Bridgestone mb2 rear brake misalignment
Old 10-01-19, 09:27 PM
Limnoted
I'm installing deore v brakes on a 1988 Bridgestone mb2. The front brakes installed fine. On the rear, the pin on the v brakes that is inserted into the frame to set spring tension does not align with the hole in the frame. It's misaligned by a mm or two. This is my first v brake setup, could be missing something obvious. I definitely have rear brakes. Also tried installing a front brake in the rear, with the same misalignment. Not sure if this is an issue with standards that have changed over the years? Strange that the front pins insert perfectly.
Limnoted is offline
Old 10-02-19, 10:00 AM
steelrider58
NO LONGER A BF USER
Quoted: 21 Post(s)
Liked 25 Times in 12 Posts
Did the old cantis have the same problem?
...5th post...Five to go...Before then, you see no photo.
steelrider58 is offline
Old 10-02-19, 10:04 AM
steelrider58
NO LONGER A BF USER
Quoted: 21 Post(s)
Also, a lot of mountain bikes in the 80s had strange rear brakes (1988 saw a lot of u-brakes installed underneath the chain stays). If you're trying to install v-brakes on the old u-brake posts, it won't work.
...6th post...Four to go...Before then, you see no photo.
Old 10-02-19, 10:27 AM
Limnoted
I bought the frame bare, so don't know if the previous owner had issues or what was installed.
However, the 1988 Bridgestone catalog shows the bike with cantis on the rear.
(a google search of 'Sheldon Brown 1988 Bridgesone catalogue' will turn up images & parts lists)
Limnoted is offline
Old 10-03-19, 06:35 PM
steelrider58
NO LONGER A BF USER
Quoted: 21 Post(s)
How far off are they? Can you submit a photo or two?
Old 10-03-19, 06:55 PM
Limnoted
I can't submit photos or URL's to this forum since I'm a new user.
The misalignment is only a mm or two
I have successfully installed an old pair of cantilever brakes on the posts, so the tolerance on the new linear pull brakes is tighter.
Will try rummaging in a used parts bin at my LBS for another linear pull option.
I'd rather not use cantilever brakes over the wet winter here.
Limnoted is offline
Old 10-04-19, 10:09 AM
Nu2Miele
Quoted: 27 Post(s)
Liked 5 Times in 5 Posts
Use cantilever brakes on a Bridgestone
Why not use cantilevers on a Bridgestone? Forget about linear pulls or V-brakes. Properly setup cantis can provide the same if not more braking, based on the size of pads, and how low you set the straddle cable. If the straddle cable is set as low as practically possible without you will easily lockthem up even in the wet. For a further take on cantis go to the Rivendell Bike Works site, pretty sure Grant Pedersen explains that (Keith Bontrager also wrote an article concerning cantilever brakes and what he thought the best set up of them was).
Nu2Miele is offline
Likes For Nu2Miele:
Old 10-04-19, 12:25 PM
dweenk
dweenk's Avatar
Quoted: 887 Post(s)
Liked 335 Times in 225 Posts
In which direction is the hole off (up, down, left, right)? Sounds like a seat stay may be bent.
dweenk is offline
