Trek FX 7.2 Clyde-Cycle
Quoted: 11 Post(s)
Liked 13 Times
It has been quite a while since I posted here. I said I would return and post some details of my Clyde-Cycle. I wanted a commuter that could reliably carry me, my laptop, a change of clothes & groceries in comfort for a routine 8km urban spin to and from work.
Secondly I wanted something that I could bring for an extended spin on the way home or go for a weekend spin on.
Here is the story of what worked for me.
I had a tight budget to start and I bought an XL sized Trek FX 7.2 off a local equivalent of craigslist at a favorable price. In hindsight now I don’t think it had ever been properly set up and that probably accounts for a lot of the early component failures that followed.
Rear wheel:
This deserves a paragraph all to itself. Again in retrospect the spokes on the original bontrager wheel probably were not tensioned to suit me or the loading. I became so familiar with the “prang” of a broken spoke and subsequent rear wheel wobble that I was on 1st name terms with the guys in 2 local LBSs. After some research I decided to buy a rear wheel from a tandem and infact I got one custom built. This was a truly wallet opening event as the wheel cost me as much as the full bike did. I went for a 48 spoke unit and it was the 1st of many steps towards near perfect reliability.
Front Wheel:
I had no issues with the original Bontrager front wheel but I wanted dynamo powered lighting. Swapped the wheel out for a 36 spoke item with a shimano dyno hub. My LBS guy convinced me to go for this basic shimano hub, saying it would last longer than the rim due to the rim brakes and my heavy breaking. This guy who I found after buying the rear wheel turned out to be a wheel builder and tensioned the new front wheel to suit me.
Rear carrier:
I picked up a heavy duty carrier on a local used website. It has been super.
Mudguards:
SKS Long. Superb, even if they are a fiddle to fit.
Brake Pads:
I’ve found the shimano pads to be fine and haven’t experimented too much. I always have a spare set to hand. The brakes themselves are adequate, an ideal version of this bike would have disc brakes but more about that later.
Bottom Bracket:
Original bracket failed quickly, replaced with a shimano unit from LBS and has been perfect since.
Headset Bearings:
Original Bearings failed quickly too, were replaced by a toplight unit.
Crankset, chain and rear gear set:
Replaced due to wear.
Lighting:
B+M CYoT front and Toplight Rear. Perfect reliability so far.
Saddles:
Bontrager item failed after a few months. Initially replaced with a fabric item until it failed after about 12 months. It failed and I replaced it with a fabric unit.
On thing I found was that while using an ortlieb saddle bag the saddle was stiffer. I think this can lead to early failure of the saddle.
I will probably change to a post mount saddle bag in the future but really it’s fine for the moment.
Panniers:
I used Ortlieb fully reflective items for commuting. Perfectly dry contents every time, even in torrential rain.
Tyres and tubes: I got several pinch flats concurrently with the early spoke failures. I ditched the Bontrager rear tyre early after a poorly positioned brake pad caused it’s demise.
Currently I’ve got 622x47 on the rear and 622x37 at the front. The increased width at the rear is a comfort and reliability step. Tyres are schwalbe marathon plus and the tubes are schwalbe too. I have not had any punctures on these tyres.
Cockpit:
I’ll save that for a later post, it’s a bit unconventional
Cost:
About €1500 total spend including all maintenance. Not bad considering this is my main transportation and I’ve had it regularly serviced. I estimate I’ve done 5000km in total.
What would I do differently? If I had money to had I think I would buy a steel framed, disc braked touring bike from say thorn or vsf. Other than that, all of the components I have now are perfect for my needs.
I hope this is useful to someone trying to get a reliable comfortable Clyde-Cycle. I’ll share some photos and update here if I make any big changes.
Rear wheel:
Front Wheel:
Rear carrier:
Mudguards:
Brake Pads:
Bottom Bracket:
Headset Bearings:
Lighting:
Saddles:
Panniers:
Cockpit:
Cost:
Quoted: 11 Post(s)
Liked 13 Times
In the photo above you’ll see the cockpit is a bit unusual. The bell was the 1st accessory to go on. It’s a BBB item.
For longer rides I wanted some bullhorns and considered getting some Ergon EG5L which look and feel great. I was conflicted because I did not want to shorten the bars.
