Carbon frame scratch repair
Quoted: 20 Post(s)
Today I accidentally dropped my keys on the top tube of my bike and they have made a small scratch on the carbon frame. What can I do to cover it?
Quoted: 9656 Post(s)
Liked 6,366 Times
I would try a auto paint polish. That looks like a Mar in the clear coat. May polish out.
Likes For Mojo31:
Quoted: 6199 Post(s)
Liked 4,816 Times
Ignore it. If your fingers are a little oily, then rub on it some and some of that will disappear. It'll fade away with subsequent use of the bike by getting dirty and then being cleaned.
If you need more immediate results then any kind of oil, fat or grease rubbed on it will fade it.
Or get a new bike and send that one to me!
Likes For blacknbluebikes:
member
I think this frame is a goner... I can pm you my shipping address :-)
But seriously, nail polish works great and easy to match - I once had a purple bike and I brought it to Walgreens nail section and matched perfectly.
Thread Killer
Quoted: 3151 Post(s)
Liked 1,717 Times
I’ve used clear nail polish to fill in a chip in clearcoat on my brake levers, but I don’t think that’ll be necessary here.
Liked 4,816 Times
Have you never seen cars that have big blotchy areas on them but are otherwise smooth? That's because someone polished them too much and wore through the clear coat exposing the paint. Polish is abrasive and removes material. You'll be making your clear coat thinner in a large area around the ding. And while trying to smooth out the ding, you might wear it off almost entirely.
If you have to smooth the ding, then use the edge of some fine sandpaper or even a emery board for fingernails. Then put a blob of something clear on it. Like fingernail polish. Or look to see if they have some clear coat touch up at the auto parts store.
Me, I wouldn't worry about it. It'll disappear enough on it's own over time. Marks and dings tell history, even if it is just your keys falling on the frame.
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
Likes For Eric F:
Liked 4,816 Times
I just have to figure out how to get your name or some other's substituted for mine somehow in the stories of the dings and scratches on my bike! <grin>
Habitual User
Liked 8,100 Times
Mine end pretty much the same way. But one can make some fun conversation building a story around them. Even the falling keys.
Likes For Eric F:
Thread Killer
Liked 1,717 Times
Liked 4,816 Times
Still, repeating myself, I'd ignore the nick or scratch. Out of mind and it will eventually be out of sight.
Liked 6,366 Times
If you want to try, stay away from "compounds" as they are very aggressive. Use something like these products by hand using a microfiber cloth. You would have to be at it for a week to burn through the clear, and the odds of making it worse are very remote. I used both of these to remove light scratches from a Bronco hood using random orbital polishing machine, and it came out looking like new. You aren't removing the scratches, but are just blending the thickness differential at the edges of the scratches.
Personally, I'd try some to see if you can make it less obvious because I'm an anal SOB, but there will be a next scratch.
First clean the area with mineral spirits or similar solvent that leaves no residue.
I would mix up a small amount of clear epoxy (the 5 minute stuff will do) and apply it to the nick with a toothpick or fine disposable brush.
After it dries (allow it to cure overnight even if you're using 5 min stuff), lightly sand it smooth with 400-600, 1000, and 2000 grit sandpapers, then polish it with aluminum polish.
