I have the leather, now need a pattern for non-aero hoods
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,844 Times
Universal brake levers with the large barrel adjusters on an early 70s bike.
Replacements from Rustines.fr are newly available, but expensive.
I can place the leather piece around the existing hoods (which will stay in place) and approximate, then trim as needed. This seems primitive.
Should I make a pattern from thin vinyl using the trial and adjust method??? I would prefer a more precise method.
The leather is supple and is from leather upholstery samples. Sound OK? I intend to put the leather over partially dried out hoods, so the leather will not have to provide the 'padding' of a rubber hood.
Freewheel Medic
Quoted: 1455 Post(s)
Liked 2,197 Times
When I've made hoods, there is a bit and trail and error involved. Turning a two dimensional piece of leather into a three dimensional object can be difficult for those of us who don't do this sort of work on a regular basis, but it can be accomplished and with satisfaction.
I made mine for Weinmann/DiaCompe levers. I worked on a paper pattern and then kept experimenting with the leather. The hardest part was the front top which wraps around the "nose" or where the cable emerges.
I over cut in this area. Once I felt good about the main portion of the body, I then trimmed the ends to meet in the center before adding the holes for lacing or stitching the seam.
Best of luck on your project!
Bob
Bob
Veteran, Pacifist
Liked 4,844 Times
Thanks @pastorbobnlnh - exactly as I plan to do mine. My leather piece may be a bit thicker - hard to tell from pic, but thinner might be better as I hope to leave the rubber hood in place.
edit: It's worth a try to save approx $75. Can always order new replacements, but hoping the product makes US distribution soon, maybe a price reduction too.
www.rustines.fr
www.rustines.fr
If your lever shape is anything like the Suntour Superbe, I can send you the pattern I came up with. I pretty much went through the same steps pastorbobnlnh described, but used 4oz veg tanned leather. Wetting the leather helps keep the shape while you are forming it around the lever body.
Quoted: 835 Post(s)
Liked 2,141 Times
Quoted: 835 Post(s)
Liked 2,141 Times
De nada. No habla español.
Note that the description indicates they are compatible with Model S1, 68, 77, and 125 Universal brake levers.
Btw, this old thread might be of interest. Sadly, many of the original photobucket links are dead. I'm not sure if @rootboy is still active on this forum, but he might be the one to weigh in on a leather brake hood pattern.
https://www.bikeforums.net/classic-v...d-project.html
Veteran, Pacifist
Liked 4,844 Times
Here's the velobase pic of Universal levers Mod 61. The production start date is 1961 - ???. Mine have a slightly different barrel adjuster on the top with a separate rubber cover, so likely a minor change by the 1971/72 model year.
Here is the Rustines product that works for me. 47euro + shipping. Plus shut down for Aug (mostly).
I really need only the barrel adjusters and rubber covers at this time. I have a good pair of Universal lever hoods.
Veteran, Pacifist
Liked 4,844 Times
Freewheel Medic
Liked 2,197 Times
Wildwood, if those are the hoods you plan to cover with your leather, may I ask WHY!?!
I'd think that they'd continue to crumble and fall apart and gradually work their way out from under the leather. You'd end up with loose leather hoods--- eventually. If you want more padding, look for some dense yet thin foam to fit just along the tops between the adjuster and junction with the bars. This is what I'd do to add padding. Just my two cents.
Bob
Bob
Quoted: 1609 Post(s)
Liked 2,216 Times
The difference in design of the Universal lever bodies is the small radius of the top of the body. Ignore the examples of typical breakage when over tightened!
P1000600, on Flickr
The hood has a fairly thick section to create the smaller radius found on the hood. The line between the side and the radius is about where the top of the lever is in the following picture. Perhaps a foam piece could be added under the leather allowing the old hood to be removed.
P1030183, on Flickr
P1000600, on Flickr
P1030183, on Flickr
Quoted: 556 Post(s)
Liked 132 Times
It is what it is.
On the pattern thing, boy... getting that right was the hardest part of my whole project. I must have made 8 or ten different patterns, and even when I got it as close as I could, the hoods always came out a bit different due to the vagaries and grain direction in the leather I was using. veg tanned. But that was with Campy Record brakes. They have a lot more compound curves than Universal levers. I only made mine because vintage Campy rubber hoods were through the roof. Then folks started repopping them, for reasonable prices.
I know the Universal 61 repops are not as common, but they're out there.
Quoted: 556 Post(s)
Liked 132 Times
Leather hoods look cool. But if it were me, I just get these. Complete with adjuster booties.
https://www.ebay.com/itm/Pair-of-Uni...ake+hoods.TRS0
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Okay, the following link is guaranteed to be useless to @Wildwood, but possibly of some use to those wanting to make thick veg-tanned leather hoods for Campagnolo type levers:
https://www.dropbox.com/s/royv1j2jtjasr06/brake%20lever%20hoods.pdf?dl=0
I gave this pattern to @rootboy when he started making leather hoods, and as I recall he found it to be not quite right. But it really comes down to what leather you use, how thick it is, and how it stretches when wet.
Wildwood's project uses upholstery leather, presumably chromium tanned, and, well, it's a different project entirely.
Veteran, Pacifist
Liked 4,844 Times
Yes, totally concur with @rhm. I’m not trying for a permanent replacement of a rubber hood. I’m just shooting for a temporary solution to cover the existing compromised hood until a better or more cost effective option fits my budget. I am using a thinner soft leather, not durable and maybe not even comfortable.
Here’s my 1st attempt at a pattern of the shape of the leather. Next step is to make it out of a thin vinyl, make it better, then cut 2 black ‘hoods’.
multimodal commuter
Liked 574 Times
Wildwood, I have not done this, so I'm treating this strictly as a thought experiment. That said, I think I would do the following....
First, I'd make a conservative guess at what the pattern should be, and I'd cut a couple pieces of the good leather to that shape. Then I'd take one of the leather scraps and experiment with it. Does soaking it in water make it easier to stretch it? Does it discolor it? Does water ruin it? Can i shape it while wet, so it retains that shape when dry?
If I could determine that the leather it can be stretched and shaped while wet, then I'd take a good piece of the same leather and try to shape it the way i want it, and let it dry.
If I was satisfied with the shape, once it's dry, I'd glue it, not stitch it, to the old hood. I'd use contact cement or Barge cement, and overlap the edges so the leather is stuck to itself as well as to the guy rubber. That way if the hood deteriorates (as I expect it will) the leather should hold it together pretty well.
If that doesn't work, I'd cut the old hood off and throw it away; and buy the Rustines hoods.
Veteran, Pacifist
Liked 4,844 Times
ah yes 1/2 the price of rustines. Thanks @rootboy.
Quoted: 2588 Post(s)
Liked 4,825 Times
DD
Training Wheel Enthusiast
Bikes: Peugeot PX-10
Quoted: 5 Post(s)
If the latter, did you also glue them on in addition to stitching? If no glue, do they slide around when in use?
Liked 4,825 Times
DD
Quoted: 5 Post(s)
I might "borrow" some of your design elements...
