Is this rim unsafe to ride?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Likes For Cyclist0108:
Occam's Rotor
Liked 2,331 Times
Occam's Rotor
Liked 2,331 Times
Quoted: 18369 Post(s)
Liked 4,507 Times
Bikeforums is a good place to come then.
They are usually exactly opposite the valve stem.
Is it possible that older rims would be pinned, and newer ones welded? Fakes?
aged to perfection
Quoted: 835 Post(s)
Liked 1,252 Times
I was talking to a good friend yesterday who is an authority on the topic of bike wheels and rims.
He mentioned this very thing ! Specifically in the earlier HED rims. Said it usually was caused by over-inflation. pump tires up to 130 psi, a couple inflation cycles to very high pressure, these cracks start to appear.
I think this is an excellent case study regarding life cycle expectations we have of very light equipment. Despite the high cost, it may not last forever, and certainly will not absorb crash damage or other misuse / neglect.
don't ride it.
Mark Petry
Bainbridge Island, WA USA
don't ride it.
Mark Petry
Likes For mpetry912:
Quoted: 5224 Post(s)
Liked 3,581 Times
Likes For rumrunn6:
Occam's Rotor
Liked 2,331 Times
Occam's Rotor
Liked 2,331 Times
don't ride it.
Mark Petry
don't ride it.
Mark Petry
I don't think he (or I) over-inflate by any stretch of the imagination, but I get the point about the fragility.
Liked 4,507 Times
There is also a bike coop within a couple of blocks of Universal Cycles. And, I think that one buys and sells. Sometimes a bit high on the prices, but they typically have a good selection.
Likes For CliffordK:
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Rim ok/not ok
Am I off base here? Deflate, and put a pair of hands on it. if still unsure take the tire tube and rim tape and try again. Does it feel/look solidly in one piece? Then if not sure do the other recommendations...
I mean this isn't mysterious like carbon apparently can be. Or am I wrong?
Regards, Eric
Don't shops/mfrs worry about liability and thus often just say "replace"?
Regards, Eric
Likes For Last ride 76:
Likes For trailangel:
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Regards, Eric
Regards, Eric
The stupider the internet gets, the more the chattering class relies on it.
Occam's Rotor
Liked 2,331 Times
If you don't want to bother reading the thread, that's perfectly fine, but why waste your time typing if you have nothing to contribute?
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Rims sometimes have a seam that's noticeable. It's rarely problem unless it catches the brake pades which would cause them to wear quickly. I see a Disc brake rotor, so it's not an issue here.
So, I suspect it's just fine to ride, but as already determined, first hand inspection by experienced eyes is recommended.
Rim failure is rare, and is not catastrophic the way fork or frame failure is.
Likes For Homebrew01:
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
You might want to get your glasses checked. I stated in the O.P. I told him to have it checked in a bike shop, and several others posting here said the same thing.
The un-intended irony is kind of dimly amusing:
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
WTH wgscott? You ask for advice or opinion on the safety of the wheel, and then get offended when members give you what was asked for. Don't bother posting if you don't want you asked for.
Occam's Rotor
Liked 2,331 Times
To whatever degree you wish to read "offended" into this, I was a bit surprised that the post in question ignored all of the suggestions (including mine) for a first-hand inspection by a bicycle mechanic/shop. There were at least six instances of that.
Someone comes along at the end and clearly has read nothing and offers nothing, apart from insulting everyone who took the time and made the effort to offer sincere (and from my point of view, very much-appreciated, advice). I simply corrected his misinformation. I didn't pass judgement. Some people need to convince themselves that everyone else is a snowflake in order to give their lives some meaning (presumably the motivation for the troll sig line).
Super Moderator
Liked 927 Times
The only non-crash rim failures I've ever had were from cracking at the spoke nipples. And that just causes the rim to slowly go out of true.
Of all the things on a bike that can break, rims are just about the least risky.
Occam's Rotor
Liked 2,331 Times
FWIW I'm going to get him a new wheel (or set) for x-mas.
Please feel free to close the thread.
Super Moderator
Liked 927 Times
Thread closed
