Brompton: Mounting adaptor for carrier block
Old 07-08-18, 01:25 PM
  #51
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Liked 118 Times in 99 Posts
Originally Posted by Schwinnsta
The thing a about adding a lug to an aluminum frame is the heat can ruin the heat treatment of the aluminum weakening the frame.
Thanks for the info.
"What's the Difference Between Soldering, Brazing, and Welding?"
https://www.machinedesign.com/fastene...ng-and-welding
So it looks like the more realistic alternative is:
  • Klickfix Caddy adapter
  • Brompton luggage block + jubilee clip/hose clamp
Winfried is offline
Old 07-08-18, 04:49 PM
  #52
BromptonINrio
Stardust
BromptonINrio's Avatar
Bikes: Dahon Curve Sturmey Archer Srf8; Brompton Sturmey Archer Srf8; Brompton M6r
Quoted: 161 Post(s)
Liked 35 Times in 28 Posts
Originally Posted by 2_i
Well, I suggest you try out yourself the advice before you give it to somebody else. For a change I actually tried soldering alu, using both processes there in the market and they work poorly if at all. Do you suggest soldering steel to alu?? Do you want it to hold?? This is just absurd.
its an nonsense statement.
if you read well, you will see im saying its possible to solder aluminion lugs on aluminiun frame.
If you cant make it work or to lazy to find a good profissional you cannot say its impossible
i made atachments of fork for front carrier touring bike and its strong as bull for more 10 years.
Stell to alu? No.. i didn say that...its a crazy assumpsion.
JUST hire a framebuilder to fix and he will know what to do.
it will not ruin heat treatment as tig soldering doesnt heat the pieace itself, but put solder stuff in lug, making it more stronger that before..
BromptonINrio is offline
Old 07-08-18, 05:06 PM
  #53
2_i
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times in 251 Posts
it will not ruin heat treatment as mig soldering doesnt heat the pieace itself, but put solder stuff in lug, making it more stronger that before..
Solder will not hold unless soldered elements are heated. Above all you do not seem to tell apart soldering from welding. A loaded Brompton carrier will not hold on an alu lug. Interesting use of term 'lazy'. I am not looking to learn from this discussion and pull myself out - just wanted to make a point that anybody thinking to follow your advice has second thoughts - this much I hopefully achieved. Bye
P.S. At a reduced max load you can presumably live with an alu lug.
2_i is offline
Old 07-08-18, 06:33 PM
  #54
Abu Mahendra
Bikes: In service - FSIR Spin 3.0, Bannard Sunny minivelo, Dahon Dash Altena folder. Several others in construction or temporarily decommissioned.
Quoted: 897 Post(s)
Liked 17 Times in 17 Posts
Fwiw...
I used the Kickflix caddy in my Korea tour without problems. I mounted it on the seatpost, holding an Ortlieb bag. Granted, I never loaded it beyond maybe 2.5kg of its 7kg rating...
Abu Mahendra is offline
Old 07-08-18, 07:07 PM
  #55
bike.gang.uk
bike.gang.uk's Avatar
Bikes: Brompton H3L, RAF, M3L, Dahon, Giant NRS, GT
Quoted: 51 Post(s)
Liked 16 Times in 11 Posts
On older neobike brompton without lug.
QR and Clamp versions
bike.gang.uk is offline
Old 07-09-18, 03:38 AM
  #56
BromptonINrio
Stardust
Quoted: 161 Post(s)
wow, how can i get one of clamp versions?
Old 07-09-18, 05:42 AM
  #57
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
I'll pass on the brazing option since it would 1) ruin the paint and 2) require finding a professional to perform the same kind of surgery on an aluminum bike.
The QR option looks very interesting, OTOH, but is not currently found on the site:
https://www.bikegang.co.uk/bikeganghut/Brommie-c9803294
If you do manufacture it, it might be a very appealing option for Dahon/Tern/Strida owners as an easy way to use a Brompton bag.
Winfried is offline
Old 07-09-18, 05:59 AM
  #58
bike.gang.uk
Quoted: 51 Post(s)
The clamp and QR version are someone's DIY project, let me check if he plans to produce them.
Old 07-15-18, 05:04 AM
  #59
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
A QR Brompton block would definitely be a great product to stick on any non-Brompton bike.
On the Strida, you can't have it low on the headtube because it prevents folding the bike, but a QR block would be easy to remove when the user does need to fold the bike (although not as easy as simply leaving it permanently, but hey.)
Winfried is offline
Old 02-15-21, 01:17 AM
  #60
Namida12
Using antix-17.4.1
Bikes: Fuji SST 1.0, Chorus equipped Ridley Excalibur, Novara XR, KHS Classic, Basso Tri-Color, 1982 Bianchi Nuova Touring, Blue Max Plateau EX, Heavy Mongoose Hilltopper
Quoted: 8 Post(s)
Liked 4 Times in 2 Posts
This may not work for all bicycles, but seems to be another option: https://www.fantastic4toys.com/produ...-birdy-bicycle
JR
Namida12 is offline
Old 02-15-21, 09:14 AM
  #61
Schwinnsta
Schwinnasaur
Schwinnsta's Avatar
Quoted: 459 Post(s)
Liked 184 Times in 122 Posts
Here is on that looks like it would work for many. I am in the process of making a quick release Brompton luggage block.
