Wheelset upgrade questions
Road Cycling ďIt is by riding a bicycle that you learn the contours of a country best, since you have to sweat up the hills and coast down them. Thus you remember them as they actually are, while in a motor car only a high hill impresses you, and you have no such accurate remembrance of country you have driven through as you gain by riding a bicycle.Ē -- Ernest Hemingway
Old 08-08-19, 10:24 AM
p4k9
I bought a basic Specialized Allez, the one with Claris groupset. Iím thinking about upgrading the wheels. Would the Shimano Dura-Ace WH-R9100 C24 be a decent upgrade? Could I use my current cassette? Any other recommendations around the same price or less would be welcome.
p4k9 is offline
Old 08-08-19, 10:56 AM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 8492 Post(s)
Liked 437 Times in 263 Posts
You can use your current cassette. It's really nice to have a backup set of wheels ready to go though.
Seattle Forrest is offline
Old 08-08-19, 11:38 AM
jlaw
Bikes: 2015 Spec. AWOL Elite, 2007 Spec. Roubaix Elite, 2003 Spec. Big Hit 2, 1998 VooDoo Zobop, 1985 Trek 410, 1984 Trek 620 1985 Trek 620
Quoted: 248 Post(s)
Liked 50 Times in 33 Posts
I looked up the wheelset you mention and the 'base' Allez on the Specialized website. It looks like you are considering putting an $800 wheelset on an $800 bike.
If so, I'm not sure that you need to spend that much if you really want different wheels. What are you trying to achieve by buying new wheels?
And, yes, you can probably use your existing 8 speed cassette on a new wheel if you have the proper spacers. Verify with the vendor re: this before purchase.
jlaw is offline
Old 08-08-19, 11:48 AM
firebird854
Bikes: 2016 Specialized Tarmac Expert
Quoted: 169 Post(s)
Liked 21 Times in 15 Posts
The best upgrade you can do is a change of wheelset, if you're really trying to min-max the bike, an $800 wheelset on an $800 bike would be a great upgrade. In my honest opinion however, I would upgrade to 11 speed 105 and a new wheelset.
firebird854 is offline
Likes For firebird854:
Old 08-08-19, 12:23 PM
p4k9
You’re right, $800 wheels on an $800 bike. There’s nothing wrong with the wheels I have I was just looking for something faster and lighter. I’m just wondering if I’d be able to feel the difference between my stock wheels and these. Nothing like spending money and not getting anything out of it.
p4k9 is offline
Old 08-08-19, 12:27 PM
p4k9
Thatís good advice. Thanks! Would I need to upgrade the whole groupset ? Or could I just do the rear system?
p4k9 is offline
Old 08-08-19, 02:03 PM
hubcyclist
Quoted: 209 Post(s)
Liked 24 Times in 17 Posts
Iím gonna be a contrarian. I have the same Allez and you honestly donít need to sink any money into it. I do some racing and it keeps up fine with everyone else, assuming your fitness and group riding abilities are good. Save your money for something like a power meter to train
hubcyclist is offline
Old 08-08-19, 02:18 PM
p4k9
Thatís exactly what I needed to hear. Thank you!
p4k9 is offline
Old 08-08-19, 02:59 PM
firebird854
Quoted: 169 Post(s)
Unfortunately I'm no bike mechanic so I'd have a hard time telling you. When it comes to my bike, I built it up from an Eomonda ALR frameset, number 1 priority was powermeter, one of the cheapest dual sensing options I could find was the FSA powerbox alloy. My 2nd was groupset, I wouldn't go less then 105 period, because it's simply some of the best value you're going to find. Next priority were wheels, pretty much the best value option you're going to find are light-bicycle wheels, I considered them heavily, but eventually ended up spending a bit more and getting Aeolus 5s. As a side note, I personally would recommend something in the 50mm range, the Dura-ace c24s are nice, but I'd go C50s if I was planning to stick with Shimano.
So... If I were in your situation, I would probably get a single sided discounted powermeter, or one from ebay, upgrade to latest Shimano 105, and get some GP5000 Continental tires.
Then, after I obtained more money, I would probably get some Bontrager Aeolus Comp 5 TLR Disc Road Wheels. A setup like this with your frame would be some of the biggest bang for your buck.
Old 08-08-19, 03:19 PM
jlaw
Quoted: 248 Post(s)
Your 8 speed Claris brifter will not work with a 10 or 11 speed system. You will need at least 1 new brifter to shift the new rear der,, new RD, new chain, new cassette, maybe a new RD cable and housing. new bar tape. $200 or so if you shop around. Microshift components are a little cheaper than name-brand
You may be able to keep your FD and the associated brifter if 10/11 speed chain will fit the existing chain rings. You might also be able to do this upgrade using your existing wheels.
jlaw is offline
Old 08-08-19, 03:36 PM
bikebreak
Quoted: 127 Post(s)
Wheels are a VERY good upgrade, esp going from heavy stock wheels to lighter rims. Lower rotating mass makes more difference than non rotating mass.
That said, the first place to upgrade is tires and tubes. Look for lower weight and lower rolling resistance, but decent puncture resistance. Check out https://www.bicyclerollingresistance.com/
Lighter weight high quality tubes will also lower rotating mass and resistance
bikebreak is offline
Old 08-08-19, 03:43 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 558 Post(s)
Liked 74 Times in 63 Posts
Since your bike isn't 11s, which generally required folks to get new wheels, you should be able to pick up a pretty nice set of 10s wheels at a good price.
