70s F W Evans: Somebody, please cancel my internet
How this bike got to Houston, I doubt I'll ever know, but here it is. From the identifiable parts it appears to be early 70s and the lack of anything brazed on (except maybe cable guides on the bb shell) would seem to agree.. Brakes appear to be MAFAC but the levers, to my eye, don't. Rear seems to be longer reach -- we'll see. 3TTT Record stem with bars I don't recognize. B17 looks to have some life left. Can't ID the crank or seat post, otherwise most everything is easily recognizeable. If all goes well (depending on the current value of "well") I'll own it in a couple hours. What's wrong with me? Is there any help for it?
FW Evans bikes, as far as I can tell, are not well known in the US. They were sold through the Evans chain in the UK and were built in the basement of the Waterloo shop in London. Mr. Fattic, apparently, visited the shop in 1975 and met the guy who built the frames for Evans at the time. Some frames may have been built by contractors, but if they were and by whom is not well established. Seller's pics follow, I'll post some better pics of the frame etc when I get it. Price was reasonable so even if the frame turns out to be low value, I'll be ok.
Likes For desconhecido:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
If the bike is not your size, there's no hope. If it is your size, then you're just proceeding normally for this place.
Likes For thumpism:
Quoted: 5888 Post(s)
Liked 3,471 Times
Lovely bike, nice score.
Likes For bikemig:
I studied the photos for a long time before I contacted the seller and figured it was large 53 to large 54 and that's my best size. Contacted the seller and he said 54 cm, so it's my size. Showed the pictures to my wife and she says, "So, you'll cancel the order for the Bob Jackson." Actually, that's just a joke.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
"Houston, where's the problem?"
Likes For Hudson308:
Quoted: 1088 Post(s)
Liked 1,205 Times
Crank looks like something good and Japanese, like a Sugino Mighty Tour or early Suntour Superbe. I think I see a squiggly little "C" on the seatpost, like a Campy. Lovely bike!
Likes For noobinsf:
Quoted: 4560 Post(s)
Liked 2,802 Times
Heh! I remember that cushy foam bar wrap. Had some on my 1976 Motobecane. Same classic swoopy fork.
Likes For canklecat:
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
I'd posted about one of them in the eBay/CL thread a short while back that looked really nicely put together: https://www.bikeforums.net/21238328-post53143.html
Cool find. Definitely not a name you see often, but one with interesting history. Seems like a lot of the small shops in UK had noteworthy builders. Revell of London was another similar, lots of rumours I've read about some big names manufacturing their frames at some point, Mercian being one of them.
Likes For francophile:
framebuilder
Visiting that frame builder was a great experience. This was right after I had finished my apprenticeship up north at Ellis Briggs in Yorkshire. He was a clever guy and I took a lot of pictures of his gizmos he had made to speed up or refine the process. For example he had converted a sewing machine into a lug filing device. I've asked on the CR list a couple of times who he was and where he came from but have come up empty. He had lots of slogans written on the walls like "there are none so fallible as experts". FW Evans put out an advertising brochure in the late 30's boasting about the advantages of its layout fixture they invented. The cover said "The sure foundation for truth in cycle frames is an accurate jig". The funny thing is that their builder used a different kind of fixture when I was there. The concept of this fixture I have refined with lots of help over the years. I now have them laser cut and etched in Ukraine for my frame building class students .
Likes For Doug Fattic:
Thank you for your recollections. There seems to be very little history available about the FW Evans bikes from the 70s and your comments from back in 2016 are the best that I can find. It very well may be that the day that you visited their shop was the day that the builder was brazing up this bicycle though I would believe it may be somewhat earlier based on the lack of brazed fittings, save for cable terminations around the BB and on the irght chain stay. Oh, and the nub/stud on the down tube to prevent the shifters from taking a ride down the down tube.
The crank turns out to be Sugino. Don't know the model, maybe I'll figure it out later. The seatpost is a Campagnolo 27.2mm, I presume NR. Headset is NR. Cable clamps, pump umbrella, Impero pump head, all Campagnolo. Only Asian parts appear to be the crankset and the bars which are an SR "rando" bend. Underneath the pump umbrella clamp is a 531 decal which appears to be the diagonal DB frame, forks, stays sticker from the early 70s. No trace of decals on the fork legs. Don't know what the crank is doing there, seems unlikely that somebody built the bike almost totally Italian/European but went with the Sugino crank and SR bars, but who knows. The rings on the crank are 50 and 40 so it's only about 5% from the typical 52 42.
I'm not an expert on frame building -- if it can't be found with google, I don't know it. But, from my limited experience with European/British bikes of the 70s, this frame looks pretty good. All the lugs seem to be nicely finished and there are no obvious flaws like the vugs and blobs one might find on some frames. Nothing ornate, but everything clean. Nice fork crown etc.
Turns out the brakes are Racers front and rear and the levers are MAFACs as well. With intact gum rubber hoods. I've never seen brake pads like this in person before and only once seen them in an Ebay ad for some MAFAC Competition 2000 brakes. I previously thought they were some sort of tandem pads but have since learned that the tandem pads were like regular pads but extra long (as I understand it). They seem to still be spongy and serviceable. Cool. edit: Nice shape, too. Remind me of radiatori. edit again: Scott Mathauser brake pads. Says "Mathouser" right on them.
Quoted: 930 Post(s)
Liked 1,292 Times
I certainly hope that you did not cancel the Bob Jackson order!
