Q Factor
Q Factor
What is a good Q factor.?
On my Mercian Audax bike,the distance between the inside face of the cranks is 150mm.Is this excessive?
Quoted: 12197 Post(s)
Liked 1,497 Times
Hi,
that is kinda like asking what a good shoe size is. Depends on your hips. If it's too narrow, you can run into trouble. Personally, I like it wide, so I would kick up a fuss. A small Q was traditionally considered a good thing. But having suffered on a bike like that; I came to disagree. I see it as part of the fit of the bike.
Quoted: 19 Post(s)
Liked 7 Times
Small Q was the secret of Greame Obree's hr record bikie (the steel Superman position one.) It can greaty improve aerodynamics. The comfort part is a matter of hip width. Most modern cranks tend to be on the wide side.
Weasel Amongst the Snakes
Originally posted by MichaelW
...It can greaty improve aerodynamics. The comfort part is a matter of hip width...
Now that I think of it, I may need to readdress my cleat adjustments since I have changed from a triple crank setup to a double. :confused:
hello
Generally speaking, compared to road bikes, MTBs have wider Q factors. I guess it all depends on crank design. You can't simply install a different length spindle in hopes of altering your Q factor......then your chainline will be screwed.
Don't Believe the Hype
Bikes: 1999 Steelman SR525, 2002 Lightspeed Ultimate, 1988 Trek 830, 2008 Scott Addict
Quoted: 21 Post(s)
the smaller Q-factor is a reason why the campy camp loves their stuff over shimano. the campy cranks have a narrower...what would you call it...gap? space?
Liked 1,497 Times
Q, the gap is called the Q.
