Computer and phone mounts
Does anyone mount their cycling computer and phone, if so let’s see those setups. Have a Garmin 530 with out front mount but would also like to mount my iPhone as well. I run a short stem so mounting to a 80mm stem is not a good option.
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 462 Times
For five years running, I use the Quad Lock system, even with an iPhone upgrade along the way.
It mounts on my stem and would certainly fit on an 80mm one. It centers the phone and holds it quite well.
I noticed a few other products on the market, lately, that look like they could capably secure a phone.
Likes For roadcrankr:
mosquito rancher
Yeah, I've experimented with a few methods for mounting my phone. I've also got aerobars, which adds another wrinkle. I wrote about this in my blog, but the TL;DR is that the QuadLock system is good, the Peak Design system is very good.
You can get a Garmin "knuckle" to stick on the back of your phone case, and use any old Garmin mount, but I recommend against that. I've broken two Garmin "biscuits" that way, which I attribute to the fact that modern smartphones are heavier and have a greater moment of inertia, overstressing the mount.
Adam Rice
Adam Rice
Likes For adamrice:
Just a person on bike
Bikes: 2015 Trek 1.1, 2021 Specialized Roubaix, 2022 Tern HSD S+
Quoted: 132 Post(s)
Liked 86 Times
Here's my current setup, using the Quad Lock Out Front Mount (OFM) Pro to hold my smartphone on top and my headlight on the bottom. I mount my Cateye computer on the stem. I bought the handlebar mount to see if it's more cconvenient to mount the phone closer to me and have the cycle computer farther away on an OFM. Since that didn't work, I guess I will stick with this configuration for now.
The value of your life doesn't change based on the way you travel. - Dawn Schellenberg (SDOT)
Likes For daihard:
Bikes: Diamondback "parkway" Spec. "expedition
Quoted: 48 Post(s)
Liked 42 Times
Try this. https://www.amazon.com/Kbrotech-Hand...nder-Extension
Have similar on each of my bikes.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 272 Post(s)
Liked 448 Times
I put the knock block chip for the computer mount on my Fuel EX so I guess there is room on the bars for a phone. There is also a guy who sells an adhesive backed computer mount.
Quoted: 6973 Post(s)
Liked 10,972 Times
Just out of curiosity, why do you want to mount both to your handlebar? After all, the Garmin will show your incoming text messages and phone calls.
