Long pull reverse brake levers for old Mafac racer brakes
Old 08-05-19, 05:08 PM
rdlange
rdlange's Avatar
Bikes: Bridgestone KABUKI mixte, TREK MT220
where do I find out about getting LONG pull reverse levers for use on bullhorn/pursuit type bars with vintage Mafac/DiaCompe 'caliper' brakes?
Tks.
rdlange is offline
Old 08-05-19, 05:23 PM
TenGrainBread
TenGrainBread's Avatar
Quoted: 769 Post(s)
Liked 125 Times in 95 Posts
Aren't Racers short pull? They are standard centerpulls AFAIK.
TenGrainBread is offline
Old 08-05-19, 05:35 PM
noobinsf
noobinsf's Avatar
Bikes: '82 Univega Competizione, '72 Motobecane Grand Record, '74 Campania Professional, '83 Mercian KOM Touring
Quoted: 349 Post(s)
Liked 43 Times in 33 Posts
Does “long pull” mean linear, like for v-brakes? If so, then I echo TGB’s advice that long pull is not what you need. Just standard levers for canti, center-pull, and sidepull are what you need.
noobinsf is offline
Old 08-05-19, 07:01 PM
Kuromori
Quoted: 133 Post(s)
Liked 24 Times in 20 Posts
Originally Posted by AeroGut View Post
“Long pull” is the same as “standard pull” ie it’s what almost everything was before they introduced “short pull” for v-brakes.
Might want to check again
Kuromori is offline
Old 08-05-19, 07:08 PM
clubman
Youngman Grand
clubman's Avatar
Quoted: 1033 Post(s)
Liked 60 Times in 53 Posts
Pictures are needed
clubman is offline
Old 08-05-19, 07:09 PM
AeroGut
Quoted: 42 Post(s)
Liked 18 Times in 15 Posts
Yes I was backwards assuming OP was correct. Should have thought for a sec before typing
AeroGut is offline
Old 08-06-19, 12:09 PM
Bad Lag
Quoted: 361 Post(s)
Liked 27 Times in 22 Posts
Huh???
Between the OP's confusing, ambiguous, erroneous question and the confusing answers in this thread, I am LOST.
Can we start over again?
Bad Lag is offline
Old 08-06-19, 12:27 PM
noobinsf
noobinsf's Avatar
Quoted: 349 Post(s)
Originally Posted by Bad Lag View Post
Huh???
OP wants to use inverse levers with his MAFAC Racers and assumes that he needs long/linear pull brake levers. OP wants to know where he can find long pull inverse levers.
OP is incorrect -- he can use standard pull inverse levers, which are readily available, with his MAFAC Racers, and so does not need to search for something special.
EDIT: OP did not specify Racers, but the same advice is true for any of the vintage Mafacs or Dia Compe caliper brakes.
noobinsf is offline
Old 08-06-19, 01:36 PM
TenGrainBread
Quoted: 769 Post(s)
OP DID specify Racers but then edited his post to remove them. Which is partly why this thread is so confusing.
Old 08-06-19, 02:12 PM
noobinsf
noobinsf's Avatar
Quoted: 349 Post(s)
Wait, who’s on first?
noobinsf is offline
Old 08-06-19, 06:27 PM
Road Fan
Road Fan's Avatar
Quoted: 846 Post(s)
Liked 30 Times in 27 Posts
I'm with Bad Lag - what is an inverse lever? I never heard of it.
Road Fan is offline
Old 08-06-19, 08:22 PM
rdlange
rdlange's Avatar
OP is most grateful for the clarification. Thanks to all who responded.
rdlange is offline
Likes For rdlange:
Old 08-07-19, 01:08 AM
Kuromori
Quoted: 133 Post(s)
Bar end brake lever like they use on time trial bikes today. CLB among others used to make a few models, typically found on French porteurs or the like.
Kuromori is offline
Old 08-07-19, 05:08 AM
Road Fan
Road Fan's Avatar
Quoted: 846 Post(s)
Pictures are needed
Ok, thanks to Kuromori, now I'm here. Why is a longer pull like for a linear brake needed? MAFAC Racer calipers work with nearly any road lever, if not EVERY road lever ...
Road Fan is offline
Old 08-07-19, 05:10 AM
Road Fan
Road Fan's Avatar
Quoted: 846 Post(s)
Ok, now I'm caught up - I agree OP does not really have a problem.
Road Fan is offline
