650 tires on an oldc Mixte frame
I'm building up a 49cm mixte frame that originally sported 27" tires for a 5'2" person. It looks like going to a smaller wheel size would make things fit into place beautifully.
Are there brake calipers that would let me go as far as 650c? If that's too much, how about 650b? Ideally I would like something retro looking.
I'd look at 590 also (650a). I have done just that, 27" (630) to 650A (590), with a brief stop in between at 700c (622). For me it was because it required less reach, and there were some rims I like available in that size (Sun CR18).
Twincities MN
By my reckoning you would need 78mm reach brakes.
www.marrow.org
www.marrow.org
Are you accounting for radius? 630 - 571 = 59/2 = 29.5mm difference in BSD (change in reach required usually). That is for 27" (630mm) to 650c (571). That would be worst case scenario for conversion to 650c (which I don't recommend, unless you want triathlete tires and rims, or worse, schwinn steel rims). Conversion to 590 from 630 requires 20mm change in reach (to 650a) and conversion to 584 (650b) requires 23mm change.
Brake change may also be required.
Twincities MN
www.marrow.org
www.marrow.org
Quoted: 86 Post(s)
abdon,
i think you are on the right track. 27 mixte, in small sizes, with smaller diameter rims look nice.
had a custom 650c bike that looked real nice in my size.
i recently put a set of 559 rims on a bike made for 630 rims, looked good! but had the worst shimmy i ever had on a bike that was otherwise one of the most stable bikes i had ever ridden. who woulda thunk it?
BTW i worked around the brake problem by lacing up a coaster brake hub in the back and dispensing with the front brake altogether. ( not for everybody, i know). clean, oh so clean!
huey
huey
Ok, because I'm in Japan and this size is common here, i'm looking at 26 1 3/8 rims. The question now is, what flavor of 26 x 1 3/8 is the one used in Japan? The two types I see mentioned by Sheldon are:
26 x 1 3/8 (S-6), 597 mm, Schwinn, lightweights
26 x 1 3/8 (E.A.3) 590 mm Most 3-speeds, department-store or juvenile 10 speeds
If it is the E.A.3, it would be perfect.
I'll go back to the store to see if I can find an ISO number on the rim. With a bit of luck (and it looks like this will be the case) it should be the 590mm one. This also happens to be what the French would call 650a.
650B [584] is a popular conversion these days from, 27" [630]
or 700c, [622].
and so will have spare tires thru Pro bike shops.
some, comfy supple casing ~ 1.5" wide.
build up the wheels around Drum brake hubs ,
and the reach problem disappears.
or 700c, [622].
