Possible to decrease brifter “throw” length?
Old 03-01-19, 10:13 AM
Dschmale
BMX commuter gone roadie
Bikes: Cheap ones
Quoted: 22 Post(s)
I’ve searched and found only adjustments to the shifter/brake lever reach. Is it possible to adjust the throw, or distance required to shift? It seems like I really have to push the things far on the larger levers to make shifts happen. I’m reading similar impressions but no solution thus far. I guess I just assumed they’d be quicker. Perhaps adjusting the reach inward would give me some more finger to work with but I feel like there must be a direct adjustment for throw.
For reference, I have Tiagra shifters and FD, and a 105 RD.
PS. Thank you all for tolerating my super fundamental questions.
Dschmale is offline
Old 03-01-19, 10:28 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1198 Post(s)
Liked 54 Times in 41 Posts
I doubt it.
Index shifting requires the shifter to pull a precise amount of cable for each shift. The amount of cable has to match your derailleur geometry and the distance between cassette sprockets.
Retro Grouch is offline
Old 03-01-19, 10:51 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6905 Post(s)
Liked 239 Times in 197 Posts
Di2
fietsbob is offline
Old 03-01-19, 11:04 AM
jadocs
jadocs's Avatar
Bikes: Litespeed T2 Disc, Fondirest P4 Carbon, Fuji Cross 2.0, Specialized Fatboy
Quoted: 362 Post(s)
Liked 91 Times in 70 Posts
Di2
Ha, Beat me to it
jadocs is offline
Old 03-01-19, 01:37 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1767 Post(s)
Liked 100 Times in 76 Posts
Not sure if it would help in your specific instance, but it appears to be possible in principle, at least.
Jtek ShiftMate Gear Shifting Adapter for Shimano Campagnolo and SRAM components
JohnDThompson is offline
Old 03-01-19, 02:43 PM
KCT1986
Quoted: 20 Post(s)
With all the Shimano levers I've worked on, there was not any way to change this. The lever must move the predetermined amount to engage the detent. The left side has intermediate (trim positions) that will engage on most models, making the full shift a shorter throw. The right has only full steps, with the throw from the smallest cog to the next extra long to take up any cable slack.
Adjusting the reach may help, as well as position on the shifter on the handlebar. Rotate as far outward as feasible, and up/down on the bar depending on bar shape.
Not sure if the Shiftmate would do any good since the shift lever will need to move the full amount to "lock in" the shift. Changing the pull will shift the chain but if the shifter doesn't move enough to engage the detent, it won't remain in position.
If someone has solution, I'm very interested.
KCT1986 is offline
Old 03-01-19, 03:41 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 718 Post(s)
Liked 89 Times in 70 Posts
You can't even repair them, much less modify them.
dedhed is online now
Old 03-01-19, 04:44 PM
CliffordK
CliffordK's Avatar
Quoted: 8915 Post(s)
Liked 138 Times in 115 Posts
The question would be whether the throw would be uniform across Shimano levers and speeds.
Another option is to look at different brands.
Shimano is one of the few brands that pivot the entire brake lever.
Campagnolo and Microshift have a second shorter shift lever that sits behind the brake lever. I haven't used SRAM.
CliffordK is offline
Old 03-01-19, 07:53 PM
KCT1986
Quoted: 20 Post(s)
Some of the newer Shimano may have a shorter throw, per some reviews of 11 speed I've seen. This may be a function of the redesign of the mechanism when they went to "under-tape" routing for the later models. Haven't tried the 10 speed shifters so I don't know if there is difference between the 10 speed exposed cable (eg 6600) vs "under-tape" (eg 6700) lever throws.
KCT1986 is offline
Old 03-02-19, 05:54 AM
dabac
Quoted: 829 Post(s)
Liked 9 Times in 8 Posts
That will change the amount the derailer moves, but will not change the amount of lever movement needed to go from one gear to the next for an indexed shifter. It would change the amount of lever movement for a friction shifter.
Only option I can see for the OP is t ask around/try different make/models, see which is preferred. Maybe a Thumbies conversion on a pair of bar end shifters?
Or go electric.
dabac is offline
Old 03-02-19, 06:04 AM
cb400bill
Moderator
cb400bill's Avatar
Bikes: Fuji SL 2.1, Schwinn Voyageur, Cannondale Synapse
Quoted: 1339 Post(s)
Liked 135 Times in 79 Posts
Di2
It's what I did.
cb400bill is offline
Old 03-02-19, 06:36 AM
Racing Dan
Racing Dan's Avatar
Quoted: 762 Post(s)
Liked 14 Times in 12 Posts
Imo, No. The shifting mechanism/ratchet is inside the brifter. Maybe SRAM is better? That or get DI2, or a bar end shifter.
Racing Dan is offline
Old 03-02-19, 06:53 AM
Retro Grouch
I don't see the Jteks addressing the OP's question. They'll alter the amount of cable pull with each shift, but not the amount of lever movement to make that shift.
samit
For Sale
0
04-10-19 10:26 PM
milosbn
Classic & Vintage
2
03-06-13 11:55 PM
Lexi01
Road Cycling
33
01-24-12 03:52 PM
j_amie_
Road Cycling
18
08-09-08 07:15 PM
