How can you go fast on a df bike without aero bars?
#101
52psi
Quoted: 790 Post(s)
Liked 800 Times
#102
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,094 Times
Hearing voices is a pretty common psych symptom, but you're the first person I have seen who hears talking sphincters. I'd suggest getting that looked at.
Otherwise, if you really need to swipe 25 year old snark from Wayne's World, it's probably time to buy a new joke book.
#103
#105
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
Pedal faster, my son. Pedal faster. Your quest is near.
#106
Tragically Ignorant
Liked 9,094 Times
#107
Bikes: Cervelo Prodigy
Quoted: 475 Post(s)
Liked 87 Times
Here's part of the article
What?s the difference between a triathlon bike and a TT bike?
The add-on accessories needed to tackle a swim/bike/run race and achieving a position that helps the triathlete to save their legs for the run are the things that ultimately set apart a triathlon bike from a time trial bike; and it goes without saying, it’s always worth getting a professional bike fit to optimise your own position if you’re looking to buy your first tri bike.
Bike fit
In a time trial, a cyclist’s only concern is getting to the finish line as fast as possible, leaving them completely spent after an all-out effort when they get off their TT bike. A triathlete has the run to deal with afterwards, which often means a more forgiving set-up. A triathlete will generally want their forearms wider apart on the aero extensions, and bent at a slight angle at the shoulder down to the elbow. Having the seat tube on their tri bike further forward also puts less pressure on the hips and hamstrings.The add-on accessories needed to tackle a swim/bike/run race and achieving a position that helps the triathlete to save their legs for the run are the things that ultimately set apart a triathlon bike from a time trial bike; and it goes without saying, it’s always worth getting a professional bike fit to optimise your own position if you’re looking to buy your first tri bike.
#108
Bike fit
mtn_cyclist
35
08-13-18 02:31 PM
