Where to find short cranks?
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
Oh we have one, it's just another complication, another delay in getting her rideable.
I know the first rule of upgrades is "It won't fit", but it's forking ridiculous; want to change shifters? You'll end up changing out the entire drive train. New brake levers? Yep, better be ready to buy new brakes and cables. Great Bird forbid you want a different handlebar.
/rant
/rant
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
Between manufacturers, sot so much. With Shimano once you understand the compatibility and limitations within it, it's not hard to mix and match to get what you are looking for. BB and cranks (threaded square taper) can cause some issues, but in stock locally I can pick up a BSA threaded BB in just about any size for <$30.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Short Bicycle Cranks
Likes For JohnDThompson:
Sugino XD is readily available down to 150mm and all sizes in between. Complete triples well under $200 even if you aren't patient and don't shop. Origin 8 has short ones too, lower price, lower quality. But not bad.
Not even sure what the MTB incompatibility is supposed to be about. Buy the cranks and put them on the spindle you've got. See where it fits. If you need a longer spindle you get a longer spindle. Have done, what, 5 very short crank conversions past two years, all kinds of bikes, no significant problems yet. Bikes built 1973 to 2018. Road bikes, city bike, mountain bike. 4 of 5 the existing spindle was fine. Working on bikes 45 years old you get used to spindle exchanges.
The Sugino and Origin cranks are 110/74bcd. Minimum chainring 24 teeth. You really don't know what gearing you are going to need with the shorter cranks. Not short myself so only working from what my friends and wife tell me. What they all find is their pedal stroke is completely changed. Much more of the pedal circle is available for generating power, as opposed to just getting feet around to where they will next be able to work effectively. So far everyone is using same gearing as before and getting up hills much easier than before. Higher top end too. And in the wife's case, riding up hills that had become walkers even when she was significantly younger.
Likes For 63rickert:
Quoted: 1303 Post(s)
Liked 1,911 Times
Well I guess I'm stumped here... I know that 175 crank arms won't work on a very small mountain bike. Toe clearance and every other aspect... But there are shorter arms out there and they can be fit onto the shorter frames. A good mechanic should be able to do the job easily and quickly. Bottom bracket spindles should be a minor concern if going from a triple to a triple. I'm going to have an adult beverage and go to sleep on this one, I'm baffled! MH
Happy banana slug
Liked 1,528 Times
Hot diggity! A new source for short cranks! They run 130 to 175 mm and are available in silver (the correct color) or black (if you must). They're also $150 and coming from Japan, so I'm afraid to look at shipping. Nonetheless, they look pretty great.
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
$28.
For reference, I had Mark Stonich of Bikesmith Design shorten these cranks for me quite a while back.
Both are ~148mm, shortened from 170mm. From what I remember, he had a CNC setup in his basement that allowed him something like 22mm as a fixed shortening measurement he could always rip out. He cut off the crankarm ends, buffed out the new end curves, and drilled a new pedal hole to replace the original.
I also remember removing all the chainring bolts ahead of time to save money. He used to charge $5 extra apiece for cranks that arrived with chainrings and bolts attached, because he'd just have to remove them anyway. Yeah, if I was doing all that crank shortening, I'd probably get sick of removing and reinstalling chainring bolts too.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2581 Post(s)
Liked 5,637 Times
This site is full of them.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 1561 Post(s)
Liked 1,734 Times
We have found a source for 160 "youth" cranksets, but of course the first rule of upgrading bikes says that it doesn't fit; the spindles are too long (bike's are 128 mm, crankset requires 113 mm). ::headdesk::
Liked 1,734 Times
Quoted: 2604 Post(s)
Liked 1,931 Times
Likes For pdlamb:
Must be symmetrical
I ride 150 or 152mm on all my bikes (I'm 6'3").
For bikes that should look nice, I use Stronglight Impact Kid, which are really Sugino XD2, and available many lengths from something like 130 to 160. They cost about $75 as a double. Silver, JIS 107mm, 110 BCD, nice.
For utilitarian or really low gearing, I use the Suntour XCT jr, 152mm. 4 bolt, 104 BCD, black. But under $30!
Both are adapted adult cranks so plenty strong.
Likes For Frkl:
