How can I keep HR low? (Polarized Training)
Retired dabbler
Location: Acton, MA (20 miles west of Boston) - GORGEOUS cycling territory!
Bikes: 2007 Specialized Roubaix Elite Triple - 1st ride = century 9/19/2010 , Ultegra
Quoted: 46 Post(s)
How do I ride to keep my HR low?
"Polarized Training" = 80% riding is VERY easy, 20% is make your eyeballs pop! (I think that's a decent distillation)
This is what I did and my results:
PS - When (if) I do it again, I think I will do one "regular effort" ride each week. I was starting to do that at the end of the 10 weeks just to relieve the boredom.
* My max HR last year was about 155 or 156
** This will sound pathetic to most of you, but one of my regular routes has a speed display in front of a school. When I hit it, I've just ended a mile that's mostly uphill (12 mph average) and it's slightly uphill. My max effort was 18 MPH. Afterwards, I could trigger "23" in Identical conditions.
- It is not practical to ride flat routes. My regular routes usually have about 50' of ascent per mile.
- Step 1 = Go SLOW - I understand, although that's usually difficult. It's instinctive to push a little.
- Sit - standing increases HR
- Cadence? It seems that high cadence increases HR, but spinning feels like it's less effort.
- I have huge gear range: 53/43/30 with 11-34, so I can spin fast even at 5 MPH
- Intervals, did them.every week for 10 weeks last year. 4 x 8 minutes (AHR = 150*), 2-3 minutes to get HR under 110.
- Almost all other rides, I worked to go slow, keeping the HR in Zone 1 if possible. It seems like it should promote more joyous riding and fewer injuries. I found it more frustrating than "joyous."
- SUCCESS: After 2 months, I improved acceleration and top speed, but I did not improve my average speed or strength or stamina. So I was pleased with the improvements** but somewhat surprised that the other items didn't improve.
Location: Was born and raised in Philadelphia, PA. For the past 30 years we have been living in Fort Smith, AR
Bikes: Two road bikes, Zanes and Specialized.
Quoted: 31 Post(s)
Well, it seems to me you're in need to some aerobic conditioning. Since your HR goes off the chart and I assume your breathing is also labored, it indicates your aerobic capacity is in need of training. Being a runner and biker secondly, I do most of my running in the easy, "comfortable hard" effort. That is, if 1 is walking and a 10 is an all out can't breath run effort, you should be at a 4. I don't use a HRM for my training but use the "talk test"...If I can repeat the Pledge of Allegiance in short phrases, I'm ok, if I can't, I'm going too hard, if no problem, then I'm going too easy. Aerobic conditioning takes time, at least 3 months. One way to know you're improving is to measure your resting HR in the morning. It will gradually get slower, because your heart is becoming more efficient, which it isn't at this time. It's way beyond the scope of this answer to explain all the wonderful things LSD ( long slow distance ) training will do for you. I suggest you do a search and you'll be reading articles until the cows come home!...Good luck...DON'T GIVE UP...It takes time, but you will NOT be an efficient cyclist or runner without a good aerobic foundation.
Lloyd
Lloyd
Bikes: S-Works Tarmac
Quoted: 182 Post(s)
You need to be in zone 2 for most of your riding. Zone 1 only for short recovery rides, of which no more than two a week. Get your intervals by riding with fast groups. These things will definitely improve your aerobic conditioning, as well as make new friends and more enjoyment. Riding alone is a recipe for depression.
Has a magic bike
Quoted: 4456 Post(s)
Liked 425 Times
You should be basing your training zones off lactate threshold heart rate not max heart rate.
When you are doing a zone 2 ride you really do have to focus to get it done. Sit & spin up hills. Don't push no matter how instinctive it might feel to do so. Zone 2 rides are for sure doable in your type of terrain.
Your HR takes a long time to come down after an interval, this suggests lack of fitness. So you've got to keep working at it.
Speed is not much of a metric- its influenced by many things, including wind, temp, road surface, %grade etc.
I think you're expecting too much from 10 weeks of intervals. It just takes a long time, you have to be very persistent.
The Left Coast, USA
My exams and EKGs have been fine before and after, so there's that. Frankly, I am of the non-scientific opinion that your daily diet has a big impact on cardio performance.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
OP, if you want to improve your average speed, then I'd work on improving your average speed. Instead of doing these shorter intervals and then spending all of your other rides barely riding, why not make a couple of three of your weekly rides longer interval rides where you're doing 30+ minutes of effort at a time.
Do those for 6-8 weeks and I bet your average speed will increase a noticeable amount.
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
Shoot...I can barely ever get my HR under 110 when riding at any pace.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Zone 1 and low zone 2 should feel painfully slow at first. You have to fight the urge to go faster, jump on the tail end of a passing group, hammer the last mile, etc. Sometimes it feels as if you didn't even exercise.
Trust your heart rate monitor. Slip into an easier gear, slow down and ride your heart rate zone for the specified time. Forget about speed altogether. Set your heart rate monitor so that it doesn't even show your speed and trust your zones, that's all.
-Tim-
Quoted: 2952 Post(s)
Liked 3,106 Times
If your plan calls for going slow, then go slow. I have had recovery rides where old ladies on shopping trikes pass me.
Non omnino gravis
The first mistake is thinking in terms of speed at all. Establish your LTHR, set your zones, and if you desire, ride in a specific zone. Effort ≠ speed, unless you're riding on a flat, smooth road. It's also virtually impossible to base any training zones off of max HR, because the average person has never seen theirs. My highest observed has been 185bpm, but I haven't seen that number in several months. The bulk of my rides come out in my HR Z2, just because they do. I'm not "training," unless I count today's ride as training for tomorrow's.
The Left Coast, USA
Nope, I have to disagree. One factor influencing cardio efficiency is hydration, and diet impacts water storage and release. From what I've studied & experienced, it seems to goes well beyond that one example. But, this is a complex subject that isn't going to be sorted out on an internet forum.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
What you are experiencing is typical.
-Tim-
-Tim-
But I felt it in my legs after the 40 mile ride. And I didn't feel like eating when I got home. I think it works, and helps to train the body to burn fat efficiently. (And it's good for just getting some hours on the saddle, too.)
When I did a few early season rides in zone 2, I had to keep my cadence at 80 or so. My usual 90+ would bump up my heart rate too high.
Bikes: bikes
Liked 1,429 Times
Multiple bikes, plan your route.
Staying in Z1/Z2 is tricky because it feels weird. Having an alternate bike can be helpful. Something with wider tires and a more padded saddle, since more weight will be on the seat.
Plan your route. You can usually find a flat route almost anywhere, but you may want to spend some time looking at the terrain. A nice easy spin through the park on a cruiser bike for example. All you need is your HRM and Garmin on the stem.
Quoted: 974 Post(s)
Liked 512 Times
Oh, of course! I never even thought about that. I'm used to maxing out at 3 mph on really steep climbs, not walking.
This was mentioned in those discussions about polarized training a couple of years ago. Walking the hill is what the Olympic cross country athletes would do, to keep their heart rate down.
Liked 3,106 Times
It can help to hide your speed. Most computers have different screens, so just put it on HR and time. That's all that matters.
hobkirk
Training & Nutrition
9
10-07-15 06:41 PM
mkmartin
2
04-21-12 03:54 PM
