Itís here, now where to start?
Old 08-22-19, 10:52 PM
robbyville
robbyville's Avatar
Bikes: Speedvagen Steel
Quoted: 265 Post(s)
Liked 35 Times in 28 Posts
My original DeRosa has been returned to me after almost 20 years of sitting around barely being used.
seems like my friends who had it replaced the stem with some type of insert that allows for a modern aheadset style stem vs quill salsa unit I had in there before.
the wheels are still in very nice shape albeit need new tires these seem pretty dry and cracked. The front Mavic hub circa late Ď80ís that I built to a Mavic rim still rolls True and the rear Campagnolo rim with old shimano 600 freehub 8spd seems to still be decent.
bottom bracket still good, Mavic headset a little rigid hopefully just needs grease. The paint is pretty darn faded and frame needs a deep clean. Chrome has some putting and rust spots.
id like to get t back into riding shape before stripping down and looking to new paint and chrome. My intent is to keep original scheme decals, chrome and paint color. Any good ideas for painters? In the interim whatís my best bet to get this thing decreased and clean, how best to clean the chrome?
for parts Iím still thinking of mid Ď90ís Campagnolo while maintaining some of the unique items on the bike, still not sure.
im pretty happy and canít wait to ride this again. Open to suggestions on best cleaning technique, sourcing parts
robbyville is offline
Likes For robbyville:
Old 08-22-19, 11:09 PM
Tulok
Tulok's Avatar
Quoted: 44 Post(s)
Liked 17 Times in 15 Posts
Cool bike!
Step 1: youíll have to at least disassemble the wheel hubs and headset, clean thoroughly and regrease them before you ride. Better safe than sorry! The B.B. is a good idea too.
Step 2: simple green, WD40 or other solvent, micro fibers and a toothbrush and maybe a short bristled paint brush to clean it all. If you rinse off the whole bike with water, remove the bolts from the bottle cages, etc and put WD40 into the holes around the whole frame and try to coat it internally with oil to prevent rust.
Step 3: if you keep the same shifters abs brakes, get new pads and high quality cables like dura-ace or jag-wire for best results!
Tulok is offline
Old 08-22-19, 11:19 PM
robbyville
robbyville's Avatar
Quoted: 265 Post(s)
Originally Posted by Tulok View Post
Cool bike!
Great advice thank you! For shifters I had the first series of 600 brifters on. I forget what year they were but i was working for a shop at the time and it was definitely first gen 600. Seems though that something must have happened over the years because it has one original and the rear shifting is now a Claris 8spd. Definitely drivetrain will be swapped out as I find parts but Iím thinking Iíd keeping the race face cranks, donít see too many of those.
im hoping to start disassembly and clean up this weekend. Thoughts on cleaning the chrome?
Old 08-22-19, 11:33 PM
machinist42
machinist42's Avatar
Bikes: 1964 Schwinn Paramount P-13 DeLuxe, 1972 Falcon San Remo, 1974 Maserati MT-1, 1974 Raleigh International, 1984 Lotus Odyssey, 198? Rossin Ghibli, 1990 LeMond Le Vanquer (sic), 1991 Specialized Allez Transition Pro.
Quoted: 390 Post(s)
Liked 15 Times in 14 Posts
All In Good Time, All In Good Time...
Hmmm.
Step 1 - Post a photograph of the whole bike, if you please? Some of us would appreciate the opportunity to see it in its entirety.
Step 2 - Nope, see Step 1.
machinist42 is offline
Likes For machinist42:
Old 08-22-19, 11:48 PM
Tulok
Tulok's Avatar
Quoted: 44 Post(s)
Bummer about the shifter! I have 1st gen 600ís on my bike and they didnít work AT ALL when I got them. All it was, was dried grease inside the mechanism. Very common and known issue on those.
Chrome:
Aluminum foil balled up with some light oil on it Or 0000 (quadruple zero) steel wool with light oil. Rub gently and go back-forth, up-down, diagonal-diagonal, repeat. The rust will begin to disappear. Then clean with s light degreaser, then wax (imho that works best.).
The crankset does look amazing I will say! I hope you can find a nice quill stem for it somewhere.
Tulok is offline
Old 08-23-19, 12:09 AM
solidtyres
Bikes: YES
Quoted: 30 Post(s)
Is the crank cracked at the at the BB?
Sorry
solidtyres is offline
Old 08-23-19, 12:28 AM
P!N20
P!N20's Avatar
Quoted: 221 Post(s)
Liked 41 Times in 36 Posts
Well that's the first thing you can get rid of...
...and after that get rid of the insert and stem.
Original paint? I wouldn't. I'm sure with a bit of work you could bring back the shine.
Aluminum foil and water. You'll be amazed.
for parts I’m still thinking of mid ‘90’s Campagnolo
So 9 speed? OK...but what about a Record/Chorus 8 speed setup?
