Pair Shimano 105 Disc Road Calipers with MTB Levers
Quoted: 80 Post(s)
Liked 9 Times
My AC Space Horse frame is set up for flat mount road disc brakes. I have a Mokolo Handle bars (flat bars). I was going to mount Shimano 6100 Deore MTB brakes and levers. But would have used adaptors since the frame is set up for flat mount brakes. I stopped by my local bike shop to pick up couple of bolts and I took the frame in with me to get the correct length. The mechanic did not like the idea of putting adaptors to mount MTB calipers. He suggested I use flat mounts as that is what the frame was intended to do. I explained was planning on using flat bars and need mtb style levers. He said that he had used road disc calipers with MTB levers on several occasions with no issue.
I picked up a set of Shimano 105 flat mount disc calipers and mounted the front caliper on the fork with the adaptor set for 160mm rotor. Super easy. I ordered an adaptor for the rear caliper so I can mount a 160mm on the rear. Just waiting for it to arrive. BTW: The 105 calipers have the hoses attached.
So what hydro MTB levers to I want to pair with these 105 flat mounts that will mount up nice on the Mokolo bar? I assume I should probably stay with Shimano levers since I can use Shimano Mineral oil in the system with no worries. Any brake lever suggestions? Also, will I need to get any fittings to put the 105 hoses on the MTB levers or will the levers come with everything I need?
(BTW: I have a MTB Shimano funnel so I think I can just gravity fill and bleed them).
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
SLX or XT levers that work with 2-piston brake calipers should be fine. It is possible any Shimano levers will work.
Likes For Polaris OBark:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Quoted: 1401 Post(s)
Liked 1,886 Times
as mentioned above - it is possible just about any Shimano levers will work
bike pictured above has BL-M8000 (XT) brake lever assemblies with BR-RS785 (Ultegra) calipers
recommended brake hose is BH90 brake hose - but got lazy and used the existing OEM BH59 hose
braking is outstanding
don’t forget - most (or all ?) of the better / higher end Shimano brake calipers are ‘narrow track’ - use the narrow track brake pads - and should be paired with a narrow track rotor
( bike pictured above has SM-RT86 rotors and J05A-RF brake pads )
can’t recall if the fittings are different on the road shifter / brake lever assemblies and the MTB / straight bar brake lever assemblies … think you gotta be careful there - wrong hose fitting / male end could damage / crack the female end
edit : I believe there might be a difference
brake hose purchased for the bike above (but not used) : SM-BH90-SS
brake hose purchased for another bike with Tiagra road brake / shifter assemblies : SM-BH90-JK-SSR
the brake calipers on both bikes use straight hose caliper connections - as opposed to banjo connectors
hmmmm
Quoted: 80 Post(s)
Liked 9 Times
t2p,
Thank you so much. Yes my 105 calipers have straight connections - they have the hoses attached. I am assuming the hoses are the BH90s since that is what came on them and from what I have seen is what Shimano specifies. I have MT6100 levers. Which I think also uses BH90.
I still am a bit confused by the hose fitting. I will take a look at the 6100 tomorrow to see what I see - not sure I know what I am looking for it to look like to work with the BH90 hose.
I also did not know about wide and narrow track brakes. Good to know. I will make sure I get the narrow track 160s for this setup.
Much appreciate the info!