The best compromise is how the bars are now. I haven’t adjusted anything in at least a year. The previous year felt like I was continuously adjusting something. I’ve retained the full width, added a pair of nice bull horns that I picked up cheap. I had to butcher som grips to fill the gaps but this works well for me.
The mirror was added to help with commuting in traffic. I can’t remember the make. Cateye maybe.
There is also an adjustable stem that I added from an old bike.
The bar is a little wide for traffic but it’s not much wider than me or the pair of loaded panniers so I find the width ok.
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
You're describing what I believe most committed, long term commuters eventually figure out; finding the perfect bike is a process of discovery and evolution. I always advise Clydes seek out a quality wheel set at the earliest opportunity. I'm not so sure I'd recommend a 48 spoke rear, but by doing so you've just about guaranteed yourself a lifetime wheel (not counting brake track wear). And your LBS guy is correct - I have a Shimano dyno hub similar to yours and it's provided thousands of trouble free miles. Your cockpit setup isn't anything too radical. SQ-Labs inner bar ends seem right up your alley.
Isn't is nice when you get your bike dialed in just the way you like? It's good that you've posted your experience as it could be a big help for others trying to find their own solutions.
-Kedosto
-Kedosto
Quoted: 11 Post(s)
Liked 13 Times
-Kedosto
-Kedosto
The 48 spoker felt like overkill when I took it out of the box but it has stood up to nearly 2 years of abuse. The weight just makes me stronger, that’s how I see it anyway.
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
As soon as I saw your air pump I knew you were a serious cyclist. I have repaired so many flats for cyclists who should know better than to leave home without a proper tire pump. CO2 cartridges are no better. I've repaired so many tubes for folks whose cartridge ran out during the repair. or had previously leaked out. If you break something more substantial like your chain then maybe you don't have the proper tool to repair it and have to walk home or beg a ride. In my 60 yrs of riding I've had very few instances where a loose stem or broken chain has stopped a ride. Your bike looks great. Your 48 spoke wheel is a plus on the durability scale and probably means that wheel will never be the reason you couldn't complete a ride. The bicycle business is just like the fashion industry in that they sell the latest fad or fashion if you will. Being a bigger person can take you out of the ordinary fashionable bicycle business and put you into the durability market. I reside in that market with you. I ride 36 spoke wheels and on the rear 10 speed hubs I install 13/14 gauge spokes for durability. There are certain rims I stay away from because of previous failures I've experienced with them. I love deep aero rims because they are so rigid and tolerate my weight well. Kedosto got it right when he said we follow a process of discovery and evolution. Come back in a couple of years and the same bicycle may have completely different setups on it. Good luck with your great looking new bicycle.
Quoted: 11 Post(s)
Liked 13 Times
Thanks for your comments. The course of bike evolution is part of the fun. I had a smaller mini pump and said i’d use it to pump one of the tyres after a tube change. It was not comfortable using it at my house so it definitely would be useless on the side of the road in the rain.
The replacement floor mount item came quickly after that. I’ve never actually used it on my own bike. It’s probably 300g but if you saw a photo of me you’d understand why that’s inconsequential.
Quoted: 5224 Post(s)
Liked 3,581 Times
How do you like having those brake levers so close to center?
Quoted: 11 Post(s)
Liked 13 Times
They work really well for me in that position and typically operate the brakes with one or two fingers.
I can reach the brakes from the bull horns too.
I intend to move everything about 10mm wider each side in the next while.
Likes For WOT:
Quoted: 11 Post(s)
Liked 13 Times
The bracket for my B&M front light was too short casting a nasty shadow from the front wheel.
My options from the B&M catalogue were to mount the light on the handlebar or to get a marginal increase in height from their other brackets.
Neither were ideal so with som digging I tracked down this SON item which is going to do the trick nicely.
I may yet make further tweaks to the positioning so the wiring is temporary
Before
After
SON Part number reference
Before
After
Quoted: 11 Post(s)
Liked 13 Times
Also made the move to clipless, which is super. No issues with falling off yet but I have set the pedals to just about the lowest possible strength setting so unclipping is really easy.
Old reliables
Flat side
SPD side
Old reliables
Flat side
SPD side
Your bike reminds me of my Norco MTB that I ride. It will probably be what I use until I can afford something with disc brakes and threadless headset, which are two items I really want, that and and a slightly bigger steel frame.
Quoted: 11 Post(s)
Liked 13 Times
A week ago I was out for a spin and after pulling up following a speedy descent there was a rubbing noise.
