Low pressure tubeless, rolling resistance holy grail?
Anyone switched from high pressure tires to lower pressure tubeless with similar rolling resistance? Most specifically any increase in comfort?
Quoted: 6972 Post(s)
Liked 10,969 Times
Yes, and yes.
Likes For Koyote:
Quoted: 2333 Post(s)
Liked 2,097 Times
Q1. no/yes
Q2. Yes/No
Q2. Yes/No
Quoted: 20810 Post(s)
Liked 9,456 Times
I've been running modern 28s on wide, hookless rims at <60psi for a couple years. Wouldn't go back.
Likes For WhyFi:
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
I used to run 23s at 105ish, and then moved to 25s at 90-95ish. I now run 28/29s (these are all true measured sizes) at 75F/80R. I go as low as 70 but beyond that, they definitely FEEL more sluggish when accelerating especially. I'm quite comfy at 75-80 and my times on segments are similar so that is where I am. If the roads are rougher, I'll drop to 70/70. If I went to 30-32, I'd run 60-65. I also have used (I'm 176 lbs bodyweight) a couple of apps to determine optimal PSI and I'm close to those as well.
Likes For Chandne:
I use the pressure calculator at zipp.com. It was spot on with 19mm hooked rims and 28mm tires, but recommended only 52 psi front with 23mm hookless rims and 30mm tires. I ran that pressure for a few rides, but it felt too squishy for me, so I added 5 psi. It's important to have an accurate pressure gauge. Many aren't. Very happy with lower pressure tubeless.
Likes For DaveSSS:
Liked 2,097 Times
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
The speed and rolling is the same (or slightly changed, I can't tell) but the comfort is greatly improved.
Likes For vespasianus:
Quoted: 1461 Post(s)
Liked 1,486 Times
7-8 years ago I was running 23s with tubes at 110psi on 16mm i.d. hooked rims.
Today I'm running 28s without tubes on 23mm i.d. hookless wheels at 60psi.
I have no idea what the rolling resistance situation is, but I'm faster now than I was then. Also more comfy.
Likes For msu2001la:
Quoted: 406 Post(s)
Liked 389 Times
Quoted: 1975 Post(s)
Liked 232 Times
My bad. I wrongly assumed the implication that was that switching to tubeless let you drop the pressure 30psi by itself. The correct pressure between tubes and tubeless shouldn't differ much
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
I agree, I’m faster now on 28s running at 55/58 than I was on 23 running 100+ 8 years ago.
I was also 15 pounds lighter then and likely in better cardiovascular condition. I’m actually considering going even a little bigger.
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
This is me almost exactly. My old bike has 700x23's at 110 or higher I'm running 32's at around 70-80.Now I'm faster and more comfortable. My new build is old school and wont take wide tires so I'm running 700x25's tubed at 90-100. A fair compromise but not nearly as nice as the 700 x 32's.
Quoted: 406 Post(s)
Liked 389 Times
In some ways it can. I would never have gotten away with running 80 PSI in my tubed tires without getting a flat. With the tubeless set up, I can.
Liked 232 Times
It gives you a little buffer from pinch flats but the psi difference is not that much. Especially if you are running latex tubes which already are more pinch flat resistant
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,646 Times
These two sites are very helpful when figuring out which tires to buy for low rolling resistance https://www.bicyclerollingresistance.com
And the optimal pressure to run your tires at: https://silca.cc/pages/sppc-form
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
