Redshift Stem for touring/training around town?
#52
Now all of a sudden we are in the region of 50W disappearing into the tires. Considering the average touring cyclist is chugging along at a mere 100-120W total output, we are not laughing anymore, are we?
#53
Sunshine
Quoted: 11003 Post(s)
Liked 7,530 Times
https://www.bicyclerollingresistance...on-32-37-40-47
https://www.bicyclerollingresistance...-gravelking-35
Pick these apart and wiggle around to justify your narrative.
#54
https://www.bicyclerollingresistance...terra-speed-45
Is bigger better with touring bike tires? No, at least not with the Schwalbe Marathon. With the Schwalbe Marathon, the 37-622 version has the lowest rolling resistance of the 4 sizes tested. The 40-622 might be a good option for slightly more comfort at a slightly higher weight and aero resistance. The 32-622 uses other materials and stands out in a negative way by performing much poorer than the 37, 40, and 47 mm versions on the rolling resistance test.
So when should I mount a bigger tire? Only when you need more comfort and your tire 'bottoms out' on bumps. Aero resistance and weight will increase. Rolling resistance will increase even more because a bigger tire needs an even lower tire pressure to offer the same comfort level, which in turn increases rolling resistance.
Join Bicycle Rolling Resistance
#55
Sunshine
Liked 7,530 Times
I provided examples.
I am not claiming those options are ideal for touring. I am not claiming g they are bad for touring.
I am not claiming anything, just providing examples.
As for your Marathon tire ramble, yeah I know the tester thinks the 32mm is a different material. Again, I provided examples where a wider tire rolls faster than a narrower tire when the brand and model are the same.
The Marathon testing showed a 37 was faster than a 32 at proper psi(for me, at least. I don't know what your proper psi would be).
Once more, even if the rolling resistance is the same between widths when proper psi is accounted for, air resistance for a 37mm tire vs a 32mm tire is so dang minimal that it isn't worth the handwringing. You are touring- nothing about the activity is aerodynamic. Tire aerodynamics is not even in the top 10 of what I would want to try and focus on for aero gains when touring.
Question for you - how much of an aero penalty, in watts, is a smooth 40mm tire vs a smooth 32mm tire? Source it.
#56
You asked for exams where wider tires of the same brand and model roll faster than narrow tires.
The Schwalbe Marathon is a different material in 32mm because this tire is not just one of the most popular touring tires in the world, it's also one of the most common commuter tires in Germany. And because Schwalbe doesn't want its reputation trashed, it wants every tire under the Marathon marque to meet a minimum threshold of endurance, which the narrow variant can't achieve without using a harder wearing compound than the wider variants. It's actually a completely different tire stuck under the same name by Schwalbe's product manager.
Which circles back to the same mistake you've been making this entire time. If you want to talk about the merits of different tire widths, you need to experiment using different widths of the same tire. If you compare different tires, your whole experiment is out the window.
If seeking evidence for your position requires you to scrounge the internet until you've found a marketing gimmick in the naming conventions of one particular brand, and then triumphantly yelling, "haha!" That's not exactly shedding a good light on you, is it? Did you also know that the Toyota Camry used in NASCAR isn't the same Camry your mom drives? Crazy stuff.
But anyway, circling back to the widths variations which ARE actually the same tire, why would I bother writing my own argument when bicyclerollingresistance.com has already written it for me?
Bicyclerollingresistance.com:
So when should I mount a bigger tire? Only when you need more comfort and your tire 'bottoms out' on bumps. Aero resistance and weight will increase. Rolling resistance will increase even more because a bigger tire needs an even lower tire pressure to offer the same comfort level, which in turn increases rolling resistance. Join Bicycle Rolling Resistance
I have no doubt you have immaculate credentials in whatever it is that you make a living with in your own life, but pardon me for choosing to believe in the conclusions of an independent testing lab over the opinion of some random nobody on the internet. No offense.
#57
I am potato.
Quoted: 1792 Post(s)
Liked 1,631 Times
Yes, for a Continental GP5000. But we don't actually tour on Conti GP5000s, do we? When we look at touring tires, the Schwalbe Marathon is 21W, the Marathon Plus is 26W, the Vittoria Randonneur is a whopping 32W. That's per single tire and bikes have two tires, so multiply by two.
