New wheel, old steel bike. Powerful stroke sends wheel into left chainstay
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 225 Post(s)
Liked 163 Times
So I need a good solution. I'm running new 650b wheels on a 1984 Nishiki Prestige. If I'm pedaling smooth and not forceful, no issues. However, if I decided to stand on the pedals and give a forceful stroke, the modern rear skewer cannot hold the wheel, and now the wheel is pushed over to the left chainstay.
Are there any good skewers with a good bite that can hold this. I can take my newer skewers and really torque the wheel down, and this holds most of the time. But, I do assume a better solution is out there.
Quoted: 4418 Post(s)
Liked 1,569 Times
Shimano skewers.
Likes For Kontact:
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
yes you'll want an old school skewer that can develop some clamping forces.
the Shimano ones from the mid 90s are good. DA 6500 series ?
/markp
/markp
Likes For mpetry912:
Quoted: 5793 Post(s)
Liked 2,593 Times
Modern hubs and skewers are designed around vertical dropouts, and lack enough holding power for horizontal dropouts.
You need to improve the bite enough to keep the chain from pulling the axle forward.
Better skewers are a step in the right direction and will help, but if you ride steep hills it might not be enough. I prefer to get bite from the axle faces, using hardened serrated lock nuts where possible. Otherwise, I "glue" coarse grit to the face with a nylon based nail polish or similar.
There's more than one way to solve this, but they all involve improving the grip of hub and/or QR into the dropout.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
Get the steel DT Swiss screw-on skewer, or one of the steel anti-theft skewers that require the use of an alan key wrench, and torque that thing until your hand starts to bleed.
Likes For Polaris OBark:
Really Old Senior Member
If you want to go retro, get a solid axle & serrated nuts.
Quoted: 2490 Post(s)
Liked 2,959 Times
In addition to the other advice, double-check that the axle ends don't protrude past the outer faces of the dropouts. Otherwise, the skewer might be clamping partly on one or both of the axle ends rather than on the dropout faces.
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 117 Post(s)
Liked 209 Times
It would be helpful friday1970 if you had photos or at least told us what skewer you are using. I had an issue of my rear wheel slipping on a steel bike and finally realized the Performance brand external cam alloy/steel skewer was insufficient to hold the wheel in place. So I bought a lower end non-group specific all steel Shimano internal cam model from ebay(with the recessed nut for the lever), for a steel on steel clamp sandwich. Not one budge of the wheel since.
I don't think it necessarily be all steel though as I also have some alloy/steel Shimano levers on another steel frame that don't slip either. I've also used vintage Campy and Suntour steel QR's on these frames and they all hold w/o ever moving. So three cheers for internal cams
Likes For Garthr:
Quoted: 225 Post(s)
Liked 163 Times
Early in the morning here and busy getting taking off to work. I'll take a few pics tonight and upload them
Sr Member on Sr bikes
Likes For _ForceD_:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Did you need to spread the dropouts to fit the new wheel? If so, the dropouts may need to be realigned. There's a tool for that.
And change the skewer.
Likes For andrewclaus:
Quoted: 1944 Post(s)
Liked 2,164 Times
In 1984, your bike probably had 126mm dropouts. You did not state if the OLD of the new 650b wheels is 130mm. If this is the case then you either cold set the dropouts to 130mm or are just forcing the wheel into the dropouts by spreading them.
I cold set the horizontal dropouts on my wife’s 1986 Univega and the same thing happened, even though she’s not powerful and did not stand up out of the saddle.
Although skewers will help, I got an 80’s Deore, the real problem is the dropouts are probably not square/parallel after being spread. They flare out and no skewer is going to straighten them. Get the dropputs square/parallel and your problem will most likely go away.
You might still want to use a good internal cam skewer, but my wife eventually ended up using steel/aluminum external skewers.
John
John
Likes For 70sSanO:
Quoted: 1110 Post(s)
Liked 1,204 Times
Your bike probably has a horizontal drop out rather than the current type which is called vertical dropout. You need an "internal cam" quick release because it can be tightened more securely. As others have said, Shimano makes them, but so do many others. You can find one at whatever pricepoint you want online. Also most likely at a local bike shop, and maybe even for free if they have a box of stuff that they aren't using.
For vertical dropouts you can get away with an "external cam" QR, which are generally lighter and work fine.
Quoted: 3515 Post(s)
Liked 2,927 Times
Aside from a cleaner look, why does the inclusion of a cover make an internal QR work better?
Quoted: 504 Post(s)
Liked 437 Times
It's not the fact that it's enclosed that improves the action, it's the smaller hardened steel cam as opposed to a larger aluminium and plastic mechanism that gives better mechanical advantage and strength.
Quoted: 4806 Post(s)
Liked 3,933 Times
Steel shaft because it has the highest modulus of elasticity of any usable metal. Twice that of aluminum and half again that of titanium. It stretches less. Stretch is the shaft relaxing and losing tension.
Internal cam design is simply better than external. Much more clamping force. You want to use a skewer made by a major manufacturer after the late '80s or so (I don't know when the change happened) and the cam shape was reworked to provide more clamping and a better lock when shut. I believe Shimano was on the leading edge here. In any case, any modern Shimano has the new cam. And all the Shimanos, of any price, have good construction and do the work of securing wheels very well.
So, el-cheapo Shimanos rule. You cannot get better, just lighter, sexier and lower bank balance. Go to your bike shop and ask for a $12 Shimanos of the correct length.
Skewers I use: Cheap Shimanos on my city bikes. Various on my 126 OLD 7-speeds. All internal, all steel skewered and probably the new cams but I don't really know. My primary 7-speed is getting re-vamped now so it will probably roll on with the new cam. Higher end Chorus and Ultegra on my best bikes. Early '00s, steel skewers and the new cams. All but one of my bikes is horizontally dropped. I'm not massively strong, nor do I have strong hands. I don't kill myself closing the QRs. Rear wheels only slip if I forget that the wheel is only in tight enough to not fall out. (I was working on the bike and needed to put it away to free the stand for another, say.)
The fix: a 2mm spacer/washer under the quick release on the left side.
Likes For Dave Mayer:
Quoted: 969 Post(s)
Liked 1,632 Times
I continue to use light weight skewers on my wheels instead of the heavy steel skewers needed. I simply took a piece of aluminum and use it to fix the skewer in place. This might work for you...
https://www.bikeforums.net/classic-v...fix-final.html
Liked 1,204 Times
I think the reason the external cam ones are so ubiquitous is that they can be lighter, maybe cheaper to manufacture, and do work fine with vertical drop outs.
Likes For Camilo:
Quoted: 504 Post(s)
Liked 437 Times
I think "lightweight" and "available in colours" were both selling points when they first achieved popularity/notoriety, but "easy to make cheaply" was probably why the manufacturers liked them.
Likes For grumpus:
Liked 2,593 Times
FWIW the arguments about internal vs external cams us a distraction. Either design can be made to generate more or less clamping force simply by altering the rise.
The critical differences are the material and shape of the faces. Steel vs. aluminum, and dentated or formed to a pointed foot vs. flat and smooth.
Take a moment to consider a pipe wrench. Would you want one made of aluminum, or with smooth jaws that won't mar the pipe, or one with hardened, sharp teeth that bit and held in a way that would make a bulldog proud?
QR design went south when vertical dropouts eliminated the need for serious holding power. So those with horizontal dropouts need QRs designed for them. That these older designs happen to have internal cams is coincidence.
BTW there were quality external cam QRs back in the day, one if the nicest was by Simplex.
Even with your fix, I would never use an aluminum quick-release; Despite it being 1/3 as stiff as steel (and sometimes more elasticity makes a better hold, hence some engines having head bolts that are super long and extend into the block skirt), aluminum is notorious for fatigue failure in high stress environments; Steel and titanium hold up much better under fatigue. Usually to make something aluminum hold up in fatigue, it needs to be designed stiff, thus my 35 year old Cannondale racer that rides like iron until fit with much larger tires. But the diameter of the quick-release is limited, so you can't increase that to get more rigidity.
Then again, most hubs are aluminum. Although this is one of many reasons I don't like radial spoking, it stresses the hub flange more.
Regarding someone saying steel has better elastic stiffness (young's modulus)... tungsten is about 2X as stiff, but yes, not a common engineering material, and it's about 2.5X the density, almost twice the density of LEAD (about the same density as depleted uranium). If you've ever picked up a piece of tungsten, you'll remember it.
Likes For Duragrouch:
Liked 3,933 Times
Another tip - that everybody knows but few do. Lube those heads! I like to take them apart completely, grease the shaft and threads and put liberal grease in the cup and the cross holes for the cam shaft. Enough that grease squeezes out first use. Wipe clean. Clean and redo in 5 or 10 years. Your hands will say thank you. (And a real plus of the internal cam - nobody sees that pile of grease and it goes nowhere. Dirt doesn't get in there either.
And yes, FB is right. External cams can be mechanically just as good. But I doubt I have ever laid eyes on such a pair.
