How do I remove this BB?
I hope to have my old Peugeot powder coated soon so I am gathering tools and reading how to articles so I can strip the frame and fork. I have the tool to remove the cranks and headset remover and press, but I‘m not sure about the bottom bracket. From the picture I provide, how does it come apart? I can take the otherwise stripped frame to my LBS and have them remove the BB, but I would rather do it myself. Thanks for your help!
Likes For jiangshi:
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Is that the dreaded plastic BB? If so, you have one shot at using the correct tools, or else it will make a very unpleasant, determined mess that will defy nearly all efforts to remove it. Please don't ask how I would know this.
Quoted: 1639 Post(s)
Liked 828 Times
Maybe the question is, is it French or Swiss threaded?...... So the OP will know which way to turn the spanners...
It actually looks like there could be enough thread showing at the cup face to figure it out.
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
It's your bike OP but the paint around that bottom bracket looks pristine. I like painting my fugly bikes.
Quoted: 237 Post(s)
Liked 83 Times
Channel locks are easier if you plan on mangling it anyways. You don't even really need the pin spanner to remove if the cup isn't seized. The pin spanner is more for holding it in proper adjustment while tightening the locknut. Loosen the locknut, and you should be able to remove it with your fingers.
Also NDS is always a standard RH thread and I'm pretty sure it's a later internally brazed Peugeot so it's BSA and the cup says 1.37
Thanks everyone, I understand the bb now thanks to you all. I’m going to remove it myself and maybe go back with a cartridge type bb.
Likes For lhill:
Quoted: 796 Post(s)
Liked 522 Times
RJ may also have a video on this BB too
Quoted: 4510 Post(s)
Liked 6,377 Times
These can be challenging and a very good skill to learn even if you don't use it again on this.
Liked 828 Times
Yah! Please don't just waste the bottom bracket that might still be good and serviceable, it made it this far and long. You wouldn't want to be the one to senselessly kill it? Take it to a bike shop and they might lend you the right tools to take it off, right there, without mangling it all up.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Campy NR / SR forever
Don't hack it up with a hammer and screwdriver. Get the right tools so you can work on it again.
Quoted: 3464 Post(s)
Liked 2,828 Times
Be sure to remove the drive side crank arm first.
the bright lock ring will remove anti clockwise. Almost always holding the adjustable cup is not needed for removal but will be for installation.
the fixed cup ... it is a later bike it appears could be Regular or LH thread. Old French was regular RH threading 35x1, later... Swiss LH 35x1 or English 1.370 x 24 LH.
the fixed cup may be best a bike shop task if you do not have the tools.
j
j
Quoted: 237 Post(s)
Liked 83 Times
It's just a lowly BSA lockring. It's not even the BB cup. It's hardly the end of the world if it gets a bit marred, or a couple notches get screwed up. It's not some irreplaceable piece of history or like it would get damaged beyond the point of usability. It's not even in a highly visible place.
Given the internal fillets and what appears to be a 1.37 marking on the cup, it's almost certainly BSA.
I have ordered the Park Tools lock ring spanner and pin spanner so I will take it out carefully and reuse it if all goes well. Thanks again for your help!
Liked 6,377 Times
This can make good practice when the stakes are low to acquire the tools, learn to use them and get it right.