Apples to oranges bull with GP5000 vs Marathons and Marathon vs Marathon Plus is hogwash and you know it. Of the same series of tire, the Rolling resistance difference between size "A" and size "B" is within the error bars. That is to say: Negligible.
What does "negligible" mean? It means that in the real world with a variety of variable surfaces the larger (of the same series) tire at the appropriate pressure can and often does come out on top and almost always has the more comfortable ride while doing so. The rougher the surface, the more likely this is so.
Learn a new thing, Yan.
#58
Can you drum me up a scenario where 2&4/25ths of a watt in total will have a real world impact on the outcome of any cycling activity not performed on a laboratory test equipment?
Now the question is, what exactly is "error bars" according to you? What exactly is "negligible"? For the typical touring cyclist peddling along at 100W cruising power, 8W would be 8%. In the opinion of Base2, is 8% "negligible"? And if 8% is negligible, then how much slower would Base2 have to be riding before he is able to notice a difference? 10%? 15%?
End of the day, is 8% power a worthwhile sacrifice for the additional comfort of going from 37 to 47mm? It's a personal preference and not a question that has a correct answer.
By the way the standard Marathon uses a steel bead and the 47mm variant weighs a whopping entire kilogram per tire (holy smokes), so it's worthwhile to consider a more expensive kevlar bead alternative if going for that size. At least get the weight down even if one doesn't mind the rolling resistance.
And coming back to this thread, because this is a stem topic thread and we shouldn't get totally sidetracked: the Redshift stem in question weighs 280g for the 10cm size, which is about 100g heavier than a typical aluminum road stem. For that extra 100g non-rotating weight, you get a stated 20mm of suspension travel, in my experience more like 15mm with the medium elastomers I put in. 15mm of suspension is the equivalent of going from 37mm to 52mm tires. If you install the softer elastomers to get that full 20mm suspension, you'd get the equivalent of going from 37 to 57mm tires, which is full blown mountain bike tire territory. Very few touring frames can even fit that width of tire. My own frame tops out at 50mm clearance. The stem costs about the same as a pair of decent tires.
And that's the gist of it.
Which is better, chunky tires vs Redshift stem? Personal decision. You could even get both and it'd be like riding a fat bike. There are very few completely free lunches in the world. Personally I think given the affordability of the stem and the very light 100g static weight penalty, it is very close to getting a totally free lunch.
#59
Sunshine
Liked 7,530 Times
That wasn't my ramble. That was a direct copy and paste from the conclusion section of testing article you linked yourself. Now I know for a fact you never actually read it.
And that's all there is to it. What else needs to be said?
I provided 3 that met your criteria and you clearly dislike one of them.
#60
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 401 Post(s)
Liked 800 Times
.the Redshift stem in question weighs 280g for the 10cm size, which is about 100g heavier than a typical aluminum road stem. For that extra 100g non-rotating weight, you get a stated 20mm of suspension travel, in my experience more like 15mm with the medium elastomers I put in. 15mm of suspension is the equivalent of going from 37mm to 52mm tires. If you install the softer elastomers to get that full 20mm suspension, you'd get the equivalent of going from 37 to 57mm tires, which is full blown mountain bike tire territory. Very few touring frames can even fit that width of tire. My own frame tops out at 50mm clearance. The stem costs about the same as a pair of decent tires.
#61
I am potato.
Liked 1,631 Times
There is no need to speculate. If you go to the Schwalbe Marathon testing report linked previously and look through the chart, you'll see that going from the old school touring width of 37mm up to the newly fashionable width of 47mm loads you with an extra 8 watts of drag across two tires at typical pressures. For surface quality, that lab uses a patterned drum to approximate rough pavement.
8 Watts. You lose as much with a dirty cross chained drivetrain. You lose as much in aero with exposed shifter & brake cables or simply by looking up or with a partially unzipped rain cape. The wider Marathon still offers better comfort and better protection against pinch flats and more conformance over sharp objects (less puncture risk) over rougher surfaces than the skinnier marathon. How much time do you lose fixing flats? The wider Marathon is the winner...Even if touring tires don't scale as flatly as high performance, supple sidewalled road tires.
https://en.m.wikipedia.org/wiki/Error_bar
#62
Quoted: 3465 Post(s)
Liked 1,470 Times
I can't tell if my dyno powered lights are on or off from the additional drag to produce the power in the lights. If I recall correctly, turning on my lights adds about 5 watts of drag.
