New Deore 12 speed groupset
despite being partly a grumpy old grouch for some tech stuff, I think this is pretty neat.
Deore is, and always has been, that sweet spot of cost/performance/longevity/availability, so this is pretty neat that 1x and 2x options of 11 and 12 speed are in that Deore price range.
although I still like triples, I'd be open to play with considering a 11 speed double one day
anyway, a blurb describing it
https://cyclingmagazine.ca/mtb/shima...wide-range-11/
who knows what sort of real life longevity you'd get out of this stuff.
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
No way to work with a triple?
don't quote me, but I suspect that with all the really wide wide cassettes that have been appearing over the last bunch of years, 11-40, 42, 51 that the spread would be too much for a rd with a triple.
The article does mention the 11 speed stuff also getting this bonkers 11-51 cassette, and says that the 11 speed 11-42 will work with a double--I guess this isnt new, but it does probably offer some interesting double 11 speed possibilities
I still laugh when I see these new uber large cassettes, its pretty wild how derailleur technology has progressed.
and cool.
Im still looking at all this from an outsider view though, happy to stick a few steps behind.
and cool.
Likes For djb:
Quoted: 606 Post(s)
Liked 286 Times
At first glance I think of this as silly but...... with a double of 46-30 up front and an 11x42 in the rear, I'm looking at a low of 19 gear inches which is the same as my triple of 24 front and 34 rear. Not sure of the actual 12 cogs but the steps wouldn't have to be that outrageous. Hmmm
I don't keep up of what doubles are common, but I was thinking a 42/28 would make a possibly interesting setup.
they do say that the 12 speed can have a 10-51 , the 11 speed is 11-51
'normal' cassettes are heavy enough, but a 51T cassette would be a freakin' boat anchor!
They do mention two versions one with aluminum and other steel, and I think they mentioned weights too. I didn't pay attention tbh and don't recall numbers.
but yes, that's why I laugh seeing these big cassettes, they really do look like pie plates
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
All I need is a front derailer and bar-end shifters to make this work w/a triple.
And of course, I have no desire for a cassette with an 8+ tooth-difference between cogs. So screw the 51, I'm excited about other possibilities that this opens up.
Quoted: 2619 Post(s)
Liked 1,960 Times
And at what cassette count do we need to start worrying about dinging up the cassette against rocks or curbs?
Likes For pdlamb:
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
And I’d like to see these cassette options in 9-speed units, too. I don’t want to have to throw away my XTR brifters, trying to be cool. 🤔😉
461 g (10-45T), 470 g (10-51T)
10-12-14-16-18-21-24-28-32-36-40-45T
10-12-14-16-18-21-24-28-33-39-45-51T
and weight for the 2x cranks, cause it IS for touring:
FC-M8120-B2 (36-26T, 175mm, w/o BB) is 672g
C-M8100-2 (36-26T, 175mm, w/o BB) is 654g.
would have to see how it would work with a 3x crank for an awesome 36-speed touring setup.
and yes, the jump from 42 to 50ish teeth is 20%, which is a lot. From experience, the 18, 19, 20% jumps are annoying, which I certainly like to avoid
Am I missing something here, or has this discussion ignored the fact that the Shimano 1x12 MTB drivetrain is intended for use with "boost" thru-hubs only, which are incompatible with most dedicated touring frames and bikes, which generally require 135mm x10mm QR rear hub. I cannot find any micro spline capable 135 QR Shimano hub. I don't think they make one or intended 1x12 for touring application.
DT and Hope seem to have either micro spline 135x10 QR hub (one in 36h!) or adapter freehub for older model hubs. In addition to having to spend ~$200 on a rear hub, you will have to order it (possibly with long wait), then have a custom rear wheel (wheelset if you want matching hubs/rims) made, or DIY.
If you are seriously considering SLX 1x12 drivetrain, be sure to factor in the cost of custom wheel ($350 +). Or a new frameset/bike with thru hub capability (Surly Troll comes to mind). I know that seems a little pricey, but bear in mind that 1x12s SLX means you do not need a front derailleur, gear shifter, double or triple crankset and 100cm of cable and housing - just think of the mechanical simplification and weight savings!
142, 148, Im personally not up on being familiar with the various ones now.
Quoted: 671 Post(s)
Liked 49 Times
Crazy with all the road & MTB options but sparse leftovers for trad drop-bar touring. No 3X hydraulic brifters; no 10/11/12-speed brifters that use MTB cable-pull, no IGH brifters, no Shimano single-speed hydro road levers for bar-ends or IGH, etc.
you don't just have to buy a new bottom bracket to go with that crank, you need to buy a whole new frame.
