bikes with Force AXS hydraulic. Sram has videos that show how to do it. Hose cutters and a bleeding edge bleed kit are needed for Force. Using DOT 5.1 fluid is actually easier, since it wipes off with a damp rag. I didn't even bother with nitrile gloves. If done right, the fluid should never contact the bike frame, but if it does, just wipe off with a damp rag.
Bikes: lots
Liked 2,932 Times
My bad. If this a drop bar bike you are stuck with whatever brand your are currently using. No, you can't use Shimano SHIFTERS with SRAM drivetrain parts. A J-tec Shiftmate would probably allow it but I haven't used them for years.
Quoted: 426 Post(s)
Liked 274 Times
https://www.salsacycles.com/bikes/road/Warbird
Did you just mean pads and rotors?
Quoted: 406 Post(s)
Liked 389 Times
what year is your bike? The current warbird has hydraulic disc brakes.
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 467 Post(s)
Liked 548 Times
Possibly guilty of being a FanBoi, but Hope makes calipers that work with both Shimano and SRAM. I've not used those, but their Flat Bar setups have performed well for me even in the extreme cold that my Fat Bike sometimes sees. They list at 100 GBP and Merlin has them for just under $100 US
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I haven't looked at the current Warbird build to make sure but it's very likely the current Journeyer came up a level to replace the lowest build on the Warbird. In prior years the top Journeyman and lowest Warbird both were Apex 1 cable. But I think the highest Journeyer is now GRX 600 with hydraulic
Install aside, current hydraulic brifters are just astonishingly expensive. you want how many hundred for a syringe and a ratchet?
Genesis 49:16-17
Genesis 49:16-17
Quoted: 1461 Post(s)
Liked 1,486 Times
Back to the OP's question: one of the local shops near me advertises $40 per hydraulic brake to install levers, calipers and bleed and adjust the brakes. So $80 for the set. I've also been charged around $40 per brake by other shops for bleed/adjust, so I'd expect to pay a similar amount for new install.
This price doesn't include installing rotors or doing anything to the drivetrain (if you have a mechanical drivetran and are installing new levers... you should probably also replace the shifter cables and will need to set-up/adjust both derailleurs). You'll also need to re-tape the bar.
Quoted: 426 Post(s)
Liked 274 Times
I replaced my sram brakes on my Blur with four piston shimano brakes. The front was super easy. Probably 15 minutes. It was all external.
If I could walk to my LBS within 10 minutes I would pay someone $40 to do the back brakes.
It was enough of PITA to cut/barb/pull/bleed the back. ha-ha Expect I am too lazy to drive my bike to the shop ( 20 minutes one way ), wait a few days and then have to pick it up.
The shop I worked in charged an extra 25 bucks for internally routed hoses. They are a PIA regardless of what others say. Front and rear install with bleed would be 140 bucks. It is billed as a two hour job. If it takes less than that then the billing is adjusted.
Clark W. Griswold
Quoted: 4365 Post(s)
Liked 4,006 Times
I would go down to the local shop and see what they charge. You can ask random people on the internet but your local shop will actually have your pricing. Every shop can have different pricing based on a lot of different factors.
Dave
Likes For bonsai171:
I recently upgraded my mountain bike with new Magura brakes. The only tools I needed were a set of Allen wrenches, a box cutter, and, for kicks, a bleed kit. The kit and he tools cost $30, installation took about 30 minutes, and I did it at the nearby park. Had I been more careful, I wouldn't have needed the bleed kit.
