Hand position on drop bars?
Old 11-21-18, 11:32 AM
jackb
Bikes: Trek Domane 5SL Disc; REI Mazama; Specialized Langster
Quoted: 61 Post(s)
Liked 13 Times in 6 Posts
Just curious. What is the hand position you use/like the most on you drop bar road bike, Hoods? Bends?Tops? Drops? I ask because I notice that on different bikes I prefer different positions despite the bike similar bike fit on all three bikes. On my Domane I favor the bends and tops. On my Mazama touring bike I prefer the hoods. On my Spcialized Lanster single speed I also like the hoods. the only time I am on the drops is to fight a headwind or when I come down a steep, fast hill.
jackb is offline
Old 11-21-18, 12:01 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6907 Post(s)
Liked 240 Times in 198 Posts
specifics?
Are the set ups quite different from each other? or all the same?
Being in such a variety, what is the style of drop bar bend in each case..?
fietsbob is offline
Old 11-21-18, 12:06 PM
Fahrenheit531
50th Anniversary Edition
Fahrenheit531's Avatar
Quoted: 568 Post(s)
Liked 93 Times in 51 Posts
Drops, almost exclusively. I used to be ramps/hoods 90% of the time, but evolved away from that over the last year or two.
Fahrenheit531 is offline
delbiker1
delbiker1's Avatar
Bikes: 1991 Ochsner steel frame, 2002 Airborne Zeppelin titanium, Schwinn DBX SS aluminum, Orbea MD 40 carbon fiber
Quoted: 242 Post(s)
Liked 79 Times in 54 Posts
I spend much more time on the hoods than any other area. I do change positions frequently and use pretty much the whole handlebar, just not as much as the hoods. I also change position in each one of the specific areas, forward or backward, side to side, straightening, bending the arms and just sort of rolling my shoulder hands or wrists. I have spinal and shoulder issues and even just making small adjustments helps to minimize the stress/fatigue factor. Along that same line I use a more relaxed set up on my bikes. Like bikes themselves, what you like and are comfortable with are very personal. I think for most people that is an ongoing adaptation from bike to bike.
delbiker1 is offline
Old 11-21-18, 12:08 PM
wipekitty
vespertine member
wipekitty's Avatar
Bikes: Yes
Quoted: 584 Post(s)
Liked 79 Times in 59 Posts
I'm about 50/50, hoods and drops between three bikes with three different fits - a road bike that's about perfect, a single speed that's a bit more aggressive (smaller frame and lower stack), and a gravel bike that's a bit less aggressive.
I probably end up using the drops just a bit more on the road bike. I'm more likely to climb in the drops on the road bike or gravel bike than the single speed, and more likely to hit rollers in the drops on asphalt vs. gravel. Always drops for descending, unless on ice.
Tops? Never.
wipekitty is offline
Old 11-21-18, 12:11 PM
wipekitty
vespertine member
wipekitty's Avatar
Bikes: Yes
Quoted: 584 Post(s)
That's awesome
I always feel weird in a paceline when I notice that I'm in the drops and everyone else is on the hoods. For a lot of riding, the drops just seem more comfortable.
Old 11-21-18, 12:34 PM
Troul
:D
Troul's Avatar
Liked 26 Times in 17 Posts
Drops unless it's a slow ride with no to little activity from other obstacles
Troul is offline
Old 11-21-18, 12:43 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 2295 Post(s)
Liked 46 Times in 44 Posts
The OP was the one asking the questions.
Sy Reene is offline
Old 11-21-18, 01:15 PM
grout
Hoods almost exclusively...or down on the clip-on aero bars, which is easier on the wrists (but only when safe to do so).
l rode on the drops more with my last bike as it had compact bars...haven't gotten around to buying them for this one yet.
grout is offline
Old 11-21-18, 01:36 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
OP obviously a Roadie , I'm Not.
Several, varies, that's why they were chosen..
Bike touring , has my day long upright ish posture favoring..