RS80 rims are the same laminated carbon/ally as Dura-Ace. They were 10s, see what you can find used, but watch out for rim wear and rough bearings.
Kimmo is online now
Old 08-08-19, 04:14 PM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
Quoted: 6813 Post(s)
Liked 632 Times in 403 Posts
The best upgrade isn't wheels but tires.
The OP's bike comes with 370 gram Specialized Espoir Sport tires. He could save well over a half pound rotational weight and improve ride quality tremendously just by swapping tires.
It doesn't even have to be expensive tires. The discontinued Vittoria Pro III tires were as low as $14 each and weigh only 235 grams.
Throw in some Continental Race or Race Light butyle tubes for another $20. These are just examples of what's out there.
The bike would ride and feel completely different with nice supple tires and light tubes. The whole thing might cost $50 or maybe $75 max and he would have nice tires to put on new wheels if he still wanted them.
-Tim-
TimothyH is offline
Likes For TimothyH:
Old 08-08-19, 04:40 PM
alcjphil
alcjphil's Avatar
Quoted: 592 Post(s)
Liked 45 Times in 33 Posts
I agree somewhat with TimothyH in this. Wheels can make a difference, but if you mate them with heavy flat resistant tires and tubes, you won't gain much. Lighter, supple tires along with lightweight inner tubes can make a noticeable difference. Since tires wear out anyway, and you have to buy new ones sometime, this is a very good first step. Unless, that is that you have a fear of flats. Lighter weight tires have less puncture protection, so depending on where you live, this can be a worry. Where I live, the biggest problem is pinch flats for which puncture resistant tires provide no help, so it doesn't matter for me if I ride on lightweight tires, the only downside is that they wear out a bit faster. Lightweight wheels are a portable upgrade, if you buy a newer, better bike you can still use them by transferring them to your new ride. How recently did you buy your bike? It is easy to catch upgrade fever, but you have to be rational about it. If the thought of upgrading groupsets is starting to look feasible, you may have bought the wrong bike to begin with, especially if you are thinking about buying wheels that sell for the whole price of your bike. Start with tires and tubes. go from there.
alcjphil is offline
Old 08-08-19, 08:54 PM
Seattle Forrest
-Tim-
Every word of this. Not just the bold parts, but especially them.
A $200 pair of tires will save about the same number of watts as a $2,000 pair of wheels.
The problem is you can only do this once. Most folks giving advice in here have been using light and supple tires for so many years, they tend not to be on our radar as a potential upgrade, I probably didn't phrase that well.
Old 08-08-19, 09:07 PM
woodcraft
woodcraft's Avatar
Quoted: 1070 Post(s)
Liked 56 Times in 36 Posts
+3 - optimize tires first.
I was surprised last weekend at how many folks were doing a century ride or longer on gatorskins.
woodcraft is offline
Old 08-09-19, 10:41 PM
colnago62
Quoted: 309 Post(s)
Liked 24 Times in 18 Posts
Shimano used to have an Ultegra version of their Dura Ace wheelset. It was the same rim and spokes, different hub. Those where half the cost of Dura Ace wheels. Here is a link from the Shimano website.
https://bike.shimano.com/en-US/infor...explained.html
colnago62 is offline
Old 08-10-19, 06:58 AM
p4k9
That makes sense to me. Iím going to hold off on the wheel upgrade for now. Iíll wear these tires out and when Iím ready Iíll look for better tires and tubes. I appreciate your insight.
p4k9 is offline
Old 08-10-19, 07:03 AM
p4k9
That said, the first place to upgrade is tires and tubes. Look for lower weight and lower rolling resistance, but decent puncture resistance. LINK REMOVED
Great website! Thanks for that resource. I really didnít think about the tire tube aspect as much as shiny metal wheels. I guess making sure my tubes were properly inflated would make a difference too. Iíll have to keep a better eye on that before each ride.
p4k9 is offline
Old 08-10-19, 07:04 AM
p4k9
Yes! Or in my case make sure theyíre properly inflated before each ride. It really makes a difference
p4k9 is offline
Old 08-10-19, 07:07 AM
p4k9
Ahhhhh, another option! I really donít know what wheels Iíd buy. I just used the dura-ace because they seemed awesome. Maybe itís not the wheels so much as the hub. I need to research more but first Iíll get some lighter tires and tubes. Everyone here has been such a great help and I really appreciate it.
p4k9 is offline
Old 08-10-19, 07:09 AM
p4k9
Thats great advice! Tires and tubes, but I have to wear what I have out first. And youíre totally right about upgrade fever. Maybe a better helmet first and some more shorts. 🤣
p4k9 is offline
Old 08-10-19, 07:18 AM
noodle soup
noodle soup's Avatar
Quoted: 3122 Post(s)
Liked 236 Times in 159 Posts
I agree with most of this, but I wouldn't recommend a power meter at this point.
noodle soup is offline
Old 08-10-19, 07:29 AM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 3862 Post(s)
Liked 361 Times in 235 Posts
Tires for absolute sure. The Espoir Sport are terrible tires-- slow rolling, low thread count, heavy, and as much puncture resistance as a birthday balloon.
A 700x25 Espoir weighs almost as much as one of my tubeless 700x35 Pirellis.
The OP could buy some very nice tires and a complete 105 groupset for about half the cost of those DuraAce wheels.
DrIsotope is offline
Likes For DrIsotope:
Old 08-10-19, 07:30 AM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 558 Post(s)
Rims are about performance, hubs are about durability, spokes are about both. Shimano rear hubs, of any level, are the most durable IMO.
Kimmo is online now
