Merida Reacto 300 front derailleur movement
Hi, got a problem that my FD moves side to side, can't be tightened up.
Works fine via the shifter, but the movement is where its attached to the frame.
Cheers
Pete
Cheers
Pete
Quoted: 2026 Post(s)
Liked 1,096 Times
How is it attached to the frame? A clamp or a braze-on tab?
Liked 1,096 Times
Liked 1,096 Times
I wonder if the bolt holding the fd to the tab is too long and bottoming out before the derailleur is firmly clamped. Perhaps a washer under to bolt head would fix the problem.
TimothyH
Road Cycling
10
01-03-16 09:55 PM
Barrettscv
Bicycle Mechanics
6
05-22-11 08:17 AM