Randonneur bend bars,
the last long tour I had a custom fabricated stem ,
combining 2 narrow ones,* to be as wide on the top, as my road bike
(road, Nitto, From an early MB1.. drops parallel, bottoms flare
(bar end shifters)
previous..
(Specialized badged Nitto) set they were narrower... drop flares , bottom parallel
sizing is across the bottom, so a 46 bottom but 38 top..
Now I mostly use trekking bars or straight bars ,
With Ergon Grips/bar end shifters ...
with IGH Drivetrains.. not derailleurs..
* having them come apart was an advantage in packing the bike
in an airline carton, to fly across the Atlantic , to tour , over there..
carry on kids..
fietsbob is offline
Old 11-21-18, 01:39 PM
Kedosto
Ambulophobic
Quoted: 437 Post(s)
Liked 126 Times in 77 Posts
Hoods 99% of the time.
-Kedosto
Kedosto is offline
Old 11-21-18, 01:43 PM
wgscott
Occam's Rotor
Quoted: 2366 Post(s)
Liked 230 Times in 144 Posts
Yes
wgscott is offline
Old 11-21-18, 02:08 PM
sdmc530
Heft On Wheels
sdmc530's Avatar
Bikes: Specialized,Cannondale
Quoted: 571 Post(s)
Liked 104 Times in 78 Posts
80% hoods, 15% the flats and 5% on the drops...just the way I roll I guess
sdmc530 is offline
Old 11-21-18, 02:48 PM
Lazyass
Lazyass's Avatar
Bikes: Vintage steel, aluminum, modern carbon disc, single speed, MTB's, the works
Quoted: 1912 Post(s)
At a cruising pace I'm usually down grabbing the tips. I like bars with long tips. On one set of bars I actually bought some Control Tech 20mm bar extensions because they were too short.
Lazyass is offline
Old 11-21-18, 02:50 PM
Lazyass
Lazyass's Avatar
Originally Posted by mtb_addict View Post
I see the older road bikes...the bar is higher....the newer compact road bikes...the bar is very low.
So, I think with newer compact geometry, you are forced to ride on the Hood. No way I can bend low enough to hold it in the Drop position on these compact geometry frame.
For this reason, I like the older diamond frame with horizontal top tube...I can get the handlebar quite high.
Compact geometry has nothing to do with stack height. Bars today tend to be lower because that's the modern "look". Which is also why most riders have their hand glued to the hoods. My vintage bikes have almost all had shorter head tubes than my modern bikes.
Lazyass is offline
Old 11-21-18, 02:53 PM
BobbyG
BobbyG's Avatar
Bikes: 2015 Charge Plug, 1997 Nishiki Blazer, 1984 Nishiki International
Quoted: 849 Post(s)
Liked 128 Times in 75 Posts
+1 without spinal and shoulder issues, but with hand issues.
BobbyG is offline
Old 11-21-18, 08:56 PM
50PlusCycling
50PlusCycling's Avatar
Quoted: 96 Post(s)
Liked 6 Times in 5 Posts
I use them all, and adjust my position regularly on long rides. Often I don't even put my hands on the bars, but rest my forearms on the tops of the bars. This makes me a little more aero, and gives my hands a little break (which is necessary on rides longer than 100 miles). The reason to run road bars is to offer a variety of positions for a variety of riding positions.
50PlusCycling is offline
Old 11-22-18, 02:23 AM
Leinster
Quoted: 64 Post(s)
Liked 8 Times in 7 Posts
Hoods for “just riding along.” Sometimes on tops if sighting is more important than access to brakes.
Hoods or tops for climbing. Hoods if out of saddle.
Drops for descending. I hit a pothole on a fast downhill on the hoods once and my bars bent down. Very nearly came off. Drops 100% ever since.
Drops or “invisible aero bars” when riding hard on the flat. Sometimes hoods for a change of position.
I have bullhorns on my single speed, and they just aren’t versatile enough.
