Short Cage vs. Mid Cage - Measurement to check?
Old 08-30-16, 11:00 AM
SpikedLemon
Quoted: 9 Post(s)
Does anyone have a measurement of the arm that I could use for reference to check if mine's mid or short?
I've got a 2014 Cannondale Synapse Tiagra. There's no SS or GS stamped on the derailleur to immediately identify it (only marked as RD-4601). I have a 12-30 cassette which falls into the top range of the SS (30T)
I would like to go to an 11-32 but not sure if I need to get the longer derailleur (need a GS to get to 32T)
SpikedLemon is offline
Old 08-30-16, 11:10 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Already long cage I would bet. But you have not provided a pic or year exact model, so I am now a mind reader.
There are numbers stamped in the cage most likely. You need to look.
trailangel is offline
Old 08-30-16, 11:17 AM
andr0id
andr0id's Avatar
Quoted: 1422 Post(s)
Liked 7 Times in 5 Posts
You should be able to tell by looking at the EV.
A long cage is usually very obvious.
andr0id is offline
Old 08-30-16, 11:56 AM
SpikedLemon
Quoted: 9 Post(s)
My guess too. I was hoping someone had a measurement that I could use for reference to check mine.
The stamped numbers did not have GS or SS. Model was noted but I added year.
Old 08-30-16, 12:14 PM
trailangel
trailangel's Avatar
2016 looks like long cage in pictures. 2014 looks like short cage in pictures.
I measured a short cage Ultegra and it was 2.322 inches or 59mm measured center to center of the pulley bolts.
2014 pic here.. looks like short:
El Davisimo
Road Cycling
25
03-25-19 12:14 PM
hexron
Bicycle Mechanics
3
04-16-17 07:24 PM
mihlbach
Mountain Biking
2
05-02-12 02:04 PM
bitt3n
Bicycle Mechanics
5
09-04-11 09:36 PM
scozim
Classic & Vintage
2
03-28-10 03:15 PM
