Columbus EL-OS compared to Columbus MAX?
Ive read many different threads regarding Columbus Steels, the hierarchy, user reviews/opinions, and several different catalog pages describing the plethora of steels unique characteristics and primary use. After all this, what I came up with is that EL-OS is just a lighter version of MAX? But how Columbus describes it is "designed to optimize efficiency under the demands of extreme bads: sprint, time trials, climbing and strong centrifugal acceleration when descending". Why does MAX sound more higher end than EL-OS? Wasn't the EL-OS newer tech than MAX?
Bianchi Goddess
Quoted: 2935 Post(s)
Liked 2,930 Times
I believe MAX came first but some found it too much, although it was a very light tubeset for how large the tubing appears.
There was for a short time a MINI MAX tubeset which I understand was EL drawn to the same profiles as MAX but smaller.
I think it mainly comes down to a personal preference. I had a SL frame that loved but when it broke I had the chance to upgrade to MAX. Being a slightly taller and heavier rider I found the MAX an excellent frame for my style of riding, Lighter riders may may find MAX too stiff.
Sugar "Kane" Kowalczyk
Quoted: 4722 Post(s)
Liked 3,039 Times
Columbus EL-OS and MAX use the same alloy but EL-OS uses round tubes that are slightly oversized to achieve stiffness. MAX achieves stiffness by using non-round tubes with oval ends. The orientation of the oval changes, to selectively apply stiffness where needed. For instance, the down tube has the major axis of the oval orientated vertically at the head tube end, for vertical stiffness, but laterally at the other end for bottom bracket stiffness. Similarly the top tube has the oval oriented vertically at the head tube end but laterally at the seat tube end. The seat tube is tapered with a laterally orientated oval for bottom bracket stiffness.
The orientation of MAX tubes provided maximum stiffness in the direction of the maximum force at the end of each tube. With EL-OS, the stiffness was achieved by increasing the diameter but since the tube was round, the stiffness was increased by the same amount in all directions, resulting in a (theoretical) compromise. From this point of view, MAX is more hi-tech, even though it is slightly older. Sometimes you can have too much of a good thing and this seems to be the consensus with MAX's stiffness.
Quoted: 3464 Post(s)
Liked 2,831 Times
Manarti built not too long ago with The MAX tube set.
I think EL-OS is decent enough. Kind of the mainstream answer to the Masi Volumetrica.
Steel is real
Bikes: 40 - accumulated over 40 years
Quoted: 377 Post(s)
Liked 1,089 Times
Quoted: 227 Post(s)
Liked 391 Times
Mid 90's Olympia 56x53 only 1510 grams and stiffest steel frame I've ridden .love it
el-os
el-os
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
My EL-OS Cramerotti also had oversize chainstays, making the frame stiff and inflexible. Didn't like it and I'm heavy.
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
I'd like to try EL-OS or just EL. I've owned and ridden (briefly) both a 61cm MAX and a 65cm MAX bike, both made my Marinoni. I didn't find them to be harsh, and this was before my discovery of Vittoria Open Corsa tires. They were certainly responsive and firm in relaying pavement irregularities (and there are tons here in Seattle's immediate neighborhoods), but really flew when you accelerated. Reminded me of my 2015/6 Trek Emonda ALR (aluminum) frame/bike. Slingshot-esque.
Question. Why is it a compromise for the stiffness to be increased by the same amount in all directions? Is stiffness a win/lose situation? I thought stiffness was a good attribute?
Stated for EL-OS : "..set in the toughest professional competitions.."
So is EL-OS not good for climbing and strong centrifugal accelerations? Are those not "settings of the toughest professional competitions"?
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
All of these criteria are quantitative and subjective, so might best be thought of as the choices of building blocks that framebuilders can select from while designing a particular frame. They would need experience building with the various tubes to apply the dimensional differences to advantage.
I found this Ciocc made from the MiniMAX tubeset, it's mainly fillet brazed because of the non-round tube ends.
I weigh in the140's (lbs) and the bike's dynamics sustain my hardest efforts for what that's worth (sorry for the poor photographic time/location):
Quoted: 4236 Post(s)
Liked 2,949 Times
So the only real difference is that Columbus EL-OS has the same amount of stiffness of the MAX but throughout its entire frame as opposed to MAX which is specifically stiff in certain areas.
Quoted: 1858 Post(s)
Liked 664 Times
I would have to say that with ELOS, at least my 54 cm Mondonico, you are not overbounced, pogoing around on the road. It rather tracks smoothly over road irregularities. Not as smooth as my 42 mm Hetres at 50 psi, but better than my SL Mondonico with 21 mm 105 psi tires. I think it's a good ride from all respects. I can't speak about the comparison to MAX, only to SL, 531, and the TruTemper version of EL, OX-Plat (both .7/.4/.7 with standard diameters.) A physically similar comparator to ELOS should be 853. Some of our colleagues in BF have talked about how good it feels to ride 853. ELOS is simple to describe, being circular: .7/.4/.7, first oversize.
For those who have not liked or preferred ELOS or anything based on "oversized chainstays," I think that comment is kind of hard to use since if you don't give tube cross-section dimensions and butting profile information, we don't know what you're talking about. One rider's oversize could be another rider's noodle.
