Bolt style rear axle , should washer sit inboard or out board of frame ?
Old 03-09-19, 03:00 PM
jambon
Quoted: 104 Post(s)
Hi
Can anyone help me here .
I have removed a rear wheel which has the older bolt style fixing not the modern QR
There are a pair of washers on the axle right next to the axle bolt on both sides. Similar to where those lawyer tabs would sit in the assembly but these are not lawyer tabs just regular circular washers about 2.5mm thick.
Should these sit outside the dropouts against the nut or inside the dropout against the frame ?
Cant figure this out
jambon is offline
Old 03-09-19, 03:18 PM
nfmisso
Nigel
nfmisso's Avatar
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times in 6 Posts
Outside the frame.
The punch direction (sharp side) facing the frame, and the rounded side facing the nut.
The washers job is to allow the nut to be smoothly tightened without digging into the frame.
The locknut on the end of the axle is often stamped (knurled/patterned) with anti-rotation features to dig a little into the frame, when the wheel nuts on the outside of the frame are tightened.
nfmisso is offline
Old 03-09-19, 04:06 PM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
Depends.
On a properly assembled and cared for bicycle, the washers should sit on the outside of the dropouts.
But it does happen that bikes bikes that has lived an ”interesting” life have rear wheels where washers on the inside is needed to make up for a spacing mismatch etc.
dabac is offline
mastershake916
Bicycle Mechanics
18
06-07-14 08:22 AM
fixitfelix
Bicycle Mechanics
3
01-15-14 03:29 PM
enuenu
Bicycle Mechanics
6
05-01-12 08:11 AM
harshbarj
Bicycle Mechanics
7
10-17-11 04:11 PM
Jez
Singlespeed & Fixed Gear
6
05-14-11 01:47 PM
