Pedals for gravel/pavement mix ?
Quoted: 49 Post(s)
Hey,
I assume some folks in here ride a mix of pavement and gravel. I'm looking to try some local group rides and want to hit gravel grinding and road rides and want to also switch to clipless and get a proper bike fit. I have rough knees and initially thought speedplay frogs but after some more research found many people dont need a ton of float to get relief on hard rides. That had me considering something like the zero. I'm wondering if i should look at a different pedal or if anyone had suggestions ? The zero concerns me some regarding dirt on gravel rides. The pave is interesting although not very cheap. Then the whole world of SPD setups but i always thought those didnt handle dirt too well.
Quoted: 1975 Post(s)
Liked 232 Times
Any of the SPDs would handle dirt well and if you pick a good stiff XC shoe it will do both road and gravel well. In terms of pedals, double sided I'd say XT is best bang for the buck and for single sided A600 or the new es600?
Quoted: 49 Post(s)
Shoe should be stiff, I actually have a very wide flat foot so shoes have been an issue. I have some Bont riot + on the way and i'm hoping once heat molded they will work for me. If so i'll probably go up to one of their higher end models once i verify fitment.
Quoted: 6963 Post(s)
Liked 10,963 Times
Shimano XT Race pedal is widely available for under a hundred bucks and is a great value.
Quoted: 696 Post(s)
Liked 910 Times
I use XTR that were on sale at Jensen.
SPD. I use them on my road/gravel bike, which I ride about 80/20 road/dirt.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Everyone is different but I found no issues going from full floating to non-floating pedals. Personally, I think Speedplay makes a bigger deal out of it than it really is. I actually enjoy having my feet more locked in at the end of a long ride when I'm tired and form is getting sloppy.
I have a friend who is having a bear of a time trying to get Frogs working.
SPD are ubiquitous. M520 are dirt cheap if you want to try them and they come with cleats. XT or XTR are extremely popular. At the high end are EXPDO Titanium.
Make sure you get the right cleats as there are two types. SH51 are single release for aggressive riding and racing. SH56 are multi release for touring and fitness riding. The SH56 can pull out if you ride really hard.
-Tim-
-Tim-
Quoted: 49 Post(s)
tried it, stuck between 42.5 and 43 and lake says heat mold the 42.5 and itll prob work. too much coin for a maybe. the bont shoe is less than $200 so i wont feel bad if it doesnt fit after molding. legit probably tried and returned $5k in shoes nothing is wide enough
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
If you don't need tons of float, XT or XTR are great at what they do-cleats are cheap and available anywhere, the pedals are durable and so are the clears, pedals are rebuildable, nice quality....only thing not to love, is they aren't the best at mud shedding as in CX.
If you do need tons of float...TIME ATAC are a great bit of kit to from what I hear.
Not too many shoes out there in wide....and the ones out there tend to be expensive....Most shoes, including many nice ones only fit narrow feet.
Quoted: 1136 Post(s)
Liked 650 Times
If you get a nice pair of flat pedals you can wear whatever shoe you want. Plus flats are better for learning handling skills off-road. Clipless just lets you cheat your way out of learning how to bunny hop and lift the bike up naturally.
I have used Shimano Saints and Crank Bros Stamps on road/gravel bikes and they both work great. No speed difference between that and an SPD setup.
Unless you're road racing, clipless is a scam IMO. Expensive, limits your options, and impractical for off the bike. Lots of MTB pros use flats.
Just finidng my cadence
Bikes: Motobecane Ti Century Pro, Catrike 559
Quoted: 7 Post(s)
Please let us know what you think of the Bont shoes...
Quoted: 49 Post(s)
I have the same problem and have been looking at the Bont shoes. I got a pair of Lake CX241 series shoe and they are AMAZING for my EEEE wide feet. Since these are road shoes I have been thinking of getting the MX (Mountain Bike) version but am having a hard time justifying another $350 purchase.
The Endurance also having the more protective front-end.
Quoted: 1872 Post(s)
Liked 692 Times
Bro if Lakes extra-wide isn't wide enough then you have concrete blocks for feet. Also, there's no way you're stuck between a 42.5 and 43. I can easily switch between my 45 and 45.5, there's only just a smidge of extra room in the toe. But we're cycling, not playing basketball, our feet stay in the same position within our shoes. You need a mtb pedal like an SPD, and stiff carbon soled shoe. Done.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Likes For shoota:
Liked 650 Times
Has this happened to you? If so, on which pedals? Modern mtb flat pedals have pins that "cling" to the bottom of the shoe. I ride quite a lot of gravel and singletrack and my feet are quite stable on the pedals, even in the wet. A lot of enduro and downhill riders also use flats and their terrain is a lot rougher than what you see riding gravel on a drop bar bike.
Liked 692 Times
But you're right, the studded flat pedals are perfect for putzing along.
2019 Salsa Warbird
2019 Salsa Warbird
junior
Bikes: 2020 Surly ECR / 2018 Norco Search XR steel gravel bike with GRX / 1983 Bianchi Campione D'Italia / Gary Fisher Wingra / Motobecane Nomade mixte (daughter's)
Quoted: 72 Post(s)
Liked 12 Times
My Buddy has the Shimano SPD M520
https://www.jensonusa.com/Shimano-PD-M520-SPD-Pedals
He doesn't have a car. He's been riding his bikes (Surly Disc Trucker is the main one) everywhere for everything 12 months a year rain or shine for decades. He is on the same set of pedals, and not only rides in the city, has done some bike packing, and has started riding gravel with me. No issues whatsoever for him.
I sprung for the 540 model since i liked the idea of the all-metal axle design (on sale at Jenson for $45 last year). And there's almost too much float for my taste (specs say 5 degrees). I ride maybe 60/40 pavement/gravel. From what I've read, these Shimano pedals simply last and last. I don't think you'd need anything else. And I used to be anti-Shimano back in the 80s and 90s.
As an aside, my Race Face Chesters ($40-$50) grip my five tens like glue. i had to focus and consciously lift my foot to move the shoe, those pins are that good. But i did only average trail mtb riding before moving to the gravel bike. Nothing too sketchy.
eric/fresno, ca.
eric/fresno, ca.
Back to the OP. What exactly are you asking about, different types of clipless types and if they work on gravel vs road? The shoe and clipless that works for you will get the same result on road or gravel. Proper fit, comfort, float, hardness, and cleat position is what it is and applies equally on gravel rides and road rides.
I used to be in practice to flip over both pedals at once, with Lyotard 460D pedals , toe-clips and straps
as soon as I jumped back on the bike..
Quoted: 479 Post(s)
Liked 277 Times
I actually used pins in the early '80s...
Liked 650 Times
What do you consider "modern"? I had pedals (actually still have an ancient set) with pins 30 years ago. They're not some revolutionary breakthrough in pedal technology. I raced a hardtail mtn bike with SPDs in the early/mid '90s, swapped to the flats and did trials (same day events) on the same bike. The flats have killer grip. They also let you put a foot down or out for balance. They have their place - BMX, trials, downhill, jumping, etc. But they really suck for efficient pedaling. I have seen guys with flats on XC trails... they're usually really cool and move out of our way as we ride by
Is that a pic of you? Way cool. I just finished building an '86 mtb with period first generation Deore XT parts, Specialized slingshot stem and risers, etc...