Liked 664 Times
Stated for MAX : "..demands of extreme bads: sprints, time trials, climbing and strong centrifugal acceleration when descending"
I would say if you are a hors de categorie rider (if such a rating exists), I'd say you should only use the very best tubing, which might be 953 at this moment in the steel universe. If you are merely a mortal bike freak, ELOS just could possibly be satisfactory for 99.7% of your riding -- YMMV.
Now what does beat me up is Brain - thick-walled tubing, first oversize, the standard recipe for an over-stiff bike. Wife's 1997 Terry has that, and while it is quick and smooth it is significantly harsher than my SL bike or my 531 fully db bikes. Ms Terry may have been trying to tame the stiffness when she specified long 43.5 cm chainstays,
Phyllo-buster
Liked 2,055 Times
When I purchased new from Bicicletta, I was told it had oversized stays. I see from the above chart that the MAX chainstays were straight gauge .06 mm while the EL-OS were butted 0.6 -0.8 mm without giving OD measurements. Nuff said. It wasn't dissimilar to my CAD3 C-dale frame. Jarring.
I have not ridden max but have bikes built from SL, SLX and ELOS. I personally love the ELOS. I have two bikes made from it and those are two of my favorite rides: DeRosa Primato and a Paletti.
Liked 3,039 Times
While a stiffer frame is desirable in terms of efficient power transmission, it is not more desirable in terms of comfort, as it transmits more road shock and is more fatiguing Like all things in life, there is compromise between the two and the desired balance will vary depending on the individual, road conditions, terrain and length of rides. To cover the conceivable range, manufacturers offer a variety of tubesets.
EL-OS was intended as a general purpose road tubeset, similar to Columbus' venerable SL. Improvements in alloy (and road conditions) allowed for thinner and lighter tubes, resulting in EL. However, this resulted in loss of stiffness and EL was recommended only for very light riders, those with very smooth cadence or where light weight was the priority. EL-OS recovered the lost stiffness by increasing tubing diameter. This also resulted in some weight gain, though it was still significantly lighter than SL, while having comparable stiffness.
MAX on the other hand is a specific purpose tubeset and this is indicted in the brochure by "extreme loads" ( I think the typesetter mistook " loads" as "bads" by reading the 'l" plus "o" as a "b"). Comparatively, it is stiffer and better than EL-OS in these conditions, provided fatigue is not an issue and weight is not the main priority. It is better suited for rides of shorter duration and/or on smoother surfaces. Personally, I always thought that MAX made an excellent track frame and it's worth noting that MAX appeared at the same time that Columbus' dedicated track tubesets disappeared.
Of course, the above assumes that everything other than the tubeset are equal. Frame builders can notably alter the ride characteristics of a frame via various methods. .
Could you possible shed some light on NEMO tubing? It seems most of NEMO frames are filet brazed, not as many around like MAX, EL-OS, SLX etc albeit newer tubing. Ive seen bikes made of Nemo but never heard people talk/rave about it. No bueno perhaps?
Liked 664 Times
Shuru, I think you can look at the Columbus site and see what they have to say about Nemo. I recall (I think) Nemo, Brain, and Neuron were more or less contemporary. Both Reynolds and Columbus brought out some tubing products designed primarily for TIG and perhaps other lug-free joining techniques. As I mentioned in the thread, My wife has a bike with Brain (no lugs) and it is stiff and sharp.
I would not say ELOS was a refined version of MAX, rather a refined version of SL - perhaps the final feasible refinement, since both are circular tubes. MAX deviates by jumping off into oval cross-sections and by orienting the long axis of the oval (essentially rotating the oval) to compensate tor the greater bending stress at certain parts of the frame.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
ELOS uses what's termed "oversize tubes". This means a 28.6mm top tube and seat tube, and a 31.75mm down tube. The chain stays were also ovalized 24mm. Because the tubes were larger diameter than "standard" sized tubes, which were 25.4mm top and 28.6mm down and seat tubes, along with 22.2mm chain stays, the ELOS tubes could be made thinner to save a little weight while not giving up any stiffness as compared to a "standard" set like SL.
Max on the other hand uses what would be termed XL OS tubes: 31.75 top and seat, and 35mm down tube. The chain stays are larger too. Basically, the Max tubes were both larger and as noted earlier, shaped more to resist deflection. Top of the heap for strong riders, but the larger tubes were heavier so only the strongest of riders typically chose it for their frames.
Bianchi Goddess
Liked 2,930 Times
and sprinting but still have some vertical give to soften road shock. Using the oversized EL OS tubes achieves IMHO a compromise of the two. You get better performance than you would from say a SLX frame but perhaps not as good as MAX might achieve but you have a softer ride.
Bianchi has long sought this sweet spot in reducing BB flex without ride quality suffering. First through their SuperSet frame design using slightly heavier gauge DT and CS tubes and SuperSet II with slightly larger DT ovalized at the BB shell. Then came the Mega Pro frame which seem to have borrowed heavily on MAX influences
Bianchi Goddess
Liked 2,930 Times
That is beautiful Coicc, are there more pics elsewhere?
