Slightly too small tube: is it really a problem ??
Professional amateur
Bikes: Does a Big Wheel count ?
Quoted: 302 Post(s)
Liked 136 Times
I have a 29er hybrid with 40-42mm tires, and my road bike is currently running some wide 32mm tires. I already have a couple spare tubes for both wheelsets, but I'd like a few more, and I can get a relative deal on more Continental 700x 25-32 tubes, and it would be handy to consolidate them, so I don't have a reserve stash of different tubes.
32mm to 40mm is only about a third of an inch more, so I can't imagine that's gonna stretch the rubber to paper-thin dimensions, and start causing me problems...........or is it?
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
False economy
You're not hurting for spare tubes, why compromise on tubes you don't need at the moment? If I had the choice between being stranded vs using a tube too small for the wheel, I might chance it. For regular riding, you're exceeding the specifications for the tube. You got the part right about the rubber compound being stretched too thin, weakening a safety critical component.
Therefore, a deal is not a deal if you don't actually need the item!
Likes For Unca_Sam:
Bikes: Konas: Jake the Snake-Fire Mountain-Zing Supreme, Dew Deluxe,Zone Ltd. (frame, needs parts), Surly Long Haul Trucker, Santana Arriva tandem, Montagues: Paratrooper-Fit, Trek 1200, Bianchi Ocelot, Fantom Cross Uno, Bridgestone 200
Quoted: 108 Post(s)
Liked 227 Times
If it were only a couple mm, I wouldn't sweat it too much, but I think when it gets that far, I'd want to have some properly sized tubes on hand.
I have heard of folks using undersized tubes to reduce weight a little, but haven't bothered with that, myself.
Likes For velojym:
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
I carry smaller tubes in my kit on my gravel bike because they pack down smaller and are easier to fit in the tool roll. I'm running tubeless so the tubes are just for a puncture that won't seal, and I don't intend for them to be used long-term.
Quoted: 1074 Post(s)
Liked 295 Times
When I had a 29er MTB, I never bothered repack the saddle bag. The 26” spare tubes worked just fine. Then when I went to a 700C commuter, the 26x1.1tubes stayed in use. No problem there either.
Likes For dabac:
Likes For tyrion:
Rubber stretches. Good butyl stretches too. Have you ever seen a genuine Goodyear bicycle inner tube? I have one here in a bike I got for my birthday sixty years ago. Stretchy. Reliable.
Current production it's safer to match tire and tube fairly closely. To get home do what you have to. For regular riding get tubes that fit.
Likes For 63rickert:
I keep a well stocked supply of tubes for all my bikes. Tube size has got to match tire size as close as possible or, you're going to have problems. It's always better to have a tube size that's slightly smaller than tire size than the opposite. Never try to stuff a larger size tube into a smaller sized tire. Try using thorn proof tubes too. They're worth the extra cost, But, you sacrifice a little on extra weight.
Likes For ramzilla:
bike whisperer
Quoted: 1526 Post(s)
Liked 718 Times
Ye gods, no. Not unless you're prepared to prioritise puncture resistance ahead of comfort, grip, rolling resistance and acceleration.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Likes For Kimmo:
I guess if you're on a professional bicycle team competing in the Tour de France you might actually notice a 2X heavier tube weight inside a tire. But for the average rider dealing with everyday concerns, heavy duty tubes can be a good problem solver. I personally want the added protection of heavy duty tubes and tires whenever I deal with extreme downhill rides in excess of 35mph.
Likes For ramzilla:
Quoted: 302 Post(s)
Liked 136 Times
So assuming a 26" tube will basically do the same thing, then yeah, I could see a 26" tube functioning fine in a 29er tire. I don;t think I'd be bold enough to try and cram one into a road wheel, but in a 29er, I could see it.
Quoted: 1572 Post(s)
Liked 643 Times
I may be a little bit sick.
I'm down to two inner tube skews at my house. That's ERTO diameter, width and valve stem length. I've given away or thrown away everything else. I'm tired of spending 10 minutes going through all of my inner tuber stock looking for the exact one that I want. I'm never going to use the rest of them anyway, so why keep them around?
Quoted: 430 Post(s)
Liked 460 Times
I use 28-35 tubes for my 40-42mm tires. Works fine, no pinch spot near the valve - that's the only area you need to be careful about when tubes and tires are slightly different sizes.
bike whisperer
Liked 718 Times
I'll take the grip you're sacrificing.
Old fart
Quoted: 3587 Post(s)
Liked 3,399 Times
The tube will expand to fill the space available. But it will also be stretched thinner than a properly sized tube, and thus arguably more prone to puncture.
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
A 25-32 tube is probably going to be 25 mm or less when it takes shape. It probably wouldn't be my first choice for a 42 mm tire.
Quoted: 302 Post(s)
Liked 136 Times
Mathematically, yeah, the tube has to get thinner as it expands, but if we draw a circle that's 32mm around, then draw a circle that's 40mm around, and compare the two, I'm having a tough time imagining there's a gonna be real-world difference here in the tube wall thickness, and it's puncture resistance.
Quoted: 302 Post(s)
Liked 136 Times
BTW, I just found a quality,economical tube that would work with both my current road and hybrid tires......
https://www.nashbar.com/continental-...501048/p326663
I have spare 40mm's tires for the hybrid, and some spare 32's for the road bike, so I'm not likely to change tire widths anytime soon (especially not on the hybrid), so these Continental 32-47mm tubes should be nearly ideal (especially at only $6 each, with $1.99 shipping, from Nashbar. Plus, the tubes wouldn't be stretched [i.e. thinned] anywhere near their maximum, which should only enhance the aforementioned puncture resistance.)
mattkime
Bicycle Mechanics
7
08-18-10 09:14 AM
mattkime
Bicycle Mechanics
16
08-13-10 05:35 PM
