To the Plus tire riders
we be rollin'
I'm wondering if you're using tires that are either 2.6", 2.8" or 3.0", do you ever feel rocks hitting the rims or if you're hitting potholes? In other words, what is the minimum tire size at which you would not hit your rims?
Run the proper psi for your weight, trail and riding style. No issues.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
That's one reason why tubeless
Genesis 49:16-17
Genesis 49:16-17
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I am 175lbs. I run 2.3s at 22/27 psi (front/rear) on a 140mm FS bike and don’t get rim strikes.
we be rollin'
Bikes: '18 Trek Roscoe 8, '10 SOMA Double Cross, '12 Brompton M6R
I'm 185, run 2.8 inch tires at ~20 PSI. No strikes yet. I can feel the tire roll on the sidewall if I drop the PSI below 17.
Disco Infiltrator
Liked 2,105 Times
You can go lower than you think, especially tubeless. I still blink though when I hear people say "twelve psi," I guess that's with a tougher carcass. 20 is really low on my pump's dial and I don't assume it's remotely accurate, that's where I aim.
https://www.bikes.com/sites/default/...hart%20(1).pdf
Genesis 49:16-17
Genesis 49:16-17
2.8s on a hardtail mtb. Locally on dirt singletrack with some tree roots for obstacles, I've run as low as 15 but usually end up at 20. (About 170lbs rider plus gear). Rode a bit in Moab earlier in the month, ran 23-25 psi and felt I could have gone lower. Plenty of opportunity for rim dings there but never got one. My riding isn't super aggressive though.