Leinster is offline
Old 11-22-18, 05:32 PM
NoWhammies
NoWhammies's Avatar
Quoted: 410 Post(s)
Liked 61 Times in 43 Posts
Hoods 60% of the time
Tops 20% of the time
Drops 20% of the time
NoWhammies is offline
Old 11-22-18, 11:47 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '18 class built steel roadbike, '19 Fairlight Secan, '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara Trionfo, '18 Diamondback Syncr
Quoted: 3180 Post(s)
Liked 283 Times in 195 Posts
Are newer bikes using actually lower bars, or is there just less spacer height and so it seems like the bars are lower?
I ride 63-65 cm road bikes. With traditional horizontal top tube geometry, the stack height is close to the seat post height which is the bike measurement.
the same stack height on a modern frame can be had woth a 58cm seatpost.
mstateglfr is offline
Old 11-23-18, 10:55 AM
mackgoo
mackgoo's Avatar
Bikes: 87 Bianchi X4, 96 Bianchi Ti Mega Tube, 06 Alan Carbon Cross X33
Quoted: 107 Post(s)
Liked 7 Times in 5 Posts
For me it depends on the bike.
X4, I'm virtually always in the drops. It feels weird on the hoods as the brake levers are on the downward portion of the bars. When I'm on the hoods I have this uneasy sensation of going over the front of the bike.
Ti Mega tube, I have a set of Cinelli Spinacholi (?). I'm getting to really like these things. In this case I rest my forearms on the top of the bars and I rest my hands on the Spinocholi's.
Carbon Cross, virtually all the time on the hoods.
mackgoo is offline
Old 11-23-18, 12:30 PM
Cougrrcj
Over forty victim of Fate
Cougrrcj's Avatar
Bikes: A few...
Quoted: 301 Post(s)
Liked 11 Times in 8 Posts
I generally ride on the Tops, or the 'shoulders' where the top starts to bend forward, or drops if heading into a strong wind. Never on the hoods since my bars are deep drops, and the brake levers are waaaay out front. In fact my old Fuji doesn't even have hoods!
'75 Fuji S-10S bought new, 52k+ miles and still going!
'84 Univega Gran Tourismo
'84 Univega Viva Sport
'86 Miyata 710
'90 Schwinn Woodlands
Huffy MTB - for trips to corner store
MTB of questionable lineage aka 'Mutt Trail Bike'
Cougrrcj is online now
Old 11-23-18, 12:39 PM
winston63
winston63's Avatar
Bikes: Specialized Diverge E5 Comp, Specialized AWOL Comp, Scott Solace 10
Quoted: 118 Post(s)
Liked 7 Times in 6 Posts
Mostly the hoods, but I'll mix it up, especially on long rides. Usually I'm in the drops on descents or when riding into headwinds.
winston63 is offline
Old 11-23-18, 07:01 PM
veganbikes
Clark W. Griswold
Bikes: Foundry Chilkoot Ti W/Ultegra Di2, Salsa Timberjack Ti, Cinelli Mash Work RandoCross Fun Time Machine, 1x9 XT Parts Hybrid, Co-Motion Cascadia, Specialized Langster, Pink Klein MTB, Phil Wood VeloXS Frame (w/DA 7400), Cilo Road Frame, Proteus frame
Quoted: 1183 Post(s)
Liked 45 Times in 32 Posts
Generally on the hoods is where I spend most of my days (that or the playground) but since many of my bike use Ergo top section bars I also will spend some time there because it is also comfortable. I am not often in the drops but I am not a flexible person especially these days. If I had any vintage style bars I don't know where I would want to keep my hands, I generally dislike those bars because of the positioning. I know they worked for Merckx but as much as I love Eddy, I am not him and will never even be an iota close to him.
veganbikes is offline
Old 11-23-18, 07:45 PM
FlMTNdude
Bikes: 1988 Panasonic
Quoted: 87 Post(s)
Liked 21 Times in 18 Posts
80% drops most rides, 100% on commutes. If the fit is right drops should be comfortable.
FlMTNdude is offline
