Need circlip source
Bikes: 70's Nuovo Record Jeunet Franche Compte, '88 105 Trek 1200, '85 Victory Bianchi Vittoria, '89 Exage Bianchi Strada LX, '11 Shimano Masi Partenza
Quoted: 109 Post(s)
Liked 19 Times
Need circlip source
Would anyone know where to get these Campagnolo specific mini clips that retain the brake cable anchor on Campys Victory calipers by chance? I know where to get non Campy specific ones at, I just wasn't really interested in spending the money and shipping for I'm betting minimum of 50, in various sizes in hopes one of them will fit. Any Campy collectors out there have actual Campy spares laying around?
70's Nuovo Record Jeunet Franche Compte, '88 105 Trek 1200, '85 Victory Bianchi Vittoria, '89 Exage Bianchi Strada LX, & '11 Shimano Masi Partenza
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,383 Times
...they're often listed as "snap rings". I once bought a large assortment of them, in various sizes, years ago.
I think I bought my assortment online, from some source on Amazon. You could try an auto parts place, or an industrial fasteners store, if one is nearby.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Lowe’s, Ace, Home Depot and such have often them.
Likes For Chuck M:
Quoted: 1106 Post(s)
Liked 1,328 Times
I have one of those, so I took it apart and measured
The shaft is 5.88mm.
The groove is 5.47mm.
Getting the snap-ring back on was tricky.
When placed on the pliers in the same orientation used to remove it, there ring would flip away from the shaft as the pins of the pliers forced it apart.
There wasn't enough clearance to turn the pliers so the ring would go over the end of the shaft.
The trick was to flip the pliers backwards, then it would go on at the far end of the shaft at least:
Then after the shaft is though both holes you can safely push the ring flush against the bracket and wiggle the pliers out.
Then slide the ring down to the groove; keep it as parallel to the shaft axis as you can, off-axis will stretch the ring.
I use the pair of large tweezers partly shown with the arms placed on opposite sides of the ring.
It will likely be stretched a bit anyway, so when you have it in the groove take the other pair of pliers and squeeze the ends closed.
Bianchi Goddess
Quoted: 2937 Post(s)
Liked 2,934 Times
True Value, Do it Best.
Maybe a automotive or motorcycle shop that specializes in rebuilding parts like carburetors, a/c compressors etc.
Sugar "Kane" Kowalczyk
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,008 Times
The most common search term I found is "external retaining ring". Harbor Freight has a 300 piece kit for $5.99. Lowes has them, two to a package for about $0.80.
