RAGE!!! Tubeless Deep Profile rims and fishing nipples
Old 06-26-19, 10:39 AM
ChinookTx
Bikes: Kona Rove Ti., Motobecane Whipshot Ti
Quoted: 99 Post(s)
Liked 48 Times in 35 Posts
I've been raging for a few hours last night trying to fish nipples through a tubeless deep profile rim. It only has an opening at the valve hole, so it's not easy to fish anything through. I've seen a few people that suggested using an air compressor and a piece of string in the spoke hole that is supposed to pop out the valve hole, attach nipple, fish through, repeat. I'm having limited success with that, it never seems to make it to the valve hole.
Any other tips people are using? Clearly, swearing doesn't work!
ChinookTx is offline
Old 06-26-19, 11:06 AM
AnkleWork
Bikes: old clunker
Quoted: 570 Post(s)
Liked 34 Times in 23 Posts
Magnet.
AnkleWork is offline
Old 06-26-19, 11:07 AM
alcjphil
alcjphil's Avatar
Quoted: 593 Post(s)
Liked 46 Times in 34 Posts
This is how it is done for Campagnolo wheels. My Shamal wheels were shipped to me with a strong magnet and a steel mini spoke for just this purpose
alcjphil is offline
Old 06-26-19, 11:15 AM
ChinookTx
Quoted: 99 Post(s)
I'm ashamed to say I didn't think of a cut off ferrous spoke screwed into the nipple and a magnet... Will give this a try tonight.
Old 06-26-19, 11:17 AM
ChinookTx
Quoted: 99 Post(s)
1 extra spoke .. screw it on up side down, hold it against the end of the spoke and unscrew it from one
and start it on the other spoke..
Not sure I get what you're saying. Tubeless means there's no spoke hole on the inside of the rim, at least in this case.
Likes For ChinookTx:
Old 06-26-19, 11:19 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6908 Post(s)
Liked 240 Times in 198 Posts
I'll pass..
I feel no need to follow the latest trends you others feel compulsory ....
stainless wire for spokes may also not be magnetic either .. older Zn treated steel spokes may be what you want..
fietsbob is offline
Old 06-26-19, 01:29 PM
ChinookTx
Quoted: 99 Post(s)
I honestly don't give a rat's butt what trends you follow or not. What I care about is you butting into every thread and giving your half-***** opinion in cryptic sentences that read like haikus.
It's not the 50s anymore, get on with it. Thanks to the others for their suggestions, off to the garage to give this another go.
Old 06-26-19, 02:27 PM
ChinookTx
Quoted: 99 Post(s)
Thanks for the video @alcjphil (and those who suggested magnets)!! 10 minutes with a magnet, a small nail cut short and threaded through the nipples and my wheel is all laced with spokes. Can't believe I didn't think of this yesterday...
Old 06-27-19, 06:37 AM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '71 Jeunet 630, '79 Peugeot PXN10LE, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022
Quoted: 626 Post(s)
Liked 132 Times in 80 Posts
Fishing Nipples would be a good name for a rock band...
Phil_gretz is offline
Likes For Phil_gretz:
Old 06-27-19, 07:51 AM
Troul
:D
Troul's Avatar
Liked 29 Times in 19 Posts
I've used fishing > string fed from the ext. spoke hole > between the rim channel > to the access point of the inner rim > then thru the center of the nipple - making a large enough knot - that will allow the nipple to be > pulled into place > as needed using the fishing string.
Troul is offline
Likes For Troul:
Old 06-27-19, 11:10 AM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 749 Post(s)
Liked 63 Times in 51 Posts
Hilarious!
But this makes me think of putting the hook into them. Would be painful. And if a fish with sharp teeth took a bite - owww.
WizardOfBoz is offline
Old 06-27-19, 11:13 AM
WizardOfBoz
Quoted: 749 Post(s)
Quick electrical tape cover over all unfilled holes except the one you are threading. Stick the and of a string into that hole. Use a shop vac or dustbuster to suck the string through. Tie the stub spoke to the string (with nipple attached) and pull through. Would that work?
Old 06-27-19, 06:37 PM
ChinookTx
Quoted: 99 Post(s)
It probably would work too! I feel dumb for not thinking about all these good ideas!
