My bike has fork chatter!
Old 05-26-19, 08:53 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara/Centurion Ironman, '18 Diamondback Syncr, '18 handmade steel roadbike
Quoted: 3056 Post(s)
Liked 198 Times in 138 Posts
Lame.
It just appeared today on a 6mi ride with my kids to a park. Apparently the 9mph coasting speed was too much for the setup and it cried uncle by chattering every time I applied the front brake.
Nothing is new and nothing has changed recently.
I have some old high level SunTour XC canti brakes with koolstop pads toed-in and use a fork cable hanger.
Never chatter on this bike before, I assume due to the cable hanger I use and the toe-in.
Odd.
Interested to see what needs to be adjusted- the pads? Tighten the cable hanger?
I only mention this due to the odd timing of not happening and I chuckled when I thought about how foreign this topic is on the forum due to tech.
mstateglfr is offline
Old 05-26-19, 09:05 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6866 Post(s)
Liked 227 Times in 185 Posts
My AlAn cross super was terrible, in that,
Now I understand mini V brakes would have helped..
fietsbob is offline
Old 05-26-19, 09:09 PM
Happy Feet
Happy Feet's Avatar
Quoted: 1244 Post(s)
Liked 152 Times in 90 Posts
I use canti's and deal with it off and on. Usually pad angle.
Funny about tech. Sometimes people complain about mech disc and think they need hydraulic and scoff at canti/V brakes. I just replaced my old front V brake pads and nearly flipped over the bars when I first used them. They stop so dramatically that they easily compress my suspension fork immediately and lock up the wheel. I just did a 13 km descent today and barely used/felt any pressure on the levers.
Happy Feet is online now
Old 05-27-19, 06:27 PM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1305 Post(s)
Liked 67 Times in 44 Posts
Do you have glazing on your rims? Try cleaning. Clean the pads too.
trailangel is offline
Old 05-28-19, 01:05 PM
clasher
clasher's Avatar
Quoted: 153 Post(s)
The cable hanger that mounts to the fork crown is supposed to help a lot. Tektro makes one that looks decent enough.
clasher is offline
Old 05-28-19, 01:16 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1708 Post(s)
Liked 120 Times in 87 Posts
The OP uses a fork crown hanger.
79pmooney is offline
Old 05-28-19, 01:17 PM
clasher
clasher's Avatar
Quoted: 153 Post(s)
lol guess i need to learn how to read!
I'd probably swap the pads since nothing has really changed on the bike it seems like the easiest place to start... the pads are really the only thing that "ages" I guess.
clasher is offline
Old 05-28-19, 09:25 PM
phobus
Quoted: 136 Post(s)
Liked 20 Times in 12 Posts
Maybe you've already checked this, but make sure your headset's preload is set correctly. I chased after a similar chatter issue recently, and it turned out I just put a slightly-too-small spacer above the stem.
phobus is offline
Old 05-29-19, 06:36 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Hi all- just coming back to say thanks for the suggestions. I havent had time to look at it, but plan to tonight since tomorrow's plan is a 40mi gravel ride followed by a 30mi paved ride in the evening.
Ill loosen the stem and check the headset preload, make sure the brake pads are toed in, clean off the pads, reset the wheel in the drop outs, and make sure the cable hanger is secure. As a last resort, ill shake the brake cable a few times then slam the bike down and forward multiple times with the brake engaged since that is apparently my default and confused go to move.
Old 05-31-19, 08:10 PM
shelbyfv
shelbyfv's Avatar
Quoted: 1157 Post(s)
Liked 165 Times in 112 Posts
If the bike happens to have threaded headset, a roller bearing headset might help. I used a Miche Miche 1'' Threaded Needlebearing Headset - now factory discountinued on an old Cannondale and it smoothed out nicely.
shelbyfv is offline
Old 07-07-19, 09:01 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Well I finally got around to looking at this bike today. Loosened the stem, tightened the headset, retightened the stem, and all is back to perfect.
Really crazy since the headset didn't feel loose to begin with.
I can't wait to finally get back on the gravel bike. It's been a month and I'll finally get in a ride or two in the coming weeks.
Road riding leading up to ragbrai has taken up way too much riding time!
Old 07-07-19, 09:10 PM
shoota
shoota's Avatar
Quoted: 1023 Post(s)
Liked 32 Times in 28 Posts
Woot. Good job. I'm not sure I understand why you have to ride a road bike to "train" for RAGBRAI?
2015 Cannondale SuperX Hi-Mod
shoota is offline
Old 07-08-19, 04:10 AM
mstateglfr
Sunshine
mstateglfr's Avatar
I help run an at risk youth cycling mentorship program where teens ride with peers and mentors 3x/week. We start in March with indoor training, then ride April thru July. Rides are 25-75mi, depending on time of year and weather.
I usually ride twice a week with the team. Add in a ride with one/both of my kids each week and an occasional group ride with co-workers and I'm pretty much at max for available riding time.
Old 07-08-19, 07:12 AM
shoota
shoota's Avatar
Super dope! I'm jealous, I wish we had something like that.
shoota is offline
Old 07-08-19, 08:25 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Its pretty cool- each year the group of kids is a mix of socioeconomic, cultural and racial groups. Some are in foster care due to chaotic home life, some are limited in opportunity due to sick/physically limited parent, some have planning and time management challenges, and others are socially awkward due to nerves or anything else. We are financially independent, but are in part sponsored by RAGBRAI and the regional YMCA. Bike World donates the bikes and gear for each new rider. Once the 1st year riders complete RAGBRAI, they get to keep the bike and can come back for subsequent seasons.
shameless plug- Helping Youth Set and Obtain Goals
related note- i rode my gravel bike into work this morning and it was pleasant to not have the fork vibrate every time I stopped. Amazing how we can hyper-focus on little annoyances and gain such pleasure when they are resolved.
Metal Man
Advocacy & Safety
52
08-25-14 05:05 PM
cupcrazy4
Classic & Vintage
25
03-30-09 08:51 PM
GuitarWizard
Northeast
2
03-13-07 04:32 AM
billallbritten
Professional Cycling For the Fans
1
01-18-07 04:36 PM
RatFinkABCAN
Introductions
2
12-19-06 06:34 AM