Likes For merziac:
Liked 2,828 Times
I think this thread was for garryg to send a message in secret code.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBxMQEBEREBMWFhUVEhcWEhUWFRcZEhkVFxIWHRgYGBUYHSggGBolGxgYITEjJSkrLjEuGB8zODMsNygtLisBCgoKDg0O FQ8PFS0ZFxkrLSsrLS0rKzctLSs3Ky0rLS0tKzctKy0rLSstKysrNystKysrNysrKysrKy0tKysrK//AABEIAOAA4AMBIgACEQEDEQH/xAAbAAEAAgMBAQAAAAAAAAAAAAAABQYCAwQBB//EADsQAAIBAgMFBQYFAwMFAAAAAAABAgMRBAUhEjFBUWEGMnGBkRMiQlKhwXKCsdHwU2LCsuHxFSMzQ5L/xAAXAQEBAQEAAAAAAAAAAAAAAAAAAQID/8QAFhEBAQEAAAAAAAAAAAAAAAAAAAER/9oADAMBAAIRAxEAPwD7iAAAAAAAAAAAAAAAAAAAAAAAAAAABw5nm1LDr/uS9592C1m/Bcur0A7gUvGdpq03anakvKU/V6L0I6Vac+/OcvGba9NxNXH0S56fOlQjyXodeHlKPcnKPhJ29Bq4vQK9gs5mtKnvLnopfsydoV4zjtRd1/OBWcbAAAAAAAAAAAAAAAAAAAAAAAAADRjcVGjTnVm7RhFyfl9wIvtHniw6VOnZ1ZK6vujH5n9lxKU5tycpNylLWUn3m/56GuVedWcq1TvVHd67lwj4JaG2KI3IxSZK4fLpabWl9yteT/KiUyXJ7b+98T+S/Bf3foWPD4eMFaK8XxfiwlqtUcmk/hl52X0N3/RpLcn6plkAxNVDEUZU9JJpHdlE3F3vo2klz15dCUzbBe2p7N90lK17Jtbk+l7PyPcFgVD3pPalbfwXSK4IYuuwAFZAAAAAAAAAAA AAAAAAAAAAApnbnH7coYWO5WqVv8I/5eSLVmOMjQpTqz7sItvm+SXVuy8z5rTlKbnVqd+o3KXi+HglZeQWRlTRKZHQUqqe/ZV0ut7L6tEbe5K9m6yjW14pfRpkbXahSUIpLzfN8WbACuYAAAAAAAAAAAAAAAAAAAAAAAAAAABHZ7mscLSc3rJ6U4cZS4Lw4t8gK 522x3tKkMNF+7C06vWT7kfJe95xINaGFPabcpvanJuU3zbevl9jMjcZKNz2lJxkmnqndGG3oSmV5dt2nK7V7Rjxk/subCrbk2KdSnFtb43Xgd5y4LDbCvLvNa23JLcl0OormAAAAAAAAAAAAAAAAAAAAAAAAAEdnWbwwsLy1lLSnBd6T+y5sDPN81p4Wn 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 mUpSes5Sk915Sba9TryjCe1qa92Or68l4tkEt2cylytJ73qv7Y831fAu2HoRhFRirJfy7NOX4fYhr3nrL7LwR1FjFoACoAAAAAAA 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 AAAAAAAAAAAAAAHko3VmegDgxeXqfC/naX/1x8yKrZTbjJeMb/WJZATF1E5DhHBSbVtWo33tX3vx09CWAKgAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/9k=[/img]you could also use a hammer and screwdriver and pin punch. usually things are not tight
Ben
Quoted: 237 Post(s)
Liked 83 Times
Maybe so, not the point, there's value in learning the drill for when it is a valuable specimen that you do want to save with the least amount of damage that doesn't cooperate.
Liked 6,377 Times
True that, the best tool in the world doesn't do a damn thing until you pick it up and wield it to do your bidding.
I have a 45 year old Sugino that never fails me, ever. It has a wrap around spring quality about it that when executed properly grabs the ring and makes short work of it no matter how tight, stuck or seized it is.
The right tool, in the right hands.........
Quoted: 147 Post(s)
Liked 331 Times
Whoa i really did not mean for my secret message to get posted, Also do not advocate hammering away at bb, but a little tap is often all that is needed.
You can just about completely take apart a bike with a hammer, a few screwdrivers, and a pair of vice grips, but I wouldn't recommend it.
Quoted: 1372 Post(s)
Liked 1,751 Times
This article on How To Rebuild a Vintage Bottom Bracket might prove helpful...
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3880 Post(s)
Liked 6,467 Times
