Mounts that attach to stem via pinch bolts: safe?
Bikes: 2017 Ridley Fenix SL, 2008 Trek 1500, 1998 Diamondback Apex
Quoted: 33 Post(s)
There are several generally well-reviewed mounts for cyclos (Wahoo, Garmin, etc) that mount to the bike via the stem pinch bolts. The idea seems clever enough, but I wonder if it results in any sort of "weak spot" on the bike. Has anyone used these? Do you have a take on how secure they are? Is there any sort of "official" word on whether using this sort of mounting setup runs a risks of premature equipment failure? etc
Random example of what I'm talking about
I pedal in my sleep...
I use one, seems to work fine.
Likes For str8jakett:
Quoted: 636 Post(s)
Liked 1,489 Times
I don't have one but just looking at how they mount, I don't see how it would put anything at risk of failure. I might put some loc-tite on the screws to make sure they stayed tight, but otherwise the only thing I see at risk of breaking is the mount itself if you got in a crash.
Likes For Ogsarg:
Quoted: 241 Post(s)
Liked 231 Times
Ritchey sells a GoPro mount for their stems the uses the pinch bolts. I'd guess they think they're okay.
Likes For RGMN:
I'd imagine that so long as the length of the pinch bolts is adequate, you shouldn't have anything to worry about. If the thickness of the mount is enough that you've only got 1-2 threads on the stem, you might have a problem but then again, I wouldn't be surprised if these mounts come with longer bolts to replace the stem's pinch bolts.
Likes For BassManNate:
Quoted: 152 Post(s)
Liked 173 Times
I had a combo one on my the bike I just traded and never had an issue with it. Bolts were sized correctly and were as tight when I removed it as when I installed it. Be aware on the cheaper non-adjustable ones you can't adjust the angle of the GPS since it is fixed at the stem angle. May or may not be an issue. A few dollars more gets you an adjustable one.
When my Edge 530 gets here in a couple of weeks I think I will bite the bullet and spring for a K-Edge combo mount for the GPS & light.
Likes For August West:
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Likes For Marcus_Ti:
Advocatus Diaboli
Quoted: 4717 Post(s)
Liked 1,526 Times
Looking at the linked example, I'd guess you'd want some assurance of the material itself used being of sufficient quality. I don't imagine any of the bits in this product's diagrams below are plastic?
Likes For Sy Reene:
Advocatus Diaboli
Liked 1,526 Times
https://f3cycling.com/formmount
Likes For Sy Reene:
Quoted: 33 Post(s)
