Experienced SMP users...
What do I not get about these saddles? Trying out a lite 209 and it's giving me the same problems the dynamic and plus did last year (the nose on the plus was too wide as well). It destroys my crotch and crushes my boys into oblivion. The very thing its supposed to prevent. I can run it level to severely nose down to the point I'm sliding off and it still crushes my scrotum on the nose. My balls are squished with authority into the top of the nose, the hook point at its highest peak, before the nose drops down into the "beak" shape.
I'm not sure if they just aren't for me but I can't recall ever speaking or reading about anyone else with this issue. Most who are against them state sit bone pain or sitting on a brick. It's the exact opposite for me, I have zero sit bone discomfort, but extreme pressure, which even the naysayers at least agree it helps in the that area.
I really want one to work because they are the only saddle with a full cutout that I don't get chafing with. I'm wondering if it's a fore/aft issue? I've started with the same setback as old saddle, and increased it up to 15mm forward as suggested by hogg and pierce. Am I sitting on the wrong area? The saddle seems to put you where it wants you regardless of where you hop on within a few pedal strokes.
Has anyone else had experiences like this? I've tried lite 209 and dynamic. The dynamic was last year but I remember the same issue. Also played with a plus but nose was too wide from the get go.
Flyin' under the radar
I had a similar experience with a demo SMP saddle I tried, though not as extreme as yours.
I ultimately went with an ISM Attack saddle, which does a great job of alleviating genital pain/discomfort/numbness. I'd previously tried an ISM Adamo, but it was too wide which caused nerve pain in my legs. Have you considered ISM?
Alsoaybe I'm exaggerating a tad with the smp pressure but it's definitely there and it's definitely uncomfortable. This is supposed to be the one thing they relieve. I don't get it
Thread Killer
Quoted: 3149 Post(s)
Liked 1,714 Times
Scrotal swelling?
just another gosling
Quoted: 3891 Post(s)
Liked 1,940 Times
Yeah, for me they're torture devices.
Bikes: Cannondale CAAD9-4
Everyone is different. Saddles are a love/hate affair. I'm most comfortable on the flat Specialized saddles and ride a 155 Avatar. Tried a few others over the years that other people rave about and I hated them. Haven't tried an ISM yet, but I might next time I buy a saddle.
Thread Killer
Liked 1,714 Times
Maybe in Cloud Cuckoo Land every bike seat is equally comfortable for every rider, but here in real life, different physiology, riding positions, effort levels, road conditions, ride durations and bike setups all combine to make some saddle shapes and constructions more comfortable for any given rider than other saddles.
What's not to get?
What's not to get?
Thread Killer
Liked 1,714 Times
What's not to get?
What's not to get?
I don't get why it does not relive pressure. Everyone agrees they do. I've rode 50 saddles that the community raves about that I didn't like for one reason or another. But, I've never had pressure from a full cutout saddle. The world universally agrees these saddles relive pressure but some may find too painful on the sitbones. Just sayin man, don't lump me into the newbie group, I'm just wondering if I'm missing something on the setup.
wears long socks
Maybe try the saddle a nudge forward and really make an effort to plant your bones in the saddle.
There are times when without noticing, I slide a hair forward. Once the pain starts, I slide back to where I should be.
Bikes: S-Works Tarmac
Quoted: 182 Post(s)
You can try lowering the saddle 5mm and see what difference that makes. Often a small adjustment can make a large difference, and its been my experience that lowering the saddle often improves comfort - with no effect on power output.
The ISM Attack as mentioned above, or most any in their line, will definitely eliminate the "squashing" syndrome. If you roll the hips forward by nature then consider trying one of the ISM saddles.
Are you sure you are positioned with your sitbones supporting your weight?
wears long socks
I think I'm going to try it perfectly level to 1 degree up tonight. It is with noting I have zero pelvic flexibility, this could be contributing to the issue. My crotch is right against the nose, I stead of just sitting up there. On the dynamic last year I did have some sore sit bones but still had pressure. I really think this is a setup issue on my end as the saddle should relive all the pressure even if it is uncomfortable on the rear.
For me, it was a huge relief once I finally got my sitbones holding all of my weight.
I'm riding on a cheap stock paradigm saddle and I can ride it all day without any pressure on my prostate/groin area.
When I slide off of the sweet spot, it becomes obvious right away.
Bikes: Fuji Sportif 1.3 C - 2014
Quoted: 5 Post(s)
It may sound counter-intuitive, but you may want to try the saddle with just a bit of nose up angle.
It sounds like you're riding the saddle way too forward, and angling the nose up a bit will help with that. Your sit bones should be in the wide part of the saddle near the very back.
I recently got the SMP Pro, and I'm still getting used to it, but most of my problems are when I end up too far forward on the seat, so I have to remind myself to stay on the rear.
As far as the cousins go, I haven't had an issue with mine, because the saddle is narrow enough that when I place them correctly in my shorts, that they would be on either side of the saddle and out of the squish zone.
Of course, not every saddle or brand of saddle is for everyone. Since you haven't tried nose-up, try that for a few rides, and if it doesn't help you stay where you're supposed to on the saddle, then try a different saddle or brand.
GH
GH
A little better tonight, no pain in the crotch but still pressure. I guess I don't understand the design, with the nose at such an angle, how are you NOT pressed up against it when leaning forward? Hogg told me to flip my stem upwards, not sure if I want to do that permanently or not but I may give it a try tomorrow.
I think I'm going to try it perfectly level to 1 degree up tonight. It is worth noting I have zero pelvic flexibility, this could be contributing to the issue. My crotch is right against the nose, I stead of just sitting up there. On the dynamic last year I did have some sore sit bones but still had pressure. I really think this is a setup issue on my end as the saddle should relive all the pressure even if it is uncomfortable on the rear.
Quoted: 1096 Post(s)
This gets to the thing I like so much about SMP saddles. Everyone notices the way the front turns down, but what makes the biggest difference is the way the back turns up. It makes correct positioning so much more natural and intentional. Brooks are like this, too. Flat saddles just feel vague and dubious.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
GH
GH
Love my Composit SMP, but getting it angled just right takes experimentation. Also some saddles just don't work for certain people, which was my experience with the Fizik Arione.
It sounds like you need to move it farther forward, and keep in mind that level for these saddles looks nose up. "Level" is placing a level on the nose & tail, which looks like an extreme up tilt. The more up-tilt, the further back you sit on the saddle which should relive pressue issues in front.
Bikes: Cervelo S2, Workswell 062, Banshee Spitfire
I recently got a 35 dollar eBay carbon one to try out for my GF. She has been through several different saddles, but did not find any of them comfortable. Its a cheap way to try out the SMP shape without spending 200+.
Her first ride was yesterday and it was the first time I've ever heard her use the word comfortable and saddle in the same sentence. Only thing she didn't like was how hard the saddle is (since it has no padding). I'm going to give her a few more rides and if she keeps liking it...I'm going to get her an SMP.
Liked 406 Times
Also good cycling shorts ofc.
Blast from the Past
Wondered how the OP was coming along with this? I recently converted from 143mm Romin to SMP Dynamic with very positive results. For me seat angle is more important on the SMP vs other seats I've tried, big differences in feel for small changes. I ended up at -4 deg of tilt down (vs -1.5 deg on the Romin). Interesting that the level of the front part of the seat tilts up about the same as the Romin (+ 1.5 ).
Seat height is still a little in flux, so far -4mm with the SMP. Setback for me ended up the same measuring from the tip of the seat.
Took me a good 4 rides to get it sorted.
