Incepi fixtures are available.
After an absence from the market, incepi disc mount fixtures are available. ISO and Post Mount fixtures are in stock, and Flat Mount fixtures are on order and expected soon.
Quoted: 4214 Post(s)
Liked 3,891 Times
Link to more info? Andy
AndrewRStewart
AndrewRStewart
Team Beer
Bikes: Too Many
Quoted: 116 Post(s)
Liked 160 Times
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Bikes: 1990 Marinoni Special, 1986 Proctor Custom, 1989 Kuwahara Caravan, Singular Firebird Stainless, Niner RIP9, Sekine SHT
Quoted: 7 Post(s)
Liked 15 Times
Great stuff! I will be bookmarking those for future purchases.
Randomhead
Liked 3,705 Times
How do you get the spacing right?
Quoted: 714 Post(s)
Liked 801 Times
With that fixture, it needs a spacer between the fixture and the dropout face to get the mounts in the right place relative to the dropout face.
Likes For dsaul:
Comes with a the spacers. You need a piece of 3/4 inch tubing and a bolt. The fixture and the spacer go on the tube then bolt the whole thing up to the drop out. As I used the Columbus chain stay with the brake mount crimp I had to locate the crimp on the mount and cut the stay together. I was surprised how easy and well it worked.
Likes For wsteve464:
"You need a piece of 3/4 inch tubing and a bolt."
I am curious about your dummy axle bolt diameter. What tolerance was there between the bolt and the 12mm hole in the dropout?
I don't know what size the bolt is maybe 10mm. The way I did it I worked off the 3/4" tube fitted into the axle slot and made sure the top of the curve was butted up against the 3/4" tube. The bolt was just to hold the tube in place. Like I said above worked great caliper lines up
Randomhead
Liked 3,705 Times
I'm confused, I need to see pictures
