Pressure in your Schwalbes ?
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
What pressure do you run in your Schwalbe Marathon's ? I am getting a pair of Marathon Plus tires and want to find the most comfortable ride with the lowest pressure I can use. Our streets are in bad shape, I need the beefy tread.
Quoted: 5224 Post(s)
Liked 3,585 Times
Don’t have those but fwiw my 2" marathon winter tires are rated 35-70 & I have them at 50 front 60 rear. but I think on unpaved dirt I will lower them to 40 front 50 rear. They have rather stiff sidewalls
Quoted: 2497 Post(s)
Liked 741 Times
Pressure is tied to the tire size. A 28mm tire is getting sploogie at 80posi. A 35mm tire at 80psi is just fine. What size Marathon Plus do you intend to use? Why do you want to use the lowest pressure you can use? With a tire that has such a high rolling resistance as the MP you should want to use the highest pressure you can use. That pressure is printed on the sidewall. If you want a more comfortable ride, get a more compliant seat or seatpost. For tires to make any difference to comfort you need 2.0+" tires with 25psi to 30psi. Do MP's come in 50mm?
Quoted: 327 Post(s)
Liked 250 Times
The tires are 700 x 32's
I found that on my 700 x 32 Gatorskins I lowered the pressure to 60 psi and had a noticeable improvement with a softer ride on our rough pavement in our area. I would like to run a little lower pressure on the MP's too. I know I can't get too carried away but there is a happy medium there somewhere. Curious what pressure others are using with these tires.........................
Quoted: 2604 Post(s)
Liked 1,933 Times
Quoted: 7353 Post(s)
Liked 2,481 Times
It depends on the construction of the tire, the width of the tire, the condition of the roads, and total weight of rider+bike+cargo. After you do some experiments, your favorite pressure might be very different from the pressures people recommend to you. I'm only 160 lbs (73 kg), and I find myself being comfortable at surprisingly lower pressures, mostly because I'm so much lighter than people I know.
One way to experiment is to drop the pressure to a noted level and then see how close you are to bottoming out on potholes. This comes with an obvious risk, but how else do you get negative feedback?
Another tip is that most people tend not to top off our tires frequently enough. So it's a good idea to overinflate at least a little to buy yourself some extra time between top-ups.
Quoted: 327 Post(s)
Liked 250 Times
pdlamb,
I weigh 170 pounds. I'll experiment with the pressure and see where the magic spot is. Sounds like it might be around 70 psi
Thanks for the info, much appreciated !
Merry Christmas
Bob
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Marathons have pretty stout casings. You probably don't need all the pressure as you can cram in. You might need less than you do with a "supple" tire which we mostly groupthink agree is already a lot lower than what we used to run. 60 sounds about the right kind of pressure to me for a 32.
Genesis 49:16-17
Genesis 49:16-17
Liked 741 Times
Disco Infiltrator
Liked 2,105 Times
If you have a 32 Marathon you've already given up all that
Genesis 49:16-17
Genesis 49:16-17
Getoutofmyway
Quoted: 9 Post(s)
Liked 12 Times
I use Marathon Plus on all my bikes. 26x2.0, 700x28, 32, and 38.
I inflate to max pressure indicated on the tires in the spring and use them until October. By then they are way below minimum pressure and are sluggish.
I find that at minimum pressure and a bit below is best, around July August they fly and float.
Cyclist
Quoted: 39 Post(s)
Liked 16 Times
I have the same tires and have run them as low as around 45 psi when I don't get around to checking the pressure. Lower pressure is a lot smoother on brick streets.
Likes For storckm:
Likes For fooferdoggie:
I run 700x35 standard Marathons with around 60psi. I find it to be a good balance between comfort and speed.
Miles to Go
According to new data on rolling resistance, Ideal pressure is a lot lower than what I thought, and what I was running in the past.
Check out: https://silca.cc/pages/sppc-form
I get 58/56.5 for you for 200 lbs rider, bike, gear, 700c X32c, puncture resistant tires.
Additionally, the lower the pressure, the more comfortable the ride.
Likes For timdow:
Liked 2,481 Times
Likes For noglider:
Liked 741 Times
Just mounted a set of MP @ 26" x 2.0 on a tandem (50lb + 345lb team + 30lb+ load) and for the first ride I tried 60psi f/r and loved the ride. Anyone who thinks these tires are heavy and slow needs to try some Bontrager H2 in the same size! For the second commute I put an extra 5lb in the rear but there wasn't any reason why. Just for some added perspective. This tandem is used so a blind Stoker can get to work every morning. This means the Captain rides back minus the Stoker weight *cough* over 145lb and all the gear in their panniers. Do I re-calculate the tire pressures for the return trip? Absolutely not.
Quoted: 4806 Post(s)
Liked 3,933 Times
On top of all the above, factor in your weight. (May have been mentioned, I didn't read all the threads.) A poster above talks of 80 psi in a 35c tire. If that pavement isn't smooth, at under 150 lbs, that's a harsh ride for me. I go 70 max that large a tire. Edit: that's on a relatively smooth running, thinner casing Paselas. Marathons - probably lower.