Velominatus
Bikes: 1986 SBDU Raleigh, 1984 Raleigh Corsa, 1980 Allin Stan Butler Special, 2 x late 1960s Roberts, 1978 Philbook, 1964 Allin Belgique, 1959 Allin Stan Butler Special, 1951 Higgins Plus Parfait, 1951 Hobbs of Barbican, 1913 Centaur Featherweight.
Quoted: 195 Post(s)
Liked 37 Times
The original F.W Evans, don't confuse with the chain of stores of that name, was very famous for being the specialist builder of touring bicycles as early as the 1930s. They were also famous for tandems; my Father had an F.W Evans tandem on which he and a friend made a tour of Devon and Cornwall (from their Surrey home) in July and August of 1945 - my Father was 16.
They used a number of builders in the 1960s and 1970s, Tom Board among them, all top builders...I'd sooner have an Evans than a Mercian any day, the F.W Evans featured looks lovely and has excellent hand finished lug work with superb shorelines.
John.
N.B apropos Mafac brake pads - 3 spots for solo, 4 for tandem pads.
John.
Likes For hobbs1951:
John.
John.
framebuilder
By the way the 1930's F.W. Evans catalog can be seen on bulgie's website here: <https://bulgier.net/pics/bike/Catalogs/FWEvans-late30s/> A picture of Tom Board on the Classic Rendezvous site shows an Evans type of fixture on the wall behind Tom: <https://www.classicrendezvous.com/British_isles/Board_Tom.htm>
Here is a picture of the print I took of their builder in 1975. I never found out who he was. He was a very clever guy and I learned more from him than any other of the many visits I had with other builders.
In the 2016 RoadBikeReview forum thread there were two Evans frames mentioned. The one which was the topic of the thread had been refinished blue with new decals. SN 5377. Reference was made to a frame on ebay but no pictures were available. SN of that frame was 5372. Mine is SN 5095. Recognizing that these were probably sold as bare frames and that the frame might not have been sold right away and that a buyer might buy a frame and not complete the bicycle for a time, there probably is no way to date these things unless there is a secret code to the SN. Interesting, the blue frame in the RBR thread had different lugs, different fork crown, and different seat stay end treatment -- the blue had the flattened wrap around like on the better Flcon Sam Remo bikes.
If the builder was spending a couple days or more to build a frame, he couldn't have been building many more than 50 or so a year so these things aren't going to be found on every corner.
PM me your cotters
Liked 590 Times
Just so the pictures from eBay don't get lost to time, here's the pics from that auction I referenced above.
Bikes: 73 Moto Grand Jubilé, 96 Kona Explosif, 95 Novara Team, 84 Miyata 912, Tern Verge P9, 06 Lemond Sarthe
Quoted: 15 Post(s)
Liked 5 Times
Following this thread with some interest, as I too have an F. W. Evans tourer that somehow found its way to Austin, TX. Scooped it off of local CL for $40 complete last year, and have only just turned my attention to building it back up as more of a "sport tourer" than the expedition rig it came kitted out as. Reynolds 531st, beautifully-finished lugs, decals and transfers all in wonderful shape. I'm looking forward to getting it built up and back on the road!
Likes For rgechols:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
^ Nice!
I finished work on mine about a month ago, slowed down for weeks by a pretty nasty cold that one practitioner said was pneumonia, though certainly not covid. Everything came apart and was serviced except I didn't remove the headset from the frame and fork and didn't remove the BB fixed cup. All cups and cones were in good shape and I didn't really have to replace anything except the sponge on the bars which coudn't be saved even if I'd wanted. So, replaced the sponge with some red Fizik tape, replaced the Campagnolo clamp-on cable guide at the bottom bracket with cable housing as there were brazed fittings for that purpose. The only significant change was the replacement of the Sugino crankset with a NR crankset from about 74 with some SR rings from about 86. Sugino Mighty(I think) is pretty nice, but with everything else being Campagnolo and as I already had the parts it seemed the right thing to do. Tried som 700C wheels as replacements for the 27", but couldn't quite get the brakes to reach, so, 27" Super Champion rims laced to Nuovo Typo hubs remain. Though I did rebuild the wheels, replacing the galvanized Robergel spokes with Sapim stainless.
Put a couple hundred miles on it and am very happy with it, except there is still a bit of squeal with the brake pads. Adjusted almost all of it out, but those Mathouser pads do like to announce there presence. But, the brakes will absolutely stop the bike with those pads and it seems that the noise lessens with use. We'll see -- black Koolstops may be in order.
The ride is great, comfortable, straight, and true.
Here is a photo of the bike today while it was resting in the garden. Silly phone seems to have focused on the background. And, the reds have taken on a purple tone. In person, they are red.
Quoted: 3811 Post(s)
Liked 3,338 Times
Recall that BICYCLING! magazine did a feature article on Evans in the 1970's. My guess is that it would have been around 1974, but that is just a guesstimate. If anyone knows of a directory for back issues of the publication perhaps they could look it up and post it.
Have an expedition size F.W. Evans musette. Colour is raw siena with bright blue silk screen printing in block letters. Dates from early 1970's.
A few links -
https://www.evanscycles.com/help/company-history
F W Evans 1920s-30s
https://lcc.org.uk/articles/london-c...s-evans-cycles
https://www.facebook.com/evanscycles/
https://www.bikeradar.com/reviews/bi...g-bike-review/
https://steel-vintage.com/f-w-evans-...e-1930s-detail
There is/was also an unrelated Evans marque of France. Found a juvenile from this maker which appears to date from ca. 1950. Traded to a collector friend.
A few links -
F W Evans 1920s-30s
Likes For juvela:
