New wheel, old steel bike. Powerful stroke sends wheel into left chainstay
Quoted: 5793 Post(s)
Liked 2,592 Times
Note the dentated steel faces. Walmart (of all places) had a similar ones for $9.75pr
I guess if you spend for good stuff you get junk, go cheap for quality.
FB
Chain-L site
FB
Chain-L site
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 225 Post(s)
Liked 163 Times
OK, finally back to answer some questions. Sorry for the late response. Work, life, wife, etc.
Someone asked about it still being 126mm. I cold spaced the dropouts using RJ The Bike Guy's method. It comes in right at 130mm now.
I've uploaded two pictures. One of the dropout, one of the skewer end, mainly the side that does move. I can definitely see now, the skewer end has no real gripping mechanism. Smooth as can be. Of course it would allow the wheel to slide to the left.
amilo posted a picture of what I should be looking for. Skewers with teeth. Anyone got a good link to buy one?
Dropout
Small skewer end
Dropout
Small skewer end
Really Old Senior Member
How about the lever end?
Liked 2,592 Times
OK You're holding half your problem in your hand. Note the smooth face, or the shallow dull teeth ( not sure which from the photo). Note also the lack of serious bite marks on the dropout. If you search imaged of vintage bikes, you'll see dropout faces badly chewed up.
As I said, that's only half. The other half is your hubs axle, which seems to be aluminum. The axle itself doesn't matter, but note the smooth aluminum faces, which are trying to gum your frame because they lack the teeth.
So, new vintage skewer. I also recommend treating the axle. I keep a bottle of nail polish into which added some sand. I clean the axle with acetone, then apply the sand paint and let dry.
The reason for treating is that there's play between the axle and skewer, which will allow the axle to creak under load.
Getting bite from both axle and skewer may be "belt and suspenders", but may be absolutely necessary if you climb steep hills.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 225 Post(s)
Liked 163 Times
Link here, if allowed to post
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I am hoping this does the trick.
Liked 2,592 Times
Those should solve it, (assuming the length is right).
If you want to keep the look, try the sandy nail polish hack. depending on your circumstances it should be about free. I made mine with "the wrong shade" and some grit media.
FB
Chain-L site
FB
Chain-L site
Quoted: 225 Post(s)
Liked 163 Times
Just got the skewer yesterday and installed it. It looks perfect with my Pacenti Brevet wheels. As soon as the ice clears and provided my dirt road doesn't melt into a mud quagmire for week, I'll be testing this on some of the local small hills. Hopefully the wheel stays.
Liked 2,592 Times
I can see the new trend now ------ Quagmire bikes.
FB
Chain-L site
FB
Chain-L site
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
RJ's video shows using dropout alignment tools. Did you do that as well as spreading the dropouts?
Do the outer locknuts/endcaps on the hub have any grip? From the photo it doesn't look like it.
I took a look at skewers on Amazon, and I wanted to keep that vintage look. So I found some 130-135mm trainer skewers, which did have the teeth missing from my current skewer.
Lube the cam (inside) with grease or anti-seize, without getting any lube on the clamping faces. Lubing the cam will allow you to get a tighter squeeze.
Quoted: 3514 Post(s)
Liked 2,927 Times
Liked 2,592 Times
Quoted: 1110 Post(s)
Liked 1,204 Times
I got a skewer with my trainer (languishing as it is). It's just a cheaper, less refined version of the other internal cam skewers I have, as far as I can tell.
Like someone said, I think it's provided (a) because I'm not sure that the very common external cam skewer would work with the trainer and (b) if one has a nice looking internal cam skewer, it might get marred up by mounting on the trainer. That's what I always thought anyway. But, I have used that "trainer" skewer as a replacement for one on the bike. Works just the same, only problem is that it's ugly.
But really, has anyone, ever, actually noticed a skewer and thought: ooohhh my oh my, that's one fiiiiinnne skewer! I'm flustered! or Gaak, that's butt u-u-u-ugly, I can't bear to look at it!
Likes For Camilo:
Liked 2,927 Times
Likes For smd4:
Quoted: 225 Post(s)
Liked 163 Times
We're looking to have somewhat decent weather on Sunday this weekend. I'll take this Nishiki out for a spin and crank the pedals a few times to see if the new skewer holds tight.
Quoted: 225 Post(s)
Liked 163 Times
I'd say my polished steel training skewer matches my Pacenti wheels perfectly. Definitely a "ooohhh my oh my, that's one fiiiiinnne skewer!" type of skewer. I even bought a front 100mm matching one.
Likes For friday1970:
Liked 2,592 Times
So, I guess it's safe to assume it solved the wheel slippage problem?
FB
Chain-L site
FB
Chain-L site
Liked 1,204 Times
Unfortunately, I don't have this tool. I can take it to my LBS to ensure the alignment is good. But I will do this only if my new skewer doesn't fix this issue.
Likes For Camilo:
Quoted: 1944 Post(s)
Liked 2,164 Times
A home made alignment tool is very, very easy to make with readily available parts, and easy to use. I made something like this and it worked well when I spread the rear spacing of an older steel bike
How To Make DIY Dropout Alignment Gauge Tools - YouTube
If the dropouts aren’t square the best skewers in the world won’t straighten them.
John
Likes For 70sSanO:
Quoted: 514 Post(s)
Liked 451 Times
Where did I say anything about rebuilding a hub or charging anything?
I've swapped in solid axles for QR simply for security reasons. What's your issue?
Quoted: 514 Post(s)
Liked 451 Times
Riders a lot stronger than you or I have been successfully using closed-cam skewers in horizontal dropouts for over 90 years.
Likes For oldbobcat:
