Transporting Batteries in the Car
Bikes: Surly Long Haul Trucker, Salsa Mukluk, Riese & Muller Supercharger GT Rohloff (Forthcoming)
Quoted: 103 Post(s)
Liked 27 Times
I will be at times carrying my forthcoming Rises and Muller Supercharger GT Rohloff on the back of the car. I do intend to remove the Bosch PowerTubes 625 Wh batteries when I transport the bike will fit either Bosch Pin Covers or Battery Transport Covers in their place on the bike.
My question is in relation to suitable bags to put the batteries in whilst transporting them (will not be used for charging). Any suggestions on a reasonable bag that will take the two batteries?
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
I would not worry about this. I would just leave the batteries in the bike.
The concerns about battery fires mostly apply to low end bikes with a minimal battery management system, and / or crappy chargers.
if you're worried about a battery fire in the car golly you sure would not want to have that battery between your legs while riding !
but you do you
/markp
but you do you
/markp
Likes For mpetry912:
Clark W. Griswold
Quoted: 4371 Post(s)
Liked 4,010 Times
I would put the covers on and take off the batteries only to remove weight from the rack as most hitch racks don't go to the weight needed to carry your bike. As someone who has the same bike I would not mount it with batteries but I also wouldn't worry about the batteries unless they are in a place to get easily damaged. Bosch batteries are pretty much the only batteries I wouldn't worry about all in a car unless it were a super duper hot car and the batteries were directly in the sun on the dashboard which is an odd situation.
If I was really worried I would leave them in a waterproof stuff sack so no air can get in. But I really wouldn't worry. Bosch has one of if not the best BMS' on the market.
Likes For veganbikes:
umm, NO
But of course they are quality batteries.
Taking a battery out for travel sounds like a good idea for an Aussie. They get a little bit of sunshine in that part of the world. Topeak recently came out with a foam battery box. That might be a good fit for the OP.
-SP
Likes For speedy25:
Clark W. Griswold
Liked 4,010 Times
I have some batteries that prove that statement wrong, as well as finding a guy in the UK that rebuilds bad Bosch BMSs. He found that one of the chips is underrated and burns out.
-SP
-SP
I think in the 1000s of Bosch bikes we have sold probably 10 total battery warranties and over half of those were batteries that were left uncharged at or near zero for a long time and wouldn't start back up. The rest were oddities for sure but never anything unsafe. I think one years ago had a bad cell and the BMS shut down the whole thing to prevent an issue. Not saying it isn't possible but it is few and far between.
Quoted: 103 Post(s)
Liked 27 Times
but you do you
/markp
but you do you
/markp
Fire? I do not believe I said anything about fire or worrying about it, but each to their own.
Thanks anyway for your input.
Likes For Aushiker:
Quoted: 103 Post(s)
Liked 27 Times
Thanks for the heads-up. I will look out for these boxes. Sounds like they may do the trick.
Quoted: 103 Post(s)
Liked 27 Times
I am worried about them moving around in the back of the car (Subura Forrester) hence why I was looking for a bag to provide some protection. The Topeak bag might be an option. I have also seen Fahrer bags which might to the trick. Actually a sports bag with some padding would probably work now that I think about it.
Clark W. Griswold
Liked 4,010 Times
Thanks for confirming my thinking. Do you use a cover when you remove the batteries?
For car movement a bag can help as you could secure that or even something like a Eurocrate could work as they are a bit longer.
Quoted: 680 Post(s)
Liked 949 Times
dont worry about pin cover. I have put over 8000 miles on my trek with the external battery mount and it's exposed to the elements 99% of the time without a battery. works fine every time. worse case you would need some contact cleaner one every few years. I ride in all weather with lots of rain. Now my nyon mounts needed some cleaner sealer on the pins for the first time on 2 or more years.
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
by all means use some silicone grease on the electrical contacts.
corrosion inhibitor if nothing else
/markp
/markp
