Thru axle loosening?
Old 08-12-19, 06:17 PM
shelbyfv
shelbyfv's Avatar
Quoted: 1201 Post(s)
Liked 201 Times in 133 Posts
A friend told me that his front thru axle loosened on a ride this weekend. The wheel cocked enough that the disc brake grabbed. Fortunately he was going uphill and was able to get a foot down. He also related that another friend had a front axle come completely out. The wheel stayed in the fork and he was able to backtrack and find the axle in the road. One was the Allen key style, the other had the lever. I searched online and found a few discussions but no consensus as to what caused it. Precession and thread direction were mentioned but it was pointed out that nothing should actually be bearing and rotating on the axle. Is this becoming common? Something to be concerned about?
shelbyfv is offline
Old 08-12-19, 06:32 PM
rayooo
rayooo's Avatar
Quoted: 15 Post(s)
Liked 9 Times in 7 Posts
hmm, 4 bikes for me so far with thru axles. no issues with loosening whatsoever over many years. Maybe someone else can shed more light on this.
rayooo is offline
Old 08-12-19, 06:33 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1735 Post(s)
Liked 137 Times in 100 Posts
The bearing cones or cartridges bear on the thru axle, don't they? If not, were does the weight they are supporting go to get to the frame? If the bearing grease dries up or the cones are too tight so the bearing is no longer running freely, then the torque would be transmittted to the through axle, applying a torque in the opposite direction as would be transmitted by properly lubed bearings and in a direction the thru axle might not be designed to handle. (Pedals and English bottom brackets are designed to screw in tighter with the forces transmitted by the bearings. If your pedal bearings go bad, the pedal unscrews and falls out (unless you "honk
on that wrench at installation in which case your ankle unscrews and falls off).
Ben
79pmooney is offline
Old 08-12-19, 07:52 PM
shelbyfv
shelbyfv's Avatar
Don't know. I only have one bike with thru axle, so not an expert. It looks as if the ends of the hubs sit in shallow indents in the fork. The axle pulls everything tight. The axle shows no sign of anything moving on it, no wear marks.
shelbyfv is offline
Old 08-12-19, 08:05 PM
Marcus_Ti
Frozen Solid.
Marcus_Ti's Avatar
Quoted: 1998 Post(s)
Liked 91 Times in 63 Posts
Thru-axles need adequate torque, as with any fastener. Generally 10-12Nm AFAIK. The bolt-head axles are better because you can put a torque wrench on them ofc.
Never seen one loosen-while-riding happen myself.
Marcus_Ti is offline
Old 08-12-19, 10:56 PM
jimincalif
Bikes: '96 Trek 850, '08 Specialized Roubaix Comp, '18 Niner RLT RDO
Quoted: 512 Post(s)
Liked 46 Times in 28 Posts
I did have my front thru axle start working loose last year. I felt the play in the front wheel when it was slightly loose, there was still lots of thread in the fork so the wheel was not anywhere near falling out. Iíve taken care to torque it sufficiently ever since and have had no more issues.
jimincalif is online now
Old 08-13-19, 09:23 AM
Eggman84
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 176 Post(s)
Liked 15 Times in 14 Posts
And there I was thinking one of the reasons bike manufacturers went to thru axles (at least on front wheels) was they wouldn't loosen when used with disk brakes (unlike with QR where wheel ejection was a well researched/documented occurrence). Maybe your friend is not following the proper procedures. Lots of you-tube videos saying how to setup thru axles (one being
). Also, if I am not mistaken one of the safety checks before each ride is checking your QRs/thru axles (if parked in public a passerby may have maliciously loosened them). Of course I don't follow this suggestion my self.
Eggman84 is offline
Old 08-14-19, 05:05 AM
shelbyfv
shelbyfv's Avatar
Thanks all. It seems nothing is going on beyond user error
shelbyfv is offline
Old 08-14-19, 03:26 PM
dabac
Quoted: 829 Post(s)
Liked 9 Times in 8 Posts
Thru-axle assemblies are rather stupidly designed, since there is nothing providing an actual definite position of the parts. The axle has to be a loose fit in the hub to allow easy, hands-only installation. So the rider end up having to rely on the end caps of the hub being pinched between two parallel surfaces as the sole mechanism keeping the wheel positioned.
What happens is that applying the brake causes a downward force on the axle, and riding causes an upward force on the axle. In the absence of a definite centering feature, a TA that hasnít been closed with sufficient force will allow the wheel to move (ever so little) up & down, as dictated by how loosely the axle fits in the hub.
One trick that might help is to tighten the TA with the wheel off the ground. That way, the slack is taken out and the wheel is already resting against a definite reference.
Brake forces canít move it any further, and w/o jostling, thereís far less going on that can cause the axle to unscrew.
dabac is offline
Old 08-15-19, 08:08 AM
Kapusta
Cyclochondriac
Quoted: 992 Post(s)
Liked 116 Times in 80 Posts
Another trick is to just tighten the TA properly and not have any issues. It ainít rocket science.
I think it is a stretch to call the TA a stupid design due to what happens if it is not properly tightened. It is a whole heck of a lot better than what happens when you donít tighten a 9mm QR.
The reality out on the road and trail is that TAs do a perfectly good job of keeping the hub exactly where it needs to be, and are actually better than QR at getting disc calipers and rotors to consistently line up after wheel changes.
Kapusta is online now
Old 08-15-19, 08:34 AM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2197 Post(s)
Liked 194 Times in 154 Posts
Looks like there are some things you just can't idiot-proof.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 08-15-19, 02:56 PM
shelbyfv
shelbyfv's Avatar
+1 Years ago I had a bike with disc and a QR. Never again. The thru axle I have now requires that I loosen it slightly to close the lever. Seems iffy to me so I probably should replace it with the Allen key type.
shelbyfv is offline
Old 08-15-19, 03:10 PM
Kapusta
Cyclochondriac
Quoted: 992 Post(s)
I don't know what kind of TA you have, but some designs you can adjust how much it tightens as you close the lever.
Likes For Kapusta:
Old 08-15-19, 03:14 PM
Kapusta
Cyclochondriac
Quoted: 992 Post(s)
True. Idiocy is like a thin liquid that will find its way through the tiniest of cracks.
Likes For Kapusta:
Old 08-15-19, 06:56 PM
August West
August West's Avatar
Bikes: Trek Domane SL6
Quoted: 35 Post(s)
Liked 12 Times in 10 Posts
My current bike came with DT Swiss RWS axles which I really like. Huge step up from my previous bike with disc/QR combo.
I do a decent almost daily of the most god awful chip sealed road you can imagine and they have never loosened one bit even though a bunch of other things on the bike have had to be Loc-Tited and re-torqued.
That being said, if I ever replace my current axles I'm going with these:
The Robert Axle Project
August West is offline
Old 08-17-19, 07:14 PM
gsa103
Bikes: Bianchi Infinito (Celeste, of course)
Quoted: 630 Post(s)
People tried. I have a Fox fork which has a QR clamp on each side, just to prevent the TA from loosening. Pretty much belt, suspenders, duct tape and super-glue at that point.
gsa103 is offline
