Can I get some help with this bike?
Rhapsodic Laviathan
First IDGAF about "oh it's a ancient bso" and other drivel. I can work magic on these and get them to be decent, capable machines for at the very least a daily or sometimey ride.
I came across a Murray Koza or Kozo and it is interesting for a most likely cheap BSO and wondering if anybody knows anything about them? It's weird to me because it has an ashtabula crank, but it's 21 speeds, aluminum wheels, trigger shifters and internal cable routing. Never seen such in this class of bike and can't find anything about it online.
I'm building it up for my g/f and it needs the general crap; trigger shifters, which I have, new calipers, grips, levers.
Quoted: 1324 Post(s)
Liked 927 Times
No need to cuss.
Never heard of it and can't find anything online either.
A lot of inexpensive bikes came with Ashtabula cranks and alloy wheels although the spokes are usually not stainless and will rust after much exposure to the elements. If properly set up and adjusted most bikes can be good for casual rides or short distance rides.
What kind of brake calipers does this bike have - cantilever or V-brake of other?
Cheers
Cheers
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Nothing found here, either. The parts you're seeing on it might not be original equipment. Someone might already have worked magic on it.
Rhapsodic Laviathan
No need to cuss.
Cheers
Cheers
Expired Member
Quoted: 3674 Post(s)
Liked 5,438 Times
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Do you have a serial number? Might be able to narrow it down.
Can you explain why you seem to be sure only of the first three letters of the model name? I ask just because that could be a clue.
There's an old bike store in Chicago called Kozy's. Is it possible it was some sort of special label deal with them? Murray did a lot of stuff with different badges.
Pics?
Pics?
Liked 2,446 Times
Is it possible that the sticker/decal on the bike has been altered to look like Kozo or Koza? Murray made the Baja, probably made a bazillion of them, so the odds are it's one of those.
Quoted: 1572 Post(s)
Liked 643 Times
What is your objective? Is it a hobby for you or is it a gift for the girl friend?
One piece crank. That by itself says "cheap bike" to me. It sounds to me like you're trying to convert a cheap old bike into an expensive old bike that has a few new replacement parts. If that's how you choose to spend your time that's one thing but, I'd think the same amount of money would buy a more impressive present for the GF.
Tragically Ignorant
Liked 9,098 Times
You're seriously off-topic just to start an argument.
Likes For livedarklions:
Expired Member
Liked 5,438 Times
OP may as well ask for the thread to be closed. Apparently nobody has any info (whatever it might be) about that particular Murray. The whole BSO issue is the elephant in the corner, just waiting to squat down on this thread. Or just wait and see....
Likes For shelbyfv:
Liked 2,446 Times
OP has enough posts to upload a photo or two, if he's serious about getting some help.
Likes For thumpism:
Rhapsodic Laviathan
The only pic I took of it before I started wrapping it with tape. I forgot it was a Huffy, not a Murray, it's put up until I can make workspace for it.
Expired Member
Liked 5,438 Times
Is that one of the titanium Huffy's, built by Litespeed?
Rhapsodic Laviathan
Rhapsodic Laviathan
Passista
Quoted: 868 Post(s)
Liked 721 Times
It's worse than I expected .
Seriously, I don't know about that particular bike, but I've seen and worked on a lot of similar bikes - 1 piece cranks, 7sp freewheels, cheap alloy rims - but usually with 1 chainring and cheap V-brakes. Nothing wrong with them as long as you don't use them much. If you ride them 1 or 2 times a week to the grocery store, they are OK.
Now - don't get me wrong, I commend you for making a usable bike for your GF. But it's got a one inch steerer tube, super long reach caliper brakes, a one piece crank, no derailleur hanger built into the frame. There's nothing proprietary here, anything can be replaced with generic components. I do find the internal cable routing interesting, and it's a plus that the bike has aluminum rims.
There was a brief time in the early 80s with America's first international successes in bicycle racing where Serotta made some frames that were badged as Huffys for team 7-11. This isn't one of them.
So I really don't understand your question(s) in your OP. Unless you're trying to restore the bike to it's period-correct OEM specs, additional details aren't really going to tell you anything you need to know to get this bike running.
And make sure you know what you're doing before you pull that cable housing out of the frame!
Liked 2,446 Times
Liked 643 Times
What do the tires look like? Do they have cracks or dry rot? I'm betting the size is 26 X 1 3/8. There is a common 26 X 1 3/8 size and a few other, hard to find, 26 X 1 3/8 sizes. The bead seat diameters don't mix and match.
I can see why the GF likes the bike, I like the colors too.
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
Jax, if you're going to rework that thing, please replace the brakes. Those stamped-sheetmetal calipers scare the daylights out of me. I'd be afraid of them folding up in a panic stop.
Other than that, yeah, it's pretty low grade ... one dead giveaway is the stamped sheetmetal rear dropouts, probably resistance-welded into the stays. And what on Earth is that front hub?
Anyway, good luck.
Anyway, good luck.
Cycleway town
That is the most cheaply-made frame I have ever seen in my life. As a working bike it wouldn't be worth one hour of the minimum wage.
I don't understand why anyone would save that, over a better scrap bike. There are no brake mounts on it, it can't take welding as it's cheap heat-treated steel, so it can't accept good brakes.
Expired Member
Liked 5,438 Times
I haven't spent a lot of time working on BSOs but the time I did spend was less than satisfying. It's just no fun to work on junk. What makes this sort of thread even more perplexing is our CL has lots of legit hybrids and HT MTBs and they are cheap. Often under $100!
Rhapsodic Laviathan
It's a generic piece of crap Huffy.
Rhapsodic Laviathan
Anyway, good luck.
Anyway, good luck.
Second is alloy wheels- which it already has.
Non knobby tires- which it has
Ditching the gripshifts(which it doesn't have) for either thumbies or trigger shifters.
Replacing RD with one of those black shimano ones you find on walmart bikes, or just something I know will adjust and shift.
That's pretty much it. Not much effort or money. I have on one instance swapped a fork on one with a fork with vbrake/canti mounts. I already had the fork.