Thanks for posting those results that show that all tire widths are so close in rolling resistance, that only a racer would care about tire size.
That does not say how much weight is on the tires, I assume that the same weight load is used in each test, the tire pressure is varied to produce the desired tire drop.
The last brevet I rode with 32mm tires, had some expansion joints in the concrete every 25 feet or so, was very rough riding for several miles with a jarring bump about every second. Was glad I did not have skinny tires on that stretch of road. My road bike with 28mm tires would have had a much rougher ride.
Likes For Tourist in MSN:
#63
Quoted: 1037 Post(s)
Liked 1,300 Times
It is amazing how one person can take a thread about a stem, and turn it into a personal diatribe about tire rolling resistance. That particular individual makes reading Bike Forums feel like riding a bike with too much rolling resistance. Hovering over the ignore function, and yet strangely hesitant due to the same force that beckons one to watch a bad movie just to see how bad it really is.
Likes For phughes:
#64
Quoted: 401 Post(s)
Liked 800 Times
This is pretty eye-opening for me. One of my bikes has Vittoria Randonneur Trail tires, which are likely even slower than the Randonneurs listed here. As Yan has pointed out previously, these result are per tire. If I can save 25 watts of output by simply changing tires, that's about a quarter of my average wattage. Not insignificant.
#65
Sunshine
Liked 7,530 Times
Yan seems to think you can't compare tires from different brands, but look at what you did with that screen shot- you managed to compare.
All seriousness, yes a Gravel King tire that you can get for under $40, or any number of other options also for less than $40, will save a bunch of rolling resistance for you.
Easy win, really.
#66
Quoted: 401 Post(s)
Liked 800 Times
#67
News flash: Marathons are terrible tires from a high performance perspective. But even if they weren't, the low rider power and high weight of the scenario you offer were specifically chosen to make the rolling resistance difference between the various sizes of these tires specific tires look more significant than they really are as a percentage of rider power.
Marathons are not performance tires, but they are one of the most popular touring tires for a reason. In a touring context, we have to look at what people actually use, not some fantasy racing tire. Schwalbe's best selling tire isn't even the Marathon. It's actually the even slower Marathon Plus. That's what people are using in the real world. This tire is a total behemoth that weighs 1.1kg per tire in the 47mm size. You want to talk about a massive penalty for sizing up?
Drivetrain loss is in the range of 2 watts.
You are right that 8 watts isn't a deal breaker. Afterall, anyone who rides a touring tire is making a speed sacrifice for durability. We are all already making a decision to de-prioritize speed. But you have a set amount of power to work with. 8 watts here, 8 watts there, 8 watts in a third place. If you care about absolutely nothing, small numbers will eventually add up to larger numbers. We are already losing 6 watts to the dynamo, 10 watts to durable tires, 30+ watts to pannier air resistance. That's all before we get into the heavy weight we are lugging around. I try to avoid flappy clothes for example. Eliminate the lowest hanging fruit first. The Redshift stem is a low hanging fruit.
Likes For Yan:
#68
I can't tell as those two are hidden behind a paywall and only the very low pressure results are shown for free. Do you have a paid subscription you can share?
#69
Liked 1,300 Times
Really? I'm still here. Sorry, but it is a huge thread drift, and you are, and I'll be nice here, overzealous in your opinion regarding tire width affecting rolling resistance, saying wider tires have more rolling resistance, despite evidence to the contrary. You chery pick data that disregards tire construction, which has a great affect on rolling resistance. The fact is, a wider tire of the same construction, has a lower rolling resistance, all things being equal, because it has a shorter, rounder contact patch than a narrower tire, which has a longer, narrower contact patch. THe wider tire's shorter, rounder contact patch rolls more easily over surfaces, and the tire can be run with a lower pressure, absorbing bumps and imperfections on the road.
Now despite the cycling community as a whole accepting this now, based on studies, and science, you are stuck in the old days, which I grew up in, and you still believe what we did back then. Back then we went narrow because it was fast. What was actually the case whas there were no real studies done, and there were not a lot of wider tires available for road bikes, and those that were available were heavy. That has all changed.
