Tannus Airless Solid Tire Review--Unstable, Slow, Faster Wear, Pricey
Old 07-30-19, 12:56 PM
cvandam
I have commuted 20 miles round trip most weekdays for a year (around 3,500 miles) on Tannus solid tires Shield 700x32c.
After a year of almost daily use I'm going to swap them out for probably Shwalbe Marathon Plus tires--I'm also interested in trying tubeless but need to learn more. The downsides of the Tannus solid tires are too many to overcome the no-flat upside. My biggest gripe is how they feel and handle. Tannus says these tires are 80 psi equivalent. When I ride on them it feels like I'm riding on hot tar on the road. The tires flex and catch on grooves and ridges in the road, making them feel very squirmy and unstable, especially when going downhill (faster speeds) and when turning. You can feel them flexing and shifting a little underneath you as you ride. At times it feels like they might roll off the rim, though that's never happened. I had a Tannus-certified bike shop install the tires and after I felt that unstable flexing I went back to the shop to be sure they were installed correctly--it wasn't the installation, it's just how those particular tires handle.
It seems to me that the tires are also slower than equivalent pneumatic tires--more rolling resistance is my guess.
Tannus says these tires should go 5,000 miles, but at around 3,500 miles my rear tire is already wearing flat and as a result it increasingly feels unstable and has a harder time cornering. Not impressed with how quickly they're wearing. I believe I could get 6,000-8,000 miles on Shwalbe Marathon Plus tires (twice the wear of the Tannus).
The Tannus tires are $80 compared to $57 for the Shwalbe Marathon Plus tires. For the money, the Tannus tires are not worth it in my opinion after a year of solid use.
If anyone wants to weigh in on whether I might choose to go with tubeless over the Marathon Plus tires I'm all ears. Can I use my existing wheels for tubeless? I'm not excited about spending more on wheels right now.
cvandam is offline
Likes For cvandam:
Old 07-30-19, 01:38 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 3861 Post(s)
Liked 360 Times in 235 Posts
As was going to ask what kind of rims you have, but the Marathon Plus HS440 is not Tubeless Easy, so it doesn't matter. In touring/commuting from Schwalbe, only the Marathon Almotion HS453 and Marathon Supreme HS469 are tubeless-ready-- and they're both around 80 bucks a tire.
DrIsotope is offline
Old 07-30-19, 01:42 PM
himespau
himespau's Avatar
Quoted: 1434 Post(s)
Liked 36 Times in 26 Posts
You've given them a longer trial that I would given the ride feel you describe. Are flats that common of a problem where you ride?
himespau is offline
Old 07-30-19, 01:44 PM
2_i
Bikes: Trek 730, Bike Friday NWT, Brompton M6R*2, Trek 830, Trek 720, Dahon HAT060, Dahon HT060,...
Quoted: 352 Post(s)
Liked 13 Times in 11 Posts
Thanks for the report! If you managed to stick with them for a year of commuting, I would say that they are not that bad . My airless experience is with the Mobike share bike tires and they are pretty heavy going. I can tolerate them on a share bike, but I would not tolerate them for any length of time on my own everyday bike. I have not run Schwalbe Marathon Plus to the ground, but I have Schwalbe Marathon XR and the tire started to fall apart under 4K miles.
2_i is offline
Old 07-30-19, 03:45 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 1561 Post(s)
Liked 164 Times in 104 Posts
paging @CliffordK for an update
Genesis 49:16-17
Darth Lefty is offline
Old 07-30-19, 04:12 PM
CliffordK
CliffordK's Avatar
Quoted: 8906 Post(s)
Liked 136 Times in 113 Posts
My notes are here:
https://www.bikeforums.net/general-c...olid-tire.html
I have been off of the Tannus tires for a couple of years (700x25 size). Still mounted, and may return to them in the winter. The rear has worn quite a bit. Front still looks good, but mounting was a big enough of a hassle that there is no reason to rotate.
I do support the idea of pneumatic tires (various brands) for summer riding when flats are less frequent. But, that would more or less require swapping wheels or bikes.
I will probably install a set on my trailer sometime.
CliffordK is offline
Old 07-31-19, 10:26 AM
CliffordK
CliffordK's Avatar
Oh, another thought. I did try a Schwalbe Marathon Plus (700x25) tire. I thought the tire had great traction.
However, the first week of riding it, I picked up a piece of glass the size of a pinky fingernail. It cut through the rubber, and did some thread damage.
I attempted to boot, and rode that tire for a while. But, it eventually ended up being a critical failure.
For another couple thousand miles, a few small cuts in the rubber, but no additional critical damage spots.
A competing tire is the Michelin Protek Cross Max. They don't have 25mm sizes, but I think have 32mm and 35mm sizes. I thought the Protek Cross Max tires were a little slower than my road tires, but I put on quite a few miles without any major tire damage or flats... until the bike was stolen. Excellent traction, including slushy snow on pavement.
Michelin Protek also has self-sealing tubes. I haven't used them myself, although I did send a pair to my nephew in goathead territory. I haven't heard of any problems yet.
Hard to say if the Marathon Plus damage was just bad luck, and the no flats with the Proteks was just good luck. But, that is certainly a tire worth considering.