P!N20 is offline
Old 08-23-19, 12:56 AM
RiddleOfSteel
Lugged, Dura-Ace Glory
RiddleOfSteel's Avatar
Bikes: '87 Schwinn Prologue - '74 Schwinn Paramount P15 - '8X Davidson Impulse - '88 Land Shark Road Shark - '85 Specialized Allez SE - '81 Univega Gran Premio - '92? Bushnell Track Bike
Quoted: 838 Post(s)
Liked 58 Times in 48 Posts
It's been 20 years, it's back to you the original owner, and it's a De Rosa. It very much deserves a full disassembly. Wheels off, cables undone, brakes off, bars off, crankset off, BB out, derailleurs off.
Use Simple Green or whatever to wipe down the now-fully-accessible frameset. You can polish (Nevr Dull or Mother's Mag & Aluminum etc) the headset if you like, though with the chrome fork and stays (Quick Glow chrome cleaner or a chrome cleaning specific product), you should do the bright work. Do you have car (as in Carnuba etc) wax? The paint looks more than fine and can be brought to a great shine with some elbow grease. Microfiber rags are your friends.
Chrome pitting/rusty bits can be dealt with via running aluminum foil over it, with a liquid serving as a middle man of sorts between the foil and the chrome. As aluminum foil is much softer than chrome, it won't damage the chrome (you might get the slightest of light scratches, but after 20+ years, that chrome won't be perfect, so it will likely be unnoticeable). I've done this on an entirely chrome 1977 Schwinn Super Le Tour 12.2. Worked well. Don't use massive crumpled bits of foil. At loose "crushing" the foil 'ball' of sorts will be between golf and tennis ball size. As you press on the chrome surface and get into it (back and forth like sanding), the foil will compress. You'll see it pick up all the rusty bits if you turn it over. A ton of rust will tell you it's time for new foil. Lather, rinse, repeat.
As for components, I don't know what your stash looks like or what groupset you'd be willing to put on it (talking about price in a way here), but the "matching things" or "consistent theme" part of me would exhort you to have a single groupset, or at the very least components from the same manufacturer. The RaceFace crankset clashes with the FD and the RD and the brakes are painted while other parts are polished. The stem conversion can go (there are much better ways/converters out there, I use them, but for this bike a traditional quill is the ticket, IMO). 9-speed Campagnolo is a great in any form that is Veloce and above. If your rear axle's spacing is 126mm, don't worry about cold setting the frame to 130mm. It's steel and it won't care about a 130mm axle if you can pop it in by yourself (easy to do).
I echo the sentiments of others and would really appreciate a full bike picture. Indoors, outdoors, doesn't matter. It helps us get a better idea of things, and then help you.
RiddleOfSteel is offline
Old 08-23-19, 01:33 AM
Drillium Dude
NNNN
Drillium Dude's Avatar
Quoted: 1138 Post(s)
Liked 220 Times in 125 Posts
000 brass wool and some SoftSoap turned this:
into this:
I was amazed, but the results speak.
DD
Drillium Dude is offline
Likes For Drillium Dude:
Old 08-23-19, 06:37 AM
robbyville
robbyville's Avatar
Quoted: 265 Post(s)
Wow thank you folks! I will get some full bike shots prior to disassembly this weekend. 8 or 9 speed will be fine for me. I live in the flatlands.
I canít tell you how happy I am to have this bike back. I bought the frame and fork back in my mid twenties and scrapped it together with what I could afford but it was my dream bike of the time. I let it go after I came to the US from Canada and following a series of moves and marriage where inactivity had me gain over 40lbs. After bleaching in the sun on a variety of apartment balconies (hence the faded paint) I finally sent it to some friends back in Whistler whonused it rarely but took good care of it.
Still married and now 40 lbs lighter thanks to picking up cycling again in 2013 I couldnít help but continue to think of my original ďfirst childĒ as my son refers to the DeRosa. My friends offered to send it back and I readily accepted.
guven your feedback Iím going to clean and polish the heck out of it. Put some new tires on and Have a few rides and will then start looking for a group set to match. If going Campagnolo I guess Iíll have to swap wheels as well unless I can changebout the shimano freehub to campagnolo or source a spacer kit of some type?
hopefully the paint will return to some semblance of its previous luster, we shall see. There is basically no rust just faded.
thanks again!
Old 08-23-19, 07:16 AM
55murray
55murray's Avatar
Bikes: 1955 20" Murray modified cruiser, 2010 Nishiki Colorado MTB, 1980 Miyata 610, several other vintage coaster brake machines
Quoted: 162 Post(s)
Liked 15 Times in 13 Posts
No more pics until this is done please. I can't handle it.
55murray is offline
Likes For 55murray:
Old 08-23-19, 07:38 AM
robbyville
robbyville's Avatar
Quoted: 265 Post(s)
Sorry
Nope just grime!