There are reasons that competitive cyclists choose a narrow tire today, and much of that has to do with aerodynamics and weight, and nothing to do with rolling resistance.
Anyway, I have considered the Redshift stem for my touring bike, and this thread has put that bug in my ear again. Hopefully my wallet hasn't heard because I really don't need to spend any more on my bike right now.
#70
I "cherry picked" data? I'm only reading a lab test report on the most popular touring tire line in the world. LOL!
You talk about relying on studies and science. Ok. Whatever you say I guess. If you think they are a disreputable lab and they are lying, fine. Which lab is your preferred lab? Which lab in your opinion isn't lying?
Bicyclerollingresistance.com: So when should I mount a bigger tire? Only when you need more comfort and your tire 'bottoms out' on bumps. Aero resistance and weight will increase. Rolling resistance will increase even more because a bigger tire needs an even lower tire pressure to offer the same comfort level, which in turn increases rolling resistance. Join Bicycle Rolling Resistance
#71
Liked 1,300 Times
We must be living in different universes because if you read that bicyclerollingresistance.com test report being discussed above, it supports what I'm saying and goes against what you're saying.
I "cherry picked" data? I'm only reading a lab test report on the most popular touring tire in the world. LOL!
#72
Liked 1,300 Times
#73
I am potato.
Liked 1,631 Times
100W cruising isn't an artificially low number. That is indeed a typical cruising power. The power number everyone talks about online, what you are thinking of, is FTP, which is a one hour max effort. You can't ride an entire day at anywhere near that. And touring cyclists don't ride at the max possible day long effort either. That would be a racing context.
1.1 Load, Speed, and Temperature
- Drum speed of 200 RPM, which translates to a speed of 28.8 km/h / 18 mph.
- 42.5 kg / 94 lbs load.
- Controlled temperature between 21.5-22.5 °C / 70-73 °F.
That only happens in a polished wood floor velodrome subject to the vacuum of space, going down hill...with a tailwind.
Your made up scenario magically arriving at 50 (or whatever) watts loss...Which is really only 8 watts difference between sizes at 18mph which is not a touring speed of 9-12mph to justify the skinny high pressure you seem to have an unhealthy obsession with is hogwash.
When you scale the 8 watts actual difference in Marathon tire size extremes down to the touring speed of 9-10mph it's like only 4-5 watts or so. A meaningless difference by most accounts.
4 Watts isn't now, or ever going to make or break a day on a tour.
...And while we're at it: Nobody buys Marathons of any variety for their stellar "performance." So, any discussion concerning their rolling resistance is, by definition moot.
#74
You also skipped this from the same site, showing the GP 5000 32 has lower rolling resistance than the smaller width GP 5000 tires using a latex inner tube. And carefully read their conclusion, "From the results above, we can quickly draw the same conclusion that we got from our test from 4 years ago: At the same air pressure, a bigger road bike tire has a lower rolling resistance." Also, and this is important, "We've decided to use a latex tube to minimize the influence of the inner tube on the total rolling resistance." In other words, all things equal, the wider tire has lower rolling resistance. That is not to say there are not differences between tires, or that some narrow tires have lower rolling resistance than some woder tires, but it sayd that all things being equal, a wider tire has lower rolling resistance at a given air pressure.
But did you miss the part a little further down on the very same page where they said that if you inflate the wider tire to the same pressure as the narrower tire, then the wider tire is actually LESS comfortable than the narrower tire, completely defeating the purpose of running a wider tire in the first place?
Did you also miss the part on the very same page where they said they ignored the rated safety maximum pressures during the tests, and that in real world use, you cannot actually safely inflate wider tires to the same pressure as narrower tires?
Yeah, you missed both.
This is the problem with you parrots who have drunk the marketing Kool aid. You saw one chart and never paused to realize that in real life, wider tires need to be run at lower pressure than narrower tires.
#75
These tests are on one wheel. Bikes have two wheels. If you and your bike weigh ~80kg, then each tire carries about half the weight, therefore, ~40kg.
They are not screwing around with you by cheating with some fake light weight. It's simply because bikes have TWO wheels. What's hard to understand about this? HELLO???
