Overhauling outboard BB bearings?
Quoted: 1857 Post(s)
Liked 664 Times
Anybody ever overhauled the ball bearings in ultratorque or similar outboard BBs? replacement is $30 to $45. How is their durability?
Quoted: 4205 Post(s)
Liked 3,863 Times
At the low cost of complete replacement and it's "guaranty" of good condition why clean and grease the old bearings?
Having said that Phil has offered a rebuild tool for the Shimano external BB bearings. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 714 Post(s)
Liked 800 Times
I've done some SRAM GXP ones by prying out the seals, flushing and re-greasing. That was only in an emergency to get me going again until I could purchase a new one. It was never as smooth as new, because its almost impossible to get all of the grit out.
Likes For dsaul:
Quoted: 2952 Post(s)
Liked 3,106 Times
I had the same experience.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
How much do you ride in monsoons, submerging the BB in water...or in torrential downpours (sans fenders) forcing water in? Most people don't, so they'll last years. My UT still has the original bearings without being modified at all--then again that bike doesn't see near the abuse my gravel rig does.
Non omnino gravis
By the time an external cartridge bearing BB has enough grit in there to need flushed out, the bearings and/or races are generally shot. Cleaning/regreasing will add a little life, but it's gonna need replaced.
That said, I have two BBs with over 15k miles on each. Still nice and smooth.
Quoted: 2026 Post(s)
Liked 1,096 Times
I have two Shimano Ultegra external bearing bottom brackets (BB-6700) with 22,000 and 24,000 miles and both are still in fine condition and working quietly and smoothly. These bikes don't get ridden in the rain intentionally but they have been anyway.
I don't remember why but I replaced UT bearings once.
I think I changed them because the cranks I got were used.
UT bearings are sealed.
You need a special bearing puller or I suppose you can make one.
I think I used a 1/2"drive deep socket to install.
My other UT cranks probably got 5000+ on them and no issues.
Liked 664 Times
Ok, I guess the $45 replacement cost for Campy is comparable to when one buys a new UN55 or some such cartridge BB.
I just bought an aluminum Ultra-Torque Centaur CT crankset, and the installed bearings have some little catches when I rotate them. Zinn has a flush/grease process if you only have one side exposed, basically spray it with some WD-40 or something, dry and re-grease. With most used BBs I tend to run them before replacing, so I did the spraying, worked in some new Park grease, and am now ready to install. They feel smoother, so I think I managed to remove some significant crud. But without full disassembly and cleaning, or renewal, it's not going to get any better.
We'll see how it rides. If it is smoothed out like a good modern BB, then life is good and I'll just go on. If it goes bad, then I'll fix it.
Thanks, folks!
Thanks, folks!
Depends on your performance expectations and how you value your time. Removing bearing shields flushing and regreasing certainly does extend their life, particularly if done when the bearings are only slightly rough and have no play, but in most cases BBs have enough life that I'd personally rather just replace them wholesale in most cases. If paying shop labor rates replacement almost always makes more sense
Quoted: 18376 Post(s)
Liked 4,511 Times
With Campagnolo, one just replaces the cartridge bearings, and not the cups.
I think some of their top of the line (Record/Super Record) bearings either lack seals, or have poor seals (race only?) And, should be able to be disassembled and flushed.
I think at least some Wheels Manufacturing bottom brackets can have the cartridge bearings replaced.
That might be a handy option for the press-in types of bearings. Actually, I think their press-in cups may screw together, which is both good and bad. Be careful with galling.
