Forum Suggestions & User Assistance Have a suggestion for the forums? Need help with the Forums? Post here.
Mention fail?
Old 05-01-19, 12:00 AM
madpogue
Quoted: 815 Post(s)
Liked 140 Times in 115 Posts
Mention fail?
Mentions appear to be inop. They just show an @ sign, with nothing follwing. Even mentions in existing old posts, that worked previously, are doing this.
madpogue is offline
Old 05-01-19, 12:20 AM
Rollfast
What happened?
Rollfast's Avatar
Quoted: 1675 Post(s)
Liked 144 Times in 128 Posts
@madpogue
Our streets are paved with onions...the drivers aren't tarping
Rollfast is offline
Old 05-01-19, 12:21 AM
Rollfast
What happened?
Rollfast's Avatar
Brings up your profile page. Did you get a notification?
Rollfast is offline
Old 05-01-19, 12:24 AM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 1600 Post(s)
Liked 211 Times in 134 Posts
At lower left of page change your skin to BikeforumsNG, that fixed it for me
Genesis 49:16-17
Darth Lefty is offline
Old 05-01-19, 07:29 AM
madpogue
Quoted: 815 Post(s)
Worked! Much obliged. So the mention content was there the whole time, just obfuscated.
So I wonder what other things this skin change will break. That's the beauty and wonder of all "upgrades".......
madpogue is offline
Old 05-01-19, 09:26 AM
IBRyan
Retired -- Do not PM
Quoted: 67 Post(s)
Liked 17 Times in 14 Posts
Thank you @Darth Lefty !
IBRyan is offline
Old 05-02-19, 10:58 AM
CliffordK
CliffordK's Avatar
Quoted: 9213 Post(s)
Liked 208 Times in 161 Posts
In the past, there was a problem with mentioning
@Andrew R Stewart
@Andrew R Stewart;
As far as I can tell, no matter how one does the mention (@ symbol, or [mention] tags), the system still reads it from left to right, and picks out @Andrew, a different user.
Oops, it chose to do "Andrew R", so it doesn't deal well with the middle initial, and ignored it alltogether when I tried using the [mention] tags (half worked using the @ symbol).
CliffordK is offline
Old 05-02-19, 07:20 PM
IBRyan
Quoted: 67 Post(s)
@Andrew R Stewart
@Andrew R Stewart;
Are you on BikeForumsNG? And what browser and device are you on?
IBRyan is offline
Old 05-02-19, 10:45 PM
CliffordK
CliffordK's Avatar
I'm using Firefox. However, it is not a browser problem. Although, apparently not a common problem for very many users.
Andrew R Stewart has been a member since 2012, with 11,399 posts.
He has been quoted 1661 times.
And, has been mentioned exactly ZERO times.
On the other hand, Andrew R has made exactly 3 posts and has been mentioned 41 times (almost all having to do with Andrew R Stewart).
Andrew has also made 3 posts, and has been mentioned 11 times, although perhaps one can chalk many of those to careless posting.
Old 05-03-19, 09:00 AM
madpogue
Quoted: 815 Post(s)
^^^^^ W@G - the space(s) in the user name complicate/confound the little auto-formatter humunculus.
madpogue is offline
Old 05-05-19, 08:47 PM
Rollfast
What happened?
Rollfast's Avatar
If you gotta humunculus I'd get a scan for it.
Rollfast is offline
Old 05-06-19, 10:21 AM
IBRyan
Quoted: 67 Post(s)
Okay, I will bring this up to tech!
IBRyan is offline
Old 05-06-19, 01:18 PM
IBRyan
Quoted: 67 Post(s)
@Andrew R Stewart
@Andrew R Stewart;
Unfortunately, this has been a known bug of usernames with spaces in between them. There is not a fix, but if the users with this issue would like, we are offering a one time username change for them so that the mentions can work for them. We apologize for the inconvenience.
IBRyan is offline
Old 05-06-19, 02:12 PM
madpogue
Quoted: 815 Post(s)
^^^^^^ Easiest and most reliable fix, if doable, would be a filter on the registration process that doesn't allow spaces in user names.
madpogue is offline
Old 06-01-19, 01:11 PM
Jim from Boston
Jim from Boston's Avatar
Quoted: 677 Post(s)
Liked 71 Times in 57 Posts
Just today (6/1/19) I posted to a thread:
Thanks for that post Trocadile [ @Trocadile ]. I have never heard of that trail. Do you or rholland1951[ @rholland1951 ] have any other information, like access points and road surfaces, especially paved segments...
PS: For some reason today the MENTION function of the BB codes blanks out the name rather than MENTIONING it.
It also seems that all previous mentions are similarly blanked out. For example I type @_Trocadile (typed without the connecting symbol): @Trocadile
A short while later I posted to that thread:
Thanks for those informative replies, @Trocadile and @rholland1951. I look forward to my own investigation. Unfortunately your names are still unmentionable.
Originally Posted by Jim from Boston
(from a now-closed thread) I think a quote or mention is as much of a kudo as a LIKE, since it is conspicuous and is viewed by a wider audience than just the author and those who actually view the LIKED post.
PS: I just further noticed on my Profile Page, under the MENTIONS tab, that the drop-down menu of MENTIONS and QUOTES has disappeared.
Last edited by Jim from Boston; 06-01-19 at 02:47 PM. Reason: added last, nested quote; then PS
Jim from Boston is offline
Old 06-01-19, 03:10 PM
Jim from Boston
Quoted: 677 Post(s)
Another example. Wipekitty appears to quote me:
What water bottle do you use?
My preference for water is flavored carbonated water. [The local brand here around Boston is Polar Seltzer and it comes in a lot of flavors.] It comes in one liter bottles with a screw top cap to contain the carbonation.
Originally Posted by wipekitty View Post
...Like @Jim from Boston, I sometimes use 1-liter bottles. I'm not a fan of carbonation while riding, but these bottles nicely hold a lot of water. I tend to use them early/late in the season when it's cooler and I'm combining commutes, transportation, and recreational rides to save daylight.
Old 06-01-19, 03:21 PM
CliffordK
CliffordK's Avatar
Hmmm...
at Jim from Boston @Jim from Boston test
at madpogue @madpogue test
at IBRyan @IBRyan test
mention Jim from Boston @Jim from Boston test
mention madpogue @madpogue test
mention IBRyan @IBRyan test
Edit:
It looks like it is working for me... for the user names above, using either the "@" symbol, or the [MENTION] tags.
Old 06-03-19, 03:07 PM
IBRyan
Quoted: 67 Post(s)
Hmmm...
Edit:
I am also having no issues with quoting so I believe that it may be on your end @Jim from Boston
IBRyan is offline
Old 06-19-19, 04:30 AM
Jim from Boston
Quoted: 677 Post(s)
Just this morning I noted that MENTIONS have been (spontaneously) restored, as well as MENTIONS and QUOTES on my Profile. Mirabile dictu.
Old 06-19-19, 07:50 PM
Rollfast
What happened?
Rollfast's Avatar
I'm always amazed at how many thing keep people from just reading the posts.
It's like a nagging marriage.
I don't think I'll get scabies and die from it after 12 years. Oh well.
Rollfast is offline
