Rear Drop Out Angle on Vintage Bike
I measure about 73 degrees on this bike. 64 cm seat tube. It was built for a claw derailleur hanger, but I would like a more modern set up. Are there “common” angles that were used in mfg bikes? I see a few 72 and 74 degree dropouts from suppliers.
"It's a fine line between absolute genius and sheer stupidity"
Quoted: 4211 Post(s)
Liked 3,881 Times
Just to be sure you are talking about the angle between the stays, not the angle of the slot relative to... Andy
AndrewRStewart
AndrewRStewart
Also, used a protractor, should have used a tape measure and a trig table!
Quoted: 714 Post(s)
Liked 800 Times
Unless they are socket style dropouts, you can make a single angle dropout work for a wide range of angles between seat and chain stays. The tabs are generally wider than the stays and you can shape them to flow better with the angle of the stays.
Likes For dsaul:
These are indeed tabs, not sockets, so I do have some wiggle room. Can a socket style be brazed over a slotted stay or would that leave too weak a connection?
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Randomhead
Liked 3,701 Times
I wouldn't try replacing tabbed dropouts with socketed ones. Sounds like a recipe for frustration and early failure.
Randomhead
Liked 3,701 Times
If you cut off the slotted part, the dropout isn't going to fit the frame. If you don't cut out the slotted part, it's going to be structurally questionable.
