Altering Der. Hanger for Roadlink
Old 01-27-20, 08:36 AM
New2Two
Quoted: 12 Post(s)
Liked 4 Times in 2 Posts
I am upgrading out C-Dale RT1000 to Etap. I was going to use the roadlink with Wifli to fit the 11-40 cassette. However, when I went to fit the Roadlink to the derailleur hanger, they won't fit together. There is too much material on the bottom edge of the hanger where the B-screw would hit that interferes with the roadlink. I would need to remove 1 to 2 mm off the end of the hanger. I figured this would be easy enough to do on the belt sander. Has anyone done this to make it work?
My other thought was to get the Digirit extended cage and forego the Roadlink.
Thoughts on which way I should go?
New2Two is offline
Old 01-27-20, 01:38 PM
OneIsAllYouNeed
Bikes: Chinook travel/gravel/family tandem, Chinook all-road, Motobecane fatbike
Quoted: 232 Post(s)
Liked 34 Times in 25 Posts
RoadLink and extended cages solve different -- but related -- problems. The RoadLink allows the upper pulley of the rear derailleur to clear a larger cog. An extended derailleur cage gives your rear derailleur more chainwrap such that you can have adequate chain tension in a wider range of gears.
Are you using an authentic Wolftooth Roadlink? The knockoffs might not fit as cleanly as the real thing. On your current derailleur hanger, I'd remove it from the bike, then file down the tip until the RoadLink fits. You should be able to buy a spare derailleur hanger if something goes terribly wrong.
OneIsAllYouNeed is offline
Old 01-27-20, 03:45 PM
New2Two
Quoted: 12 Post(s)
It is an original WolfTooth RoadLink with a new hanger that I just got. Perhaps 15 years ago C-dale added more material at the bottom to ensure the b-screw had enough real estate so the derailleur could be adjusted properly.
New2Two is offline
Old 01-27-20, 09:41 PM
act0fgod
Bikes: Specialized Tarmac Pro, Bilenky Coupled Tandem, Calfee Tetra Tandem
Quoted: 32 Post(s)
Liked 15 Times in 10 Posts
Yeah the roadlink didn't fit on our hanger. I ended up taking a Dremel to the very bottom of the hanger. Also needed a 120 link chain to make sure the derailleur didn't rip off if I ended up in the 52-40. It's kind of loose if I end up in the 36-11. Generally, I'm satisfied. I'm operating way outside the technical recommendations so the performance isn't perfect but it's still better than the mechanical was.
act0fgod is offline
Old 01-28-20, 04:41 PM
Alcanbrad
Alcanbrad's Avatar
Bikes: '14 CoMo Carrera, '11 CoMo Primera co-pilot, '98 Santana Visa, a Plethora of road bikes, A commuter/Gravel beast (and 1 MTB)
Quoted: 106 Post(s)
Liked 45 Times in 38 Posts
I don’t know if your dale has a replaceable hanger or not. If not, I would explore modifying the roadlink before removing material from your frame.
Alcanbrad is offline
Old 01-29-20, 08:44 AM
New2Two
Quoted: 12 Post(s)
The hanger is replaceable. I picked up a replacement for this project and might get another as a backup just in case. I plan on drawing in the curve needed to fit the Roadlink and take the hanger to the belt sander to slowly remove what is needed to make it fit.
New2Two is offline