Less than a minute later and BOOM! The side wall of my rear rim gave way, puncturing the tube.
Quoted: 11 Post(s)
Liked 13 Times
My long term goal is now set to upgrade my frame to a disc braker. Therefore I wanted to spend as little as possible on fixing this.
Rebuild was quoted at £160 by the original wheel builder incl shipping 2 ways.
After doing some research I decided to have a go at swapping the rim.
Like for like Kinlin 48h rim £40 plus a spoke key and replacement rim tape. I decided to recycle the spokes and the nipples. Time will tell if that was a good decision.
I loosened all of the nipples gradually down to a couple of threads and then taped the 2 rims together.
One by one swapped each spoke and nipple.
Quoted: 11 Post(s)
Liked 13 Times
No Truing Stand, dishing tool or
No Spoke Tension Meter
I mounted the wheel into the frame and began dialing in tension, hop, dish etc.
48 spokes are a bit of a nightmare to chase around the rim, I admit I thought I was going a bit crazy at one stage.
My goal was to get it good enough that I could cycle it for the coming week. I’m running 47-622 at the rear with minimal clearance to the mudguard and the chainstays.
New Rim Tape, Tube and mounted up the tyre. Perfect clearance! Result.
Brought it for a 10km cycle and there were a a few creaks and pings from the rear. I did get a little bit of rubbing. 10minutes of micro adjustments later and it’s like new again.
All in all, I know it’s not 100% and I’ll get it onto a trying stand in the next week BUT it’s unbelievably satisfying to have gotten it to this point with only a spoke key, a ruler, some chain lube and some tape.
Likes For WOT:
Quoted: 131 Post(s)
Liked 141 Times
Quick home repairs
Quoted: 131 Post(s)
Liked 141 Times
Quoted: 11 Post(s)
Liked 13 Times
Thanks for your kind comments and further research and input. After 2 years of hardship induced by a heavy rider, heavy panniers and aggressive braking sometimes needed for city cycling I ain’t complaining. Quite the opposite infact.
I do think the failure was less to do with brake track wear and more to do with brake track deformation due to heavy braking pressure.
I’ve sent the old rim for recycling now but i’ll add a sketch later to illustrate my point.
In broad terms I agree, the profile of the Kinlin rim isn’t up to the job long term.
I thoroughly enjoy the tweaking, research, tweaking process but I’m also reluctant to throw the credit card at every new shiny thing that comes along without research.
I considered 3x rims that I could find in 48h drilling.
The Kinlin was the route of least resistance for a few reasons: I could reuse the spokes and nipples so no issues with length or fit. I could also order it from a reputable local vendor and get it in my hands within a couple of days.
Given that I had never even had a spoke key in my hand, let alone used one; a like for like swap really appealed to me from a getting the job done point of view.
I thought about the velocity chukker but 48h weren’t available to me in the short term and i’d have needed more research re spokes and nipples.
SJS Cycles have the Rigida Grizzly MKII ex-stock and i’d have been pretty comfortable with spokes and nipples there. The downside was the CSS braking surface. That would bring me to needing to upgrade the brakes to accept brake blocks and would leave me with a mismatched braking system. Special pads for the CSS rear and standards for the front.
That would be called project creep in my line of work.
I take your point on the disc brakes. I feel similarly but without trying I’ll never know I guess.
I’m going to look into rims that are used with the hydraulic rim brakes and various other things but essentially I’d be aiming to have this rim swapped out with a new rim or complete wheel before it fails again.
That gives me about 18months to figure out a plan, during which time a lot more components will also be replaced!!
58km on Sunday and 26km this morning. All is well.
Until the next chapter....
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 564 Times
@WOT, I did many of the same things you had done, with a Trek DS. Started with a custom quality wheelset, along with fenders and rack. Altered the saddle, stem and bars to suit, plus good lighting and safety/reflector improvements. Made a much more useful, practical and comfortable ride, at the expense of being heavier than the "floor" model as delivered. A joy to ride, by comparison.
As some have suggested, finding the right "fit" for things is a process.
The wheelset I did were: Velocity Dyad 700c 36H, DT Swiss spokes, Shimano Deore XT hubs, quality build, with Conti Tour Ride 700x1.95 tires. Not a peep through years of use on rougher urban streets and mild trails. Considered a higher spoke count, being a heavier rider, but 36H was fine given the quality of the build.