Old 08-23-19, 07:51 AM
jamesdak
Bikes: G.L. Maillot Juane & Ventoux,Schwinn Circuit, Prologue,PDG Paramount,Paramount,Tempo,Jake The Snake,LeMond Zurich & Tourmelet,Giordana XL Super & Antares,Puegeot U08,Bob Jackson,Fuji S12-S,Opus III,Orbea Cabestany,Bianchi Campione,Basso Gap
Quoted: 1219 Post(s)
Liked 162 Times in 97 Posts
Gotta love a De Rosa, can't wait to see more of this one.
jamesdak is offline
Old 08-23-19, 05:54 PM
2cam16
2cam16's Avatar
Bikes: TOO MANY
Quoted: 638 Post(s)
Liked 74 Times in 58 Posts
Looking forward to this! Congrats on the return!
2cam16 is offline
Old 08-23-19, 06:15 PM
Classtime
Classtime's Avatar
Bikes: 69 PX-10, 81 Medici, 84 Turbo, 87 IM, 2010 Milwaukee Road, 2011 RS
Quoted: 576 Post(s)
Liked 25 Times in 22 Posts
I kinda dig the Crankset. I'd clean it up and ride it with those parts and new cables, tires, and grease. Then, while you ride it, think long and hard about a matching group and a likewise matching stem and bars. Probably end up with the group and wheelset that I wanted but couldn't afford in my 20s. Make it your dreamier bike. Don't paint it
Classtime is offline
Old 08-23-19, 07:40 PM
robbyville
robbyville's Avatar
Quoted: 265 Post(s)
Ask and ye shall receive! Some quick pics taken this morning.
Unfortunately while there is no rust on the frame (just lots of grime), a big piece of chrome flaked off the lower part of the fork while checking it out. Left rust below. The top of the fork seems to only have a little rust. Not sure what can be done about this? I'll inspect the frame well, but so far a preliminary look down the seat tube seems all good. In the pics you can also see how faded the paint is. Still, I'll give it a good cleaning and shine and see how I fare. Do I need to worry about riding it with the amount of rust below that section of chrome?
Old 08-23-19, 07:45 PM
robbyville
robbyville's Avatar
Quoted: 265 Post(s)
ok separate question, any idea why I'm not seeing any pics being posted on this computer that I'm on (including my own). My other laptop and phone are fine. I know it must be a setting but for the life of me I can't see where the change needs to be made?
Old 08-24-19, 07:06 AM
robbyville
robbyville's Avatar
Quoted: 265 Post(s)
Going to start the clean up today! Will be super careful to not take any more chrome off the fork blade.
Old 08-24-19, 07:34 AM
Classtime
Classtime's Avatar
Quoted: 576 Post(s)
Don't worry about the fork. If the chrome readily flakes off, I think you should Blake it off so you can remove the rust. On my nasty spots of chrome, I thoroughly sand the rust away and shine up the steel. Then clear nail polish over that. Cool bike and the paint looks great to me.
Old 08-24-19, 07:36 AM
iab
iab's Avatar
Quoted: 1414 Post(s)
Liked 123 Times in 83 Posts
If the chrome is flaking, you need to remove what is causing it to flake. The only way to do that unfortunately, is to remove the chrome.
It is actually quite difficult to remove chrome that isn't damaged in the first place.
iab is offline
Old 08-24-19, 07:47 AM
robbyville
robbyville's Avatar
Quoted: 265 Post(s)
Ok thanks for the advice! Yep it literally flaked off when I touched it.
The feedback has been invaluable thanks so much to all! Iíve been involved with bikes in some form or the other since I was a teen but have never restored one.
Old 08-24-19, 08:32 AM
Hobbiano
Quoted: 164 Post(s)
Liked 22 Times in 19 Posts
Maybe once everything is cleaned up, re-greased, etc., and you can ride it to check it out, send the fork out to be re-chromed? Not worth it for a cheap bike, but for a De Rosa?
Hobbiano is offline
Old 08-24-19, 09:56 AM
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Bikes: 1977 Trek TX700; 1978/79 Trek 736; 1984 Specialized Stumpjumper Sport; 1984 Schwinn Voyageur SP; 1985 Trek 620; 1985 Trek 720; 1986 Trek 400 Elance; 1987 Schwinn High Sierra; 1990 Miyata 1000LT
Quoted: 1769 Post(s)
Liked 93 Times in 74 Posts
That is going to be a super swell bike!
Commence to jiggliní huh?!?!
The Golden Boy is offline
Old 08-24-19, 12:11 PM
shuru421
Quoted: 241 Post(s)
I used a dremel with brass wire attachment. My fork was in way worse condition, yours will come out very nice if you can get those 2 items. Also helps that youll use less elbow grease! My 2 cents.
shuru421 is offline
Old 08-24-19, 01:00 PM
robbyville
robbyville's Avatar
Quoted: 265 Post(s)
Thank you! I have a dremel with brass wire I believe. If not Iíll pick up the attachment tomorrow. Is there a process I should follow that worked for you?