Schwinnsta is offline
Old 02-15-21, 11:28 AM
  #62
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
It might prevent the Strida from folding, though, as the two tubes get very close.The only way is to give it a try.
Winfried is offline
Old 02-15-21, 06:59 PM
  #63
biker101
Quoted: 8 Post(s)
Liked 9 Times in 7 Posts
A simple DIY solution, "hacking" a seatpost rack. See:
https://mybikesite.org/#CarrierBlockMount
biker101 is offline
Likes For biker101:
Old 09-19-23, 11:21 AM
  #64
luke1111
Wanted to revive this thread with a few photos of a DIY welded brompton block adapter. For context, this was my first attempt at welding (apart from a quick half hour practice session on scrap metal). This was done with a cheap flux core welder.
imgur[dot]com/a/0xT1ha1
luke1111 is offline
Old 09-19-23, 01:41 PM
  #65
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
https://imgur.com/a/0xT1ha1
Winfried is offline
Old 09-20-23, 12:49 AM
  #66
2_i
Quoted: 840 Post(s)
I am not sure you are selling me on this. Maybe there was a room there for more practice .
2_i is offline
Old 09-20-23, 10:04 AM
  #67
luke1111
Yeah definitely not the prettiest welds (it was my first time welding!), but I think they should hold the 10kg limit many of the racks recommend.
Hard to get a photo of the inside of the tube, but there is a visible sign that the heat penetrated into the metal which is a good sign that the weld was effective. It doesn't take a ton of welding to create the kind of strength needed for a rack -- different story for structural frame welds.
Not trying to convince anyone to do it, just wanted to share my experience in case anyone else wants to venture down this path!
Happy cycling ya'll
luke1111 is offline
Old 09-20-23, 10:29 AM
  #68
Schwinnsta
Schwinnasaur
Schwinnsta's Avatar
Quoted: 459 Post(s)
The problem is that if this is welded as opposed to brazed, then you have lost the heat treatment of the metal around the area of the weld and thus weakened that area of the head tube.
Old 01-09-24, 04:29 PM
  #69
luke1111
Just wanted to follow up now that I've run a few real-world tests. I've been able to haul 10kg of groceries on my front rack without any issue. Seems like the welds are holding strong!
link to photo : imgur[dot]com/a/zdcgMV5
luke1111 is offline
Old 01-10-24, 02:23 AM
  #70
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
https://imgur.com/a/zdcgMV5
Winfried is offline
Old 02-29-24, 05:50 PM
  #71
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Finally, someone came up with a carrier block that can fit any tube without bothering with a mount base ŕ la Litepro/H&H
Winfried is offline
Likes For Winfried:
Old 03-01-24, 12:58 AM
  #72
Jipe
Quoted: 801 Post(s)
Liked 249 Times in 213 Posts
This way of mounting on the head tube won't work with frames like the Birdy and Zizzo with a big main tube that cover most of the length of the head tube.
My experience from building several own adapter for several bikes is that it will probably rotate around the head tube and won't be stiff enough to avoid the bag to wobble.
There was several years ago an adapter for Birdy with steel wires placed more or less like the plastic straps of this one 5but with a bigger spacing to come above and below the thick Birdy main tube) and it wasn't strong enough and tight enough to avoid rotation around the head tube and wobbling of the bag (it also eventually broke during the ride).
The tilt to the front might also be a problem. To reduce the cantilever effect, the bag frame should be tilted to the rear, not to the front (like it is the case with some of the Litepro adapters).
I definitely wouldn't use such kind of adapter!
Jipe is online now
Likes For Jipe:
Old 03-01-24, 04:29 AM
  #73
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Since I could return them in case they didn't fit, I ordered the four adapters from Litepro.
Using a digital sliding calliper, the only difference I see is in the external distance between the two flanges (87, 90, 97mm)
If needed, each flange can be turned upside down thanks to the three bolts on the inside, which helps to fit them on bikes that weren't meant for that use.
We order stuff so you don't have toŽ
https://liteprobicycle.com/collections/adapter
Winfried is offline
Old 03-01-24, 07:20 AM
  #74
Jipe
Quoted: 801 Post(s)
There is a major other difference: the two first 51-98mm and for Bird 2 3 tilt the bag frame to the front (bigger distance from the stem) what increases the cantilever effect while the third one K3 plus tilt the bag frame to the rear (closer to the stem) which is what also happen when the bloc is mounted on the Brompton. Maybe its possible to mount the vertical part of the adapter upside down to have the same rear tilt with the two first types?
To minimize the cantilever effect, the bag frame should be as close as possible to the stem.
The H&H adapter place the bag frame very close to the stem.
For the Birdy, the head tube bearings are different on the Birdy 2 (external) and Birdy 3 (semi integrated), the adapter must be different to take care of this (like for H&H that has two different adapter one for Birdy 3, another one for Birdy 2 (and recently one for the Birdy New Classic).
The Litepro adapter for Birdy on the Birdy create steering wobble even with relatively low bag load that doesn't happen with the H&H adapter (unless you overload he bag), its a bad design!
Jipe is online now
Old 03-01-24, 08:58 AM
  #75
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Yes, you can just install the adapter upside down.
The Litepro for Birdy is available in two versions, to match 2/3.
As for the bad design, I'll report back after giving it a try.
Winfried is offline
