weird question, are some tubes faster than others?
Quoted: 161 Post(s)
Liked 267 Times
My mind says no, but my legs tell me something different. I had 26x1.5 tubes in my 650bx42mm tires and then went to 27.5x1.75 tubes. At the same PSI, the larger tubes felt comfier but slightly slower. I'm not trying to overthink things or nitpick every little detail, mainly just curious.
Quoted: 626 Post(s)
Liked 701 Times
There are many claims (especially latex vs. butyl tubes). There may be research out there that can verify some of the claims, but I go for inexpensive, since I'm not a speed demon.
Quoted: 20810 Post(s)
Liked 9,456 Times
Yes, some tubes are faster than others. Latex and Schwalbe's schmancy new tubes are ver fast.
Quoted: 6196 Post(s)
Liked 4,810 Times
Anecdotal, but anecdotal counts if you can get some data recorded and repeatable results.
For one, your tubes are probably a different weight. More mass equals more energy to accelerate. Also there will be some change in rolling resistance depending on how stretched the tube is inside the tire. Or perhaps if the larger tube winds up being wadded up and you just didn't notice the bumpy ride.
Different brand tubes might have been different compounds. Butyl rubber is not simply one exact recipe.... I think. Slight changes to the ingredients and how they are processed to make the butyl rubber or any tube material will make a difference for the rolling resistance. As well, Latex vs Butyl vs ?? It's all going to roll different.
But if you didn't control everything else like PSI, same tire at the same wear level, road surface and even your own increasing or decreasing fitness, then well you know, could be an infinite number of reasons for your perceptions.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
There are comparisons of same tire and rim running tubeless versus, latex, thin butyl and standard butyl tubes. IIRC, tubeless is best, with latex usually adding a bit over 1W, thin butyl maybe 3W and standard butyl more like 5W. It will vary with tire type and wheel size.
So, yeah, it’s there and measurable. However, latex tubes lose air faster and both latex and thin butyl tubes are more vulnerable to puncture. So, standard butyl tubes still have a place when convenience and reliability are a factor. OTOH, tubeless is fastest, assuming you have things sorted and working,
Otto
Otto
Quoted: 9653 Post(s)
Liked 6,365 Times
Otto
Otto
Likes For Mojo31:
Liked 4,810 Times
Though only ride road bikes, I have to wonder if the 1 or 2 watts difference that tubeless versions of the same tire provide is material for me. For others that ride really far, long and often, maybe.
From what I've read, tubeless became a hit with the off-road crowd for puncture resistance. No so much for rolling resistance.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Why use a 26" tube in a 650b wheel? I guess in an emergency?
Ill pile on and confirm that tubes vary and will affect power/speed.
Liked 9,456 Times
Likes For WhyFi:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2584 Post(s)
Liked 5,642 Times
The less the rotating mass, the faster you will go. It makes sense to get the smallest, lightest tubes. This is true for all vehicles which use tires.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 1109 Post(s)
Liked 1,200 Times
But maybe the type of riding the article was talking about needs to be considered. Didn't see any road bikes in the pic's.
I wonder if the wattage difference makes any difference except in competition where success is measured in seconds per km (or 1.61 seconds per mi) or even seconds per 100 mile+ race. I don't think that even long distance recreational riders would notice the difference unless they're competing.
If any tube or tire contributes to comfort or convenience, that's a selling point to me. Haven't seen documentation of enough of a difference for the type of recreational road riding I do, yet.
Likes For Atlas Shrugged:
Quoted: 4806 Post(s)
Liked 3,931 Times
A trick that is as old as I am to getting lighter and better rolling wheels is to use undersized tubes. Same model tube but one width narrower - that much lighter plus the highly stretched tube is effectively thinner and more supple. It is easy to feel the difference. Drawbacks - the thinner tube doesn't hold air as well, may be less reliable and may have issues after patching. Plus (besides fast) - easier to mount tire.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
The SLX tubes on my DeRosa seem fastest. But totally subjective and without data or links to a study.
22mm tubulars also always seem faster on good pavement.
New chain needed with Spring maintenance
Liked 1,200 Times
As for the chain: less rotating mass and less wind resistance - leave it as-is.
Likes For Camilo:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
The tubes on most of these guys’ bikes are way faster than mine.
Genesis 49:16-17
Genesis 49:16-17
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Quoted: 1743 Post(s)
Liked 1,281 Times
When people test the same tire, Vittoria latex and tubeless tend to perform pretty similarly, with the outcome depending on how generous the sealant fill is. A dry tubeless tire probably slightly beats latex, although this is obviously not an attractive setup. Michelin latex tubes tend to test slower than Vittoria.
Liked 1,281 Times
Their methods are nonsense. The tubed clincher they used is a less performance-oriented tire than the tubeless tire.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
The Placebo Effect with these types of "tests" are strong. I wonder what the results would be if one didn't know what tubes were in the tires. Tublito's are definitely the fastest.
Aerocoach has some good articles on the issue.
This one explains the issue of tubeless sealant, and in the "TIRE AND SEALANT" tab it says that in their testing, ~30ml of sealant was pretty similar in performance to a latex tube.
This article compares different inner tubes.
Here's some accumulated test results.
Likes For HTupolev:
Liked 1,281 Times
