Drying a bike by machine
Quoted: 144 Post(s)
Liked 119 Times
I tried drying a bike with an ancient data-vac (electric handheld machine for blowing dust out oof computers). It did the job quickly and thoroughly, then died.
Now I’m in the market for a new drying machine. It will only be used for drying bikes. Small and cheap would be good. Portable (i.e. fit in a backpack) would be even better. Having to be plugged-in is fine.
Any recommendations? I'm in Sydney but will order overseas if necessary.
Cheers.
Cheers.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Likes For terrymorse:
Likes For fredlord:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2590 Post(s)
Liked 5,656 Times
No suggestion for you Lord Fred, but an interesting observation the other day after I cleaned my chain using a chain pig and Parks chain cleaner. Usually I wipe the chain as thoroughly as one can with rags. This time I used compressed air to get the remaining cleaner and rinse water out of the chain and was shocked to see how much liquid the chain was still holding as well as hidden black residue. I will be using the compressor in the future after cleaning and rinsing.
Fred you may want to check Amazon for mini-blowers. Here’s a page full of them: https://www.amazon.com/s?k=mini+air+..._ts-doa-p_1_16
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 18428 Post(s)
Liked 15,582 Times
Something wrong with a blow dryer from somewhere like CVS?
Likes For indyfabz:
Likes For tempocyclist:
Quoted: 6974 Post(s)
Liked 10,975 Times
Wipe it off with a clean soft towel and let it sit. Using forced air to dry a bike will potentially force moisture into places it should not go.
Likes For Koyote:
Quoted: 314 Post(s)
Liked 683 Times
Yes they blow hot, and that could be an issue with frame stickers and whatnot. Some hairdryers have a "cool" setting I'm pretty sure, which would be better.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
My first thought was a small shop vac used in blower mode. But I like the leaf blower idea more. The leaf blowers can be had in cordless styles which would probably be more convenient.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
https://www.amazon.com/Conair-Mid-Si...843142255&th=1
Liked 15,582 Times
Your lungs? Free, cordless and no power required.
Likes For indyfabz:
Bounce it on the tires a few times? That shakes off a lot of the major drops. I use WD40 to displace water from some parts like the retention portion of spd pedals. It leaves some minimal lubrication and doesn't leave anything that dirt clings to.
I have used a not too powerful battery leaf blower at times, but usually just a few bounces and some Florida sun.
Quoted: 1034 Post(s)
Liked 1,292 Times
A bike should be able to handle temperatures your head does.
Liked 15,582 Times
Liked 2,981 Times
Likes For Troul:
Quoted: 4227 Post(s)
Liked 2,488 Times
Why speed up the drying ?....Why can't you just leave the bike alone and let it dry naturally on its own?.
climber has-been
Liked 3,567 Times
Quoted: 680 Post(s)
Liked 949 Times
yes my shop in winter has no heat and if it is 99% humidity and raining for weeks on in my bike never dries. I use an electric leaf blower (because I have one) to blow the water off the chain so it wont rust. fast and easy.
Quoted: 970 Post(s)
Liked 1,632 Times
Over the past years I have come to use my leaf blower. I wash my bikes with laundry soap and water using a soft brush. I then blow off the water and then spray the entire bike with ArmourAll tire foam. I spray everything. Seat, brakes, tires, spokes, hubs, bars... everything. I then hit it with the leaf blower again then wipe the entire bike down with a soft cloth. The emollients in the tire foam leave a nice shinny layer of protection over the paint, metal and rubber/plastic components as well a low level lubrication.
I would probably do things much differently if I was doing dirty mountain biking and bringing home a crusty bike...
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,923 Times
That works when it's warm, and dry enough outside, or even inside where the bike(s) are kept, but this winter it was always wet outside, and my bikes are kept in an unheated garage, and of course needed to be washed more frequently because they were ridden in the wet. So I would close run a space heater to warm up the garage and a box fan to circulate the air.
